20 Most Recent
Panasonic Viera Plasma TV TC-P60ST30 Questions & Answers
Try going into set up menu and look for a screen degauzing function or try setting the screen temp. to warmer or cooler.
Panasonic Viera...
Answered
on Aug 11, 2017
Fault to its main board.
Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Panasonic Viera...
Answered
on Nov 18, 2015
2708,2704,2700.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list
& set-up procedure to many popular brand remote controls.
Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Panasonic Viera...
Answered
on Aug 14, 2014
Try disconnecting all of your HDMI cables and plugging the power cord of the TV into another wall outlet. If this resolves the issue, you may have had a small power surge from either your wall outlet or one of your source devices. It is recommended to connect your TV to a surge protector if you haven't done so already.
Panasonic Viera...
Answered
on Oct 22, 2013
I had the same problem with my Viera. if you disconnect the power and ribbon cable from the YSUS board (check youtube for how), the light led will blink 6 times, indicating the YSUS is bad. Check ebay for TNPA5175 board (about $115-160). The pop is one of the DG402RP chips burnout. These are about $4, but only available from China. If you can wait a month for delivery, you can solder the new one to replace the bad one. You may want to purchase several in case more are bad or it happens again.
Panasonic VIERA...
Answered
on Apr 14, 2018
That probably won't work. You'll have that problem until you get a new TV.
Panasonic VIERA...
Answered
on Feb 13, 2018
I would say that's pretty much had it ,if there's smoke coming from the back something has burnt out
I would take it to a TV specialist to see if it can be repaired
Nick
Panasonic VIERA...
Answered
on Feb 03, 2018
Need service, your safety shutdown circuit is functioning properly.
Panasonic VIERA...
Answered
on Nov 23, 2017
I presume you are unable to activate the on screen menu after the picture goes, if you can then heat for setup or initial set up and factory reset and see if that clears the problem.
My guess would be it needs a service engineer to look at it there may be a faulty part which fails shortly after power up. If by Off it is just in standby then try pulling the plug out for an hour to let it cool down then if that works do a factory reset to clear any software problems.
Hope this helps.........
Panasonic VIERA...
Answered
on Jul 02, 2017
