20 Most Recent Samsung SCX-5315F All-In-One Laser Printer Questions & Answers
you are check the cartridge or laser scaner
Samsung... | Answered on May 10, 2014
just open the scanner unit clean strip cable and end position sensor on the logic board and start the printer :)
Samsung... | Answered on Aug 09, 2012
It sounds like it is dirty where it feeds through and not on the flat bed glass. Try and gently lift up the top section where the paper feeds through. If it resists you may need to locate clips or screws but generally the thin strip of glass under the top feeder is easily accessible. Good Luck
Samsung... | Answered on Feb 18, 2010
If you have taken apart the printer and checked where all the paper could have jammed up, use compressed air first on the printer. Then, check your toner cartridge. I know on my HP I had a sample toner cartridge and I put another one into the printer. It either was damaged or scratched, etc. and it caused the printer to not respond.
Samsung... | Answered on Sep 01, 2009
The fact that it's printing anything suggests that it is not a Toner problem. Remove the toner, and have a look at the run inside the printer, checking for any excess toner which is in there. Also, check the Drum and Imaging Unit for damage, wear and tear etc. There will also be a static strip near the imager, with a little tab which you can sweep across the unit to clean it.
Samsung... | Answered on Mar 05, 2009
HI PLEASE CLEAN THE CCDUNIT .YOUR PRINTER CCD UNIT IS VERY LOTS OF DEST.AFTER CLEANING CCD THEY PRINT SAMSE SO REPLACE CCD UNIT WITH CABLE
Samsung SCX... | Answered on Dec 02, 2019
go directly to Samsung to download driver
http://www.samsung.com/levant/support/model/SCX-4828FN/XSG-downloads
Samsung SCX... | Answered on Apr 02, 2019
Samsung service code is fn # 1934, go to tech mode and reset to factory set
Samsung SCX... | Answered on Jan 26, 2019
It has no built in duplex function only manual duplexing. Print the odd pages first than turn them up and print the even pages.
Samsung SCX... | Answered on Apr 14, 2016
Samsung SCX-5315F All-In-One Laser Printer Logo
Popular Tags
12 questions posted
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
blank copy print good
  • Office Equipment & Supplies
