20 Most Recent Samsung SCX-4016 Laser Printer Questions & Answers
http://www.samsung.com/us/support/owners/product/SCX-4016
Samsung SCX-4016... | Answered on Oct 02, 2015
The pickup roller sits on top of the tray that lifts. Cleaned the roller with soapy water (fairy liquid is best). To get to the bit of the roller that you cant get to. Just ask the machine to print while watching the roller and when it start to rotate kill the power and then you can clean all of it. Power up again and the roller will turn back to its original position. all should be well now.
Samsung SCX-4016... | Answered on Jun 04, 2011
  • Install the drivers for this device from the CD that came with it as per the link below
http://www.fixya.com/support/r3559995-installing_devices_on_pcs_and_laptops
  • Then connect the device and allow Windows some time to autodetect and load its drivers.
  • After that you can start using it.
  • To do that you can start MSWord and from the File Menu select Import. This will give you an option to import from the Scanner. Use that and scan a document.
  • Else, there would be a software with the device that can enable you to scan the document directly from the scanner.
  • Just remembert hat if you scan using the OCR (Optical Character Reader) SW then only would you be able to edit it. Otherwise, you can scan as a graphic file and that can be opened only in a graphic program, ie, Paint etc.
Samsung SCX-4016... | Answered on Nov 24, 2010
This is a fuse error which is on the Cartridge, please check the cartridge very carefully, the fuse is somewhere on the edge of the cartridge/s, simply remove it and try again. You problem will be fixed. I hope your cartridge must be similar with this one.. (click here)
Fuse:
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Samsung SCX-4016... | Answered on Aug 30, 2010
laser scanner unit error replace it
Samsung SCX-4016... | Answered on Aug 17, 2010
hello remove and replace toner machine display toner empty but didnt matter
Drivers and software for the printer can be downloaded from the link below.
http://www.samsung.com/ca/support/detail/supportPrdDetail.do?menu=SP01&prd_mdl_name=SCX-4623FW
Robert from Blitware
Samsung SCX-4016... | Answered on Jun 21, 2010
It seems that you need to change the fuse on the toner cartridge...
or you better change the cartridge itself.
Samsung SCX-4016... | Answered on Jun 15, 2010
1. open front door,
2. look for black toner cartridge inside
3. pull back toner cartridge
4. Replace cartridge whit new one on the same place
Samsung SCX-4016... | Answered on May 27, 2010
You can buy Toshiba 2060 or hp laserjet 1100 pickup roller rubber.and assembling it.no need 10 $ only 3$.
Samsung SCX-4016... | Answered on Jan 23, 2010
open backside of printer and look foe any misplaced parts inside...
Samsung SCX-4016... | Answered on May 27, 2009
Absolutely. Just click on the "PROPERTIES" button found on the "PRINT"menu. Find the "PAPER SOURCE" option, open it and select "Manual Paper Tray" or "Manual MPT". As soon as you confirm your print job, you unit will display a message asking for paper on the manual tray, which is the horizontal slot just above the paper tray. Insert each legal paper manually until your print job is done.
Samsung SCX-4016... | Answered on Nov 01, 2007
HI PLEASE CLEAN THE CCDUNIT .YOUR PRINTER CCD UNIT IS VERY LOTS OF DEST.AFTER CLEANING CCD THEY PRINT SAMSE SO REPLACE CCD UNIT WITH CABLE
Samsung SCX... | Answered on Dec 02, 2019
Samsung SCX-4016 Laser Printer Logo
30 questions posted
Top Samsung Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Muntejaya Ginting
Muntejaya Ginting
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
SCX Samsung
  • SCX Samsung
Most Popular Question
looking repair samsung scx 4016
  • Office Equipment & Supplies
