The option is backup take is external drive, how to take the Drive backup.
Go to Disk properties and select the tools and down 'Backup Now" option showing click that option.
Now the new windows will open. click the next and Choose the Backup file option and click "next" now choose the last option " Let me choose " Option and select the driver or document that you take the backup then click Next.
Now you have to give the path where you want to save that backup and give the name.
Then click Next and the backup process is start
When the backup is finish after that you have to format the drive. After formatting the driver you and install the New windows, again go to the D:/ properties and select the "Tools" and click the "backup Now" you get new windows click next the second windows show two option select the "Restore file " option and select the backup path that we take in external drive and click next now wait few minute you backup is restoring the file..
Open the start menu and right click on computer. then open the manage option, from there click on disk management and click on any of the areas that are not associated with drive C:/ and create a new partition.
INSERT THE OPERATING SYSTEM CD ...
NOW FROM BIOS SET YOUR SYSTEM TO BOOT FROM CD....
YOU HAVE TO ACCEPT THE LICENSE AGRREMENT IF IT COMES..
FIRST SCREEN WILL BE TO REPAIR THE OPERATING SYSTEM YOU CURRENTLY HAVE..PRESS ESC TO SKIP THIS
NOW YOU WILL BE TAKEN TO SCREEN WHICH ALLOW YOU TO MAKE NEW PARTITIONS AND TO FORMAT YOUR DRIVES...JUST FOLLOW ONSCREEN INSTRUCTIONS FROM HERE..GOODLUCK
open your cpu and change the sata wire to another sata slot in the mother board... there will be 4 sata sloy in *********** board... you can change it to any..
please go to the bios and change the hdd mode to inhance at present its in raid mode or can use the intel raid drivers by pressing the f6 while starting the system with the cd drive
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information.
User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access.
Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'.
Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you.
With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Sounds like the phone is on a contract with a different supplier.
Contact the original SIM supplier, EE, O2, Vodaphone etc and ask them to unblock the phone.
Question edited to add the further information.
Has to be in the manual? Did you pull the mains plug overnight?
That panel is called OSD (on screen display) and can be set to stay on for up to 200 seconds. Page 39 refers, and you can also reset it to factory defaults.
https://downloadcenter.samsung.com/content/UM/200803/20080329132905671_BN59-00716A-Eng.pdf
That sounds like a voice command problem for this Chicago, Illinois based channel. Refer to the station by its number on your subscription package, like "Alexa channel 1105 on tv".
https://www.google.com/search?q=wgn+-+tv
Samsunghttps://www.samsung.com > answer > ANS00087622
Amazon Alexa is now built-in on Samsung TVs and smart monitors! You can ask Alexa to change the channel, open apps, search for movies and shows, play music, ...
Tom's Guidehttps://www.tomsguide.com > How-to > TV
Apr 5, 2023 - Step 1: Set up your devices. First, make sure that both your Samsung TV and your Amazon Alexa device are set up and workings.
Can Alexa change TV channels? As long as you're using the TV's built-in tuner, you can use Alexa to change TV channels. Just say something like "Alexa, channel 7 on TV" or "Alexa, change channel to [channel name] on [TV name]."Nov 1, 2022
