20 Most Recent Samsung X10 XTC 1600 Notebook Questions & Answers
Hi! Welcome to www.fixya.com.
Click "Start" and then "All Programs."
2Click "Samsung," and then click "Samsung Recovery Solution." Click "Samsung Recovery Solution" again to launch the Samsung Recovery Solution program.
3Click "Restore," and then select "Complete Restore."
4Click the empty circle to the left of "Complete Initial Status," and then click "Next." The computer will automatically restart.
5Click "Agree" when the licensing agreement appears on the screen.
6Click "OK" after the computer restarts to begin the restoration process. When the process is complete, a dialog box will appear on the screen telling you the process is complete and that you can click "OK" to restart the computer. Click "OK." When the computer restarts you can begin setting up Windows.
Read more: How to Restore Factory Settings on a Computer System ' eHow.com http://www.ehow.com/how_7213487_restore-factory-settings-computer-system.html#ixzz1Sb728twX
Hope this resolution fix the problem on your computer.Thanks for contacting Fixya. Bye for now.
Samsung X10 XTC... | Answered on Jul 19, 2011
If there is a display switch in the functions on the keyboard (most likely will look like a laptop monitor or a computer monitor on the keyboard). Press the function key and the button associated with that and wait 3 to 4 seconds (you may have to press it multiple times) If you have anything in the vga slot, then it may think a monitor is plugged in and won't display the laptop screen.
If none of the above work, then maybe your computer is having a systematic failure, or the screen connector is loose.
Google Translate: Si hay un cambio en las funciones de visualización en el teclado (muy probablemente se verá como un monitor de ordenador portátil o un monitor de ordenador en el teclado). Pulse la tecla de función y el botón asociado con eso y espere de 3 a 4 segundos (es posible que tenga que pulsar varias veces) Si usted tiene cualquier cosa en la ranura de vga, entonces puede pensar que un monitor esté enchufado y que no mostrará el pantalla del portátil.
Si ninguno de los trabajos anteriores, entonces probablemente el equipo está teniendo un fracaso sistemático, o el conector de la pantalla está suelto.
Samsung X10 XTC... | Answered on Jun 14, 2010
Help me, I have same problem I thing..
my problem is that,
I have samsung x10 series laptop so I want to install win xp or pro to my laptop...
when I started to install, I chose boot cd rom and it reads from the cd rom and win xp or pro installed after some times. at thşs tiem my problem is starting, after installation, when   Windows is starting  (the loading bar is shown) , at the loading process, it stops  and I wait for long time, anything does not happen. I restart the windows, then again problem is happen. I know that ı have to make changing in bios options. when I made the changing, it was worked but now I could not remember what was the changing...
please help me....
Samsung X10 XTC... | Answered on Jul 24, 2008
it meant backup when you buyed a new laptop it backup all OS,SW and stored in different partition,OEM supplied recovery media is commonly shipped with most computers to allow the user to reformat the hard drive and reinstall the operating system and pre-loaded software
Samsung X... | Answered on Feb 14, 2014
If you can't get one from samsung.com (Support section) then it won't be free. If you can't download it, then they'll either charge you or you will have to find an OS disc matching what you have and after running the install, punch in the product key on the bottom of the laptop for the OS, or purchase a new copy of Windows.
Samsung X... | Answered on Feb 13, 2014
Remove the CMOS battery for 30 seconds and put it back in. This helps clear the BIOS password.
Samsung X... | Answered on Jan 17, 2014
Have you recently changed the resolution/refresh rate? This is usually set automaticallly by windows by check anyway.
Right click the desktop and select Screen Resolution
Change the slider/dropdown to the (recommended) selection and click apply. Click keep changes if it appears.
Still having issues then go back into Screen Resolution and click the "advanced settings" blue link on the bottom right.
Click on the "Monitor" tab and select the highest refresh rate you can and click ok. again click "keep settings" if it appears.
Samsung X... | Answered on Dec 23, 2012
https://www.samsung.com/us/support/troubleshooting/TSG01110761/
Samsung... | Answered Yesterday
Check the security settings of your mail server to ensure you're not being blocked.
Here are some 'standard' settings that may work with your system.
