20 Most Recent Sole Fitness Sole F85 Treadmill Questions & Answers
If it was moved . Most likely the cable was damaged where the right upright bar slides into the frame. You will need to take the console off and remove the right upright , too access the cable. Unless you live in NC you could call, wilsons triad fitness 336-313-6253
Sole Fitness... | Answered on Dec 16, 2017
Dear Sir:
1) Lube the deck belt very well, as your instruction manual indicate for maintenance.
2) Try to Run software calibration after you fix it. For easy diagnose and troubleshooting.
3) The elevation motor can be faulty for lack of maintenance too, again Run the software calibration.
sincerely. God bless you
Sole Fitness... | Answered on Sep 19, 2017
If youre meaning that the buttons do not function this could be caused by sweat getting inside. Replace electronics inside or entire console.
Sole Fitness... | Answered on Jan 04, 2014
Your display pcb board needs replacement.....call sole for service
There may be two problems, however, I would suggest you replace the main display pcb. That will fix the fan problem. If the handle bar switches still do not function replaces the switch and wiring.
Sole Fitness... | Answered on Aug 12, 2013
The hand rail switch contacts can be worn out. The more likely problem is a broken wire by the arm. Remove the cosmetic covers by the hand rails and check for broken wire. If wires are not broken replace the switch.
Sole Fitness Sole F85 Treadmill Logo
25 questions posted
Top Sole Fitness Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Sole Fitness Exercise & Fitness
Most Popular Question
sole f85 treadmill stopping after
  • Exercise & Fitness
