20 Most Recent Samsung ML-2150 Laser Printer Questions & Answers
Toner low
If you have toner chip , please change toner chip, than you can see new life toner cartridge
5/5/2014 9:48:36 AM • Samsung ML-2150... • Answered on May 05, 2014
4answers
Engine LSU error printer model samsung ML2150
how can over come from LSU error problem in samsung all in one machines
5/5/2014 9:47:01 AM • Samsung ML-2150... • Answered on May 05, 2014
0answers
3answers
Software download
1/23/2013 5:38:44 PM • Samsung ML-2150... • Answered on Jan 23, 2013
Arguments are invalid when installing. What do I do?
Instead of trying to install the driver from the CD. Download the latest driver from here and install it:http://www.samsung.com/us/support/owners/product/ML-2150#content2
8/19/2012 6:54:53 PM • Samsung ML-2150... • Answered on Aug 19, 2012
Engine fuser error how can
replace a new fuser
8/2/2012 6:31:24 AM • Samsung ML-2150... • Answered on Aug 02, 2012
3answers
Error message w/Samsung ML 2150 Laser Printer - Engine LSU Error
Your Laser unit at the top section where the paper exit is faulty. You have no choice but to change it.
7/22/2011 11:32:53 PM • Samsung ML-2150... • Answered on Jul 22, 2011
My samsung 2150 duplex jam
The printer is telling you it is the wrong toner not an old toner this is either because it is the wrong toner or a fault with the printer has caused it to think its the wrong toner, try taking out the toner and putting it back in again, then try replace the toner with a new one. if this doesn't work the printer is probably got a broken component.
3/10/2011 3:17:18 PM • Samsung ML-2150... • Answered on Mar 10, 2011
HOW DO I CLEAR THE PAPER JAM 1? I opened all the
Did you check the fusing section from back door? When you open the rear door you can access the fusing unit (hotest place!!!). Sometimes the paper stacks below the stripping pawls of hot roller and you can't see it easy. Look harder! Pull out the whole paper tray and check below (printer bottom) for paper sheet. Lift upper cover and remove cartridge. You will see little green lever. Lift it up! Look for piece of paper around the little black pawl (paper sensor after registration roller). Restart printer!
Good luck
pifonski
3/3/2011 7:18:33 PM • Samsung ML-2150... • Answered on Mar 03, 2011
Appear duplex jam at display
Lubricate all gears and shafts inside the machine. There is an idle gear on the top back motor "where the paper comes out" the nylon it is made of shrinks causing the gear to seize on the shaft resulting in jamming. Super glue the fuser output rollers to their shaft. the rubbers on the output roller expand and slip when heated (usually after printing a large document) printing one page then resting/cooling down the problem doesnt occur. the idle roller on the duplex feeder also breaks off.
2/23/2011 2:22:27 PM • Samsung ML-2150... • Answered on Feb 23, 2011
2answers
The ml-2150 has a serial inferface option. In what
you are talking about the serial parallel cable, almost all the store that is selling computer, parts and accessories are selling these parallel cable for printers printer such as epson lx-300+ uses these kind of cable check your local store for stocks
2/21/2011 9:14:19 PM • Samsung ML-2150... • Answered on Feb 21, 2011
I have lost my CD
This is a link to the downloads page for your printer.
http://www.samsung.com/us/support/downloads/ML-2150
You may need the universal drivers and the management suite is under the software section.
Basically all you get on the cd is the driver, the manual and the management suite which are there.
1/24/2011 12:41:29 AM • Samsung ML-2150... • Answered on Jan 24, 2011
Samsung ML-2150 Laser Printer Logo
62 questions posted
Top Samsung Office Equipment & Supplies Experts
Gary
Gary
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
ML Samsung
  • ML Samsung
Most Popular Question
appear duplex jam display
  • Office Equipment & Supplies
