20 Most Recent
Samsung ML 1651N Laser Printer Questions & Answers
Samsung 1650 Laser Printer
It seems the the power supply boad is dead. in short we call it (SMPS).
if you are electronic trained than you may want to go ahead and dissemble the printer to check on the SMPS fuse, capacitor and transformer.
unscrew the left side cover of the printer. open back & front cover and by using pull techic don't worry if you control your strenght the cover will not break.
Hop this Help :)
Samsu Tech
Samsung ML-1651N Printer
I have the exact same problem with my ML-1651N printer. It started out as an annoying problem that i solved by pulling the paper try out and then pushing it back in again. Now that solution doesn't work anymore.
Printer not take paper
Look for a small piece of paper or other foreign object stuck in the paper path, or a rubber roller which has gotten slick and will no longer pick a sheet.
A broken gear in the drive mechanism, broken gear tooth, a small piece of broken plastic (from inside the printer itself), all of these can produce a problem like this.
Dell 1700 Printer
There is a sensor that is under the toner cartridge. make sure that it's sticking up. The fuser in the back of the printer has one sensor flag that is supposed to stick up all the time except when paper goes through it. What I see alot of times is that the sensor flags get stuck halfway down and all they usually need is a little help back up. Sometimes when removing a paper jam from the back of the printer the flag can be broken off, if that happens then your most likely looking at replacing the fuser. If you feel up to it you can take off the two side covers (the left one has a screw half way down in the front that you have to take out first) and then there are four screw on the back that take off the back cover so you can get a look at the fuser better. Remember to look for a screw that attaches the back cover directly to the fuser when you pull take it apart. Make sure there isn't any dust blocking the sensorts. Hope that helps.
Samsung ML-2000
from where i can download printer driver for samsung ml-2000 series laser printer
Location of Solenoid samsung ML-2510 printer
Pick-up SOLENOID needs replacing.See this link.http://www.arbikas.com/view/locator/ML-2510.pdfPart is JC33-00015B SOLENOID-MP_R2;-,SCX-4720F,DC24VFairly involved strip down but there are a Cpl of you tube videos out there showing something similar.Looking to undertake this task myself and will You Tube it.
