20 Most Recent Samsung V25 CXTD 2000 Notebook Questions & Answers
to reset the BIOS, remove/reinsert the CMOS battery which is inside of your laptop ryanpajaro20_10.jpg Kindly consult your PC dealer for the teardown of this device
Samsung V25 CXTD... | Answered on Mar 23, 2011
Post me the brand and model of your laptop and which version of windows it has I'll find it for you.
Samsung V25 CXTD... | Answered on Nov 25, 2010
Microsoft works 8 is NOT a boot disk. It does not have an OS
Samsung V25 CXTD... | Answered on Mar 26, 2010
Try Disk cleanup by right clicking the on the hard drive and clicking properties
Samsung V25 CXTD... | Answered on Feb 08, 2010
hello there,
if i was you i would totally forget about avg because that is 1 of the worst antiviruses you can get and get eset nod 32 it is free will never give you a problem at all updates it self you dont have to update it
and when you have downloaded it it will ask for activation key
here are the steps to get the activation key,
1. go to www.youtube.com
2. type in eset nod32 antivirus serial key
3. click on one of the videos
4. look in the description or look through the video
5. it should have a key there then copy and paste that key into eset nod 32
6. and it will say completed
hope this helped
Samsung V25 CXTD... | Answered on Jan 16, 2010
there is a button to activate it or go to control panel then network connections and then enable wireless lan
Samsung V25 CXTD... | Answered on Dec 01, 2009
Dear sir
her i think your problem is on operating system(OS) lavel and u need to recover yr os with recover dvd or recover disk whitch provide with yr laptop and if you need to reset factory setting you have to go on bios setup screen
1 start laptop
2 press F10 button
3 then go to last screen ad find " setup defullt opetimeze"
4 then got to save and exti button
simple.. if u need more help please contact feel free.. thianks..
Samsung V25 CXTD... | Answered on Apr 11, 2009
please ensure that the TV has a compatible input for connecting laptops etc..right click on empty desktop..go to graphic options u will see an option as output to.(if the tv is connected properly)
.hope it helps!
Samsung V25 CXTD... | Answered on Nov 02, 2008
One way to make sure the system is still working, remove the Batery, then plug the power adapter only and turn the computer back on, normally if the laptop goes into Hybernation mode and the battery is low on power this can happen. If that fixes the system then you can do a safe shutdown and re-install the battery and turn your laptop on and it should come on, the fact that you mentioned this has happened before makes me believe it is Hybernation issue. Good Luck.
Samsung V25 CXTD... | Answered on Mar 31, 2008
Does this all-in-one have the original Windows 7 installed or has the OS been upgraded? This could be a driver issue or a problem with the Ethernet cable (if you are using the wired network). It could also be caused by the distance/direction between your computer and the router, if you are using the wireless network adapter. Try a new cable. Open the Device Manager (right click on Start for all versions of Windows). Find the section with the network adapters and check for entries with a yellow triangle with an exclamation point or red triangle with an x. These indicate the driver that has an issue.
I recently went through some trouble-shooting on a slow computer running Windows 10 2004. After checking everything with the drivers, including launching the system in Safe Mode with Networking, I finally found the Blue Screen of ***** that the user didn't mention. The Windows Driver Verifier was causing crashes. The solution turned out to be using the sfc /scannow command at the command prompt when run as administrator. (Again, use right click on Start for a fast option to find the command prompt.)
On one laptop (with OS updates from Windows Vista, Windows 7, 8, and 10) I dealt with, Microsoft installed a driver for the wireless network under Windows 10 that just didn't work. It would make the wireless network slower than the 10/100Mbs wired network adapter. Every time I did a clean install, I had to specifically install the correct Broadcomm driver for the wireless network adapter. I made a point to save this driver to a CD so that I could speed up restoring the network functions before Windows tried to do any updates.
I hope this helps. Please add a comment with more information about the OS on the DP700A3B-A02US and the internet connection type that you are using. If you see any error messages or had any system crashes, add any key words that you saw. Then I can better assist you in solving the problem.
Samsung... | Answered on Oct 20, 2020
Read this
support microsoft com
Samsung... | Answered on Oct 15, 2020
Resolve the issue of Error Code 0xc0000185 with the help of the Hp Technical Support Phone number. Here the Technical Expert will provide you all possible help for getting out of this issue. Just visit the help website through the link shown below. Link:- https://www.hptechnicalsupportphonenumber.com/blog/fix-hp-printer-error-code-0xc0000185
Samsung... | Answered on Sep 11, 2020
there is a TP link that you can get from places like Jaycar that will turn your house wiring into extension cords for the router
the operation can be explained at the shop but it means that you can extend the wires to any part of the house and by using ethernet cables will connect other computer, printers and tv units easily
cheaper that new modems and routers
Samsung... | Answered on Jul 14, 2020
Well... Yes and No... Does this set have an Ethernet port?
If so then try and plug it in that way.
Try and reset the router and tv
Make sure the connection settings are correct or defaulted
Are you entering the correct password?
Are you close enough to the router?
reset the network setting on the tv
it's possible you may have a bad wifi chip but im not thinking you do. Good Luck and come back it the above does not help we can go more into detail.
Mr.Mike
Samsung... | Answered on May 20, 2020
Samsung V25 CXTD 2000 Notebook Logo
22 questions posted
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Samsung Computers & Internet
Most Popular Question
samsung v25 laptop come
  • Computers & Internet
