20 Most Recent Precor 9.35 Premium Series Treadmill Questions & Answers
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to
change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Precor 9.35... | Answered on Nov 05, 2014
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
This link will take you to the parts available for these models. Because most machines are serial number specific, you will need to narrow your search based on your particular model and serial number.
Precor Repair Parts for 9 35 9 35i Treadmills Consumer SPORTSMITH net
Turn off you machine always, also disconnect the treadmill remove the cover and clean the motor fan and the motor with air cans.
Precor 9.35... | Answered on Dec 23, 2013
this is the answer:
Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis.
God bless you
Precor 9.35... | Answered on Sep 18, 2013
please see the details and proceed according. God bless you
Precor 9.35... | Answered on Mar 18, 2013
It might be the battery. A fully charged battery is required to move the ramp up and down. The battery is like a car battery, if you don't use it then it dies and might need to be replaced.
Precor Exercise... | Answered on May 15, 2020
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
https://www.sportsrec.com/reset-error-code-precor-treadmill-5519820.html
https://www.youtube.com/watch?v=_yD5eoMNB64
Precor Exercise... | Answered on May 09, 2020
https://www.precor.com/en/efx®-546i-elliptical-fitness-crosstrainer™
use of:
https://www.youtube.com/watch?v=YRFJNFIHAHY
Precor Exercise... | Answered on Apr 25, 2020
https://www.youtube.com/watch?v=M3u-jvWGTs8
Precor Exercise... | Answered on Mar 24, 2020
Precor 9.35 Premium Series Treadmill Logo
9 questions posted
Top Precor Exercise & Fitness Experts
NOEL
NOEL
Ngoro
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Precor Exercise & Fitness
Most Popular Question
stuck key
  • Exercise & Fitness
