20 Most Recent HP Officejet Pro 8600 e-All-in-One - multifunction fax / copier / printer / scanner color Questions & Answers
No other way except to hinge it open and get a hold of the paper.
HP Officejet Pro... | Answered on Feb 04, 2019
Replace the depleted cartridge. It's out of ink.
Make sure that plug is in working order by plugging something else into it. If you need to get to the power unit inside the printer to test it, here's a video on how to get to power supply:
TRY UNPLUGGING IT FOR A MINUTE OR SO... AND TRY AGAIN.
Try this fix. It is an upgrade model from 8600, but the build is same and rollers are located in the same spots.
it is quite an undertaking for a novice to dismantle and remove pads and absorbers for cleaning and or replacing , but yes you should be able to, the ink is water soluble so with enough hot water you would be able to
HP Officejet Pro... | Answered on Nov 24, 2014
you will have to dismantle it somewhat ,easy to moderate difficulty
HP Officejet Pro... | Answered on Oct 10, 2014
In order to print on transparency film from a HP8600 all you have to do is load the paper rough side down with the white border going into the tray toward the back of the printer so that you can not see it when you look into the paper tray. The HP 8600 will auto-adjust for the film, that is why you do not have the option to select transparency like you did in the HP 8500
HP Officejet Pro... | Answered on Jan 31, 2014
If your printer's status displays "Printer in error state," there may be a problem with the printer itself. Make sure the printer is turned on and connected to your PC by Wi-Fi or cable. Check it for low paper or ink, and be sure the cover isn't open and the paper isn't jammed
HP Office... | Answered 14 hours ago
Usually, Error Code 0x07a74dd6 occurs when users try to start printing via connection to the computer. The Error Code 0x07a74dd6 could refer to anything from the product needing a basic reset to reinstalling the printhead or cartridges.
HP Office... | Answered 3 days ago
How to Completely Delete and Uninstall the HP Printer Deskjet Driver Software. HP printers ship with several printing applications and drivers.
https://www.cpprinter.com/how-to-remove-and-completely-uninstall-hp-printer-deskjet-driver-software/
First, be sure all four toner cartridges are seated properly as is the transfer belt. Close the front panel, then the top panel, power-cycle the printer and try again. If that doesn't solve the issue, it sounds as if either the actuator for the front door switch is broken off (which is highly unlikely) or the door switch itself is out of position. Getting to the switch involves removing most of the panels just to get to it; not impossible, just involved and a LOT of screws, plus a small black spacer for the top-left panel hinge. If you have any kind of a warranty or maintenance agreement on the printer, DO NOT TRY THIS, you WILL void it!! You have to unplug the printer, remove the fuser from up top, then the top panel, lower the front panel and remove the transfer belt and keep it out of the way in a dark area. Remove the hinged rear panel at the rear bottom followed by the rear panel (which fits inside a side panel, something to remember when reassembling). Now the side panel. If the switch is out of position, reposition it. If it's broken, it will need to be replaced. Reassembly is in the EXACT opposite of disassembly. You may wish to forego this and get an HP authorized tech in to do this for you. Worst Case Scenario: the DC Controller board is bad. But that's also unlikely ... possible, but unlikely. Let me know how it turns out!
HP Office... | Answered on May 24, 2020
go to start menu, choose printer & faxes, click the printer icon properties and find the printer resolution to adjust the dark printing capability
HP LASER PRINTERS 2, 2D, 3, 3D
1. Defective cable laser scanner to dc controller.
2. Defective laser scanner assembly.
HP LASER PRINTERS 2P, 2P+, 3P
1. Bad scanner motor.
2. bad dc controller.
HP LASER PRINTERS 3SI, 4SI, 4V
1. Faulty cable assembly.
2. Scanner motor problem.
3. Defective laser scanner assembly.
4. Defective dc controller.
HP LASER PRINTERS 4, 4+, 5
1. Faulty laser scanner cable.
HP LASER PRINTERS 4L, 4P, 5P, 5L, 5SI
1. Temporary error. Scanner startup failure.
2. Improperly fitted scanning assembly.
3. Scanner cable problem.
4. Defective laser scanner assembly.
5. Defective dc controller board.
HP LASER PRINTERS 1200, 2200, 3100 FAX, 3200 FAX, 4100
1. Temporary error. scanner rotation error.
2. Replace contact image sensor.
4. Replace laser scanner.
5. Replace cables to laser scanner and engine board
HP LASER PRINTERS 1100, 2100, 4000, 4050, 8000
1. Scanner start up error
2. Replace scanner cable to the D.C. controller and back to scanner. Or replace scanner cable from engine board to scanner ***'y.
3. Replace scanner ***'y.
4. Replace the engine board.
5. Replace the D.C. controller only on the 8000.
HP LASER PRINTER 2300 ERROR 52.X
1. A temporary scanner start up error.
2. This can also be the shutter tab on the print cartridge. Replace the toner cartridge.
3. Replace the scanner ***'y.
HP LASER PRINTERS 4200, 4300 ERROR 52.XX
1. Printer scanner speed error has occurred.
2. Replace laser scanner ***'y
3. Replace the D.C. controller ***'y
HP COLOR LASER PRINTER 4600, 5500 ERROR 52.XK, 52.XC, 52.XM, 52.XY
1. Error code K - No Black Color.
2. Error code C - No Cyan Color
3. Error code M - No Magenta color
4. Error code Y - No Yellow color
5. Replace laser scanner ***'y
6. Replace the D.C. controller ***'y
HP LASER PRINTERS 5000, 5100
4. Replace cable ***'y from scanner to D.C. controller.
HP LASER PRINTERS 8100, 8150
1.Laser scanner error/start up/rotation error
2.Replace laser scanner ***'y.
3.Replace D.C. controller board.
4.Replace cable ***'y from scanner to D.C. controller
HP LASER PRINTER 4500, 4550
1. Temporary error. Laser scanner error/start up/rotation error
2. Replace laser scanner.
3. Replace D.C. controller ***'y
HP COLOR LASER PRINTERS 4600, 5500
1.Laser scanner error/start up/rotation error.
2.Take the toners out and reseat them, or replace them
3. Replace laser scanner ***'y
4. Replace D.C controller board.
HP LASER PRINTER 8500, 8550
2. Replace laser scanner motor.
HP LASER PRINTER 9000
1. Temporary laser scanner error/start up/rotation error
3. Replace upper cable guide assembly.
4. Replace DC controller.
HP Officejet Pro 8600 e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
35 questions posted
Ekse
efs_perpends
efs_perpends
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
officejet 9600 vertical lines 4 in
  • Office Equipment & Supplies
