20 Most Recent Canon PIXMA MX410 - multifunction fax / copier / printer / scanner color Questions & Answers
look at the settings for the printer. Set the paper size to 8.5 x 10
Canon PIXMA... | Answered on Sep 25, 2014
Yes. Just connect it and let OS X download the software from Canon.com
Canon Office... | Answered Yesterday
The Canon B504 error code is built-in protection to prevent delicate resistors in the print head from overheating and self-destruct. The problem occurs when there is no ink flowing into the print head to keep it fresh, which can occur when a cartridge runs completely dry or no ink is flowing. What happens when you insert a new cartridge, is that the printer automatically looks to clean the standard printhead, but if it does not find ink present in the printhead, it is when it will report the dreaded Canon Error Code B504.
It typically occurs to printers who print head as printers get overheated and may experience self-destruction. This problem happens when there is no supply of ink to the print head to keep it dry. So it probably happens when the cartridge is fully dry or no ink is running into the cartridge.
So when you try to inject a new cartridge in it happens that the printer doesn't find any ink in the printhead, and that's when the b504 error is registered.
I Hope above solution fix your printer if not check given blog.
Canon Office... | Answered 2 days ago
https://support.shopperplus.com/en/support/solutions/articles/9000152206-b504-error-code-on-canon-printers-affects-canon-pgi-1200-and-pgi-2200-based-printers-
You can have error E350, E-350 or E350-001
E350 means there are faults on the serial number (SN) PCB. A check is made at power-on
Solution:
  • Turn off the machine's main power switch.
  • Replace the serial number PCB with a new one.
  • Assemble the parts.
  • Turn on the main power switch.
  • Once again, turns off and on the main power switch.
  • Verify that the readings of the soft counters have been continued.
Please share your feedback or any other question in this regard, I would be glad to assist you.
Canon Office... | Answered on Nov 29, 2020
My CANON printer was also not responding, I tried a lot to fix that but unable to fix. At last I got this linkhttp://www.printer-techsupport.com/Canon-printer-support.html I just visited and made a call on their toll free. I got instant help from a certified technician to fix my printer.
Canon Office... | Answered on Nov 27, 2020
Hola , curioso caso . El papel lo pones antes o despu?s de mandar a imprimir ?
Canon Office... | Answered on Nov 21, 2020
You also need the service tool. Both things are very difficult to find
Hi, maybe the cleaning blade of the transfer unit is defective
Code d'erreur Canon IR2420L E000100-0000 Comment r?soudre s'il vous pla?t
Il y a 4 minutes · Mat?riel et fournitures de bureau Canon · 0 r?ponse
YOU NEED THE PRINTER SOFTWARE ON THE SNDROID DEVICE
Canon Office... | Answered on Nov 18, 2020
Canon PIXMA MX410 - multifunction  fax / copier / printer / scanner   color Logo
19 questions posted
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
print pdf as whole page instead 1 4
  • Office Equipment & Supplies
