20 Most Recent
Nikon 1 J1 Digital Camera Questions & Answers
Can I replace the latch or change the full internal chamber?
sir,
this part is available with Nikon agency, to replace this you have to open the whole camera, then detach the front portion, it doesn't matter, just a piece of rubber or sponge fix on the battery lid, this will be help full to hold the battery at contact perfectly.
No picture on the screen
Press the arrow button to see your images. When it starts up, it always goes straight to the record mode, not review mode.
Nikon 1 j1 will not start
sir,
power on, press menu, scroll to setting option, reset set up then go to shooting option push reset, all the system will be set to default.
No power and cracked display is it related?
Dale, If your charger starts flashing very fast, or no light is coming on at all, something is wrong. No light coming on, could mean it does not get any power. But it also could mean the battery has died.
If you have a multi meter, you could test what voltage the battery has. Most batteries are 3,7 or 7,2 volt. when you use a multimeter, the reading in DC should be something like 3,9 or 7,5. On the meter the outage should be a few percent higher than what is printed on the battery. As soon as the meter indicates a voltage just a little (or worse a lot) under the printed value, the battery must be replaced.
No powe
Most of the time it is the battery, or the battery contacts. Make sure, when you place the battery on the charger, the charger acts like the manual says. If the charger does not starts with a slow blinking light, something is wrong. If it does not give any light, check the power (cord and outlet) on the end of the charge, the light should burn continues.
When you are not sure the battery is good, try mother battery.
It also can be the contacts are not free or oxidised. Check the contacts on the battery and in the camera, if they are clean and shiny. Just a spec of dust, or a very small pice of paper on one of the contacts cab spoil all the fun. You could clean the contacts with a dry cloth, or a cotton swab. Never use anything sharp in or close to a camera.
After you replaced the battery, try again. If nothing (not even a new battery) works, contact a Nikon certified service centre. Or visit the dealer.
Why does nikon j1 clock reset each time the camera starts up
Yes, there is a separate battery for the clock and all of your saved settings that is not user replaceable. All Nikon 1 cameras are still in warranty because the camera only recently became available. I would phone Nikon USA's Service Department at (800) 645-6687 Monday through Friday from 7:00 a.m. to 8:00 p.m. and they will tell you how to proceed.
Lens error.
If you are using a lens that worked correct before, it could be one or more of the contacts are not working correct.
Remove the lens again. and try to clean the contact with a dry cloth. Both on the lens and in the camera. Check if all contacts are clean and shiny and not one has a dent. Use a magnifying glass.
careful replace the lens and hear and feel the click. Never use force to get the lens in place
If the lens is new, or never was on the camera before, could be the lens is not compatible or the lens is defect.
Pictures are white after taking a shot. But when I'm in indoors it's quite normal.
Way, Way Over exposed Gracey. Read the manual for the mystery Nikon Camera and set the camera to Automatic Exposure. Film 'Speed' is measured in ASA Rating, 200 ASA would be standard for outside, 400 ASA for lower light, up to 1200 ASA for very low light like candle light. The higher the ASA Rating, the more grain you will get in an image. In the old days, we used a light meter set to the actual film speed of the roll of film in the camera and the sensor in the light meter told you what to to set the lens aperture and shutter speed to. Now with digital cameras, it is all automatic, or you can choose to go with manual exposure.FULL 'make model (what it is)' in all questions please first 3 words.GoogleNikon (model) manualRead it it LEAST 3 times and at least once with the camera in your lap. Use the camera every day for a week and read it again...
I encounter a problem r07 using my Nikon D3100 with 18-55mm kits lens or my 55-200mm lens. How can I fix this? Thank you.
On Nikon cameras this isn't normally an error code. Have you got a memory card in the camera? Check that it isn't nearly full.
r07 common comes up as an information prompt referring to the memory space in the camera. '07' being 7 shots remaining.
If the card isn't full try this. Turn the camera off. Remove the battery. Remove the memory card. Leave it like that for at least 15 minutes. Connect the memory card to a computer or a laptop and check you can still look at and move the images that are on there. This is to check the memory card isn't corrupted (developed a fault).