Gmail Incoming Outgoing
Access Type Web & POP3 Web & POP3
Email Address Format [email protected] [email protected]
Account Username Format
Full email address Full email address
Server Address pop.gmail.com
Use SSL: yes Port:995 smtp.gmail.com
Use SSL: yes Port:465
Hotmail Incoming Outgoing
Server Address pop3.live.com smtp.live.com
ic24 Incoming Outgoing
Server Address mail.totalise.co.uk smtp.tiscali.co.uk
UKGateway Incoming Outgoing
Server Address pop.ukgateway.net smtp.ukgateway.net
UK Online Incoming Outgoing
Server Address pop3.ukonline.co.uk smtp.ukonline.co.uk
Vippowerent Incoming Outgoing
Server Address pop.vppn.com
Virgin.net Incoming Outgoing
Username Username
Server Address mail.virgin.net mail.virgin.net
Wanadoo Incoming Outgoing
Email Address Format [email protected] name.wanadoo.co.uk [email protected] name.wanadoo.co.uk
name.wanadoo.co.uk name.wanadoo.co.uk
Server Address pop.wanadoo.co.uk smtp.wanadooasdl.co.uk
World Online Incoming Outgoing
Email Address Format [email protected] worldonline.co.uk [email protected] worldonline.co.uk
Server Address pop.
tiscali.co.uk smtp.
tiscali.co.uk
Yahoo.co.uk Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.co.uk smtp.mail.yahoo.co.uk
Yahoo.com Incoming Outgoing
Username Username
Server Address pop.mail.yahoo.com smtp.mail.yahoo.com
Settings - E-mail
You'll need to complete all steps for this to work. Make sure that if you have to enter O2 in the settings you use the letter O and not a zero.
The following settings are if you use O2 Email as your ISP (Internet Service Provider).
If you require different settings eg Yahoo, Gmail etc please click here
1. Tap the Application tab on the bottom of the screen
2. Tap Email
3. Tap Next on the Welcome to Email setup screen
4. Tap on the Email address text box and enter your Email address then tap Done
5. Tap on the Password text box and enter your Password for your Email account then tap Done
6. Tap Next
7. Your phone will now try and download your setting to your phone and set up your account, if this can not be done you will see the message, Setup could not finish. Unable to open connection to server. Tap Edit details to continue.
8. Tap Manual setup
9. Tap the Username text box and enter your full Email address then tap Done
10. Tap POP3 account
11. Highlight POP3 server and tap the text box and enter mail.o2.co.uk
12. Check that Port is default set at 110
13. Highlight Next and tap
14. The phone will now check your settings
15. Tap the SMTP server text box and enter smtp.o2.co.uk
16. Highlight Next and tap
17. The phone will now check your settings
18. Tap Next on the Account options screen
19. You now have the options to add a name for your new account plus add your name to outgoing messages
20. Tap Done
Samsung... | Answered 2 days ago
who to fix a Samsung home Air conditioner, on computer repair site?
why not ask them first.
read there service manual yet.
no samsung model stated, no answers easy.
https://www.samsung.com/in/support/
my wild guess, replace the now clogged filter.
i see manuals there one states
The filter
clean/
replacement
indicator
is blinking
continuously. then tells you what to do.... RTM
learn to find and read manuals first.,
Samsung... | Answered on Feb 10, 2020
We are a North American site. Please converse in English.
What could cause Sim to lock my Samsung Galaxy Amp 2 that has been damaged? dej? d? v? rrouiller?
SIM Lock
https://www.fixya.com/support/r26056685-phone_asking_puk_code
https://translate.google.ca/?hl=en&tab=rT
Samsung... | Answered on Feb 05, 2020
NO PC stated make and model.
no OS stated
no dock model stated, Samsung model.
no answers.
Samsung... | Answered on Jan 26, 2020
wrong forum posted (answer are better and faster using the right forum.
post to TV not PC.
or read the manual at Samsung.com
the remove may have weak batteries.
Samsung... | Answered on Jan 18, 2020
Android is not compatible with your model....You may want to refer below mentioned link for more information
http://www.topandroidphones.com/android-phone-list/
Samsung... | Answered on Jan 13, 2020
Samsung X10 XTC 1600 Notebook Logo
5 questions posted
Top Samsung Computers & Internet Experts
Ekse
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
X Samsung
  • X Samsung
Most Popular Question
restore samsung x10 factory settings
  • Computers & Internet
