20 Most Recent Precor Treadmill 9.21 9.21s 9.25 9.21si 9.25 Replacement Motor Hood Cover Questions & Answers
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Damaged speed sensor target.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Precor Treadmill... | Answered on Aug 13, 2014
Precor Error Code 22 Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Precor Treadmill... | Answered on Jul 08, 2014
This really sounds like the results of long term use without lubrication or wax between the belt and deck. Chances are you will need to replace the running belt and the deck or flip the deck if it has not already been done. The friction builds up between the deck and belt and caused the electronic components to overheat. The machine is shutting down as a precautionary measure. It will do this only so many times before the electronics are zapped. Start with the deck and belt. Hopefully the electronics are okay. With your model and serial number, you can visit our website and view the products we have available for your particular machine.
Precor Repair Parts for 9 21s 9 21si Treadmills Consumer SPORTSMITH net
Precor Treadmill... | Answered on Jun 30, 2014
please read your owner manual. Diwnload freewww.fitnessmanualsonline.comGod bless you
Precor Treadmill... | Answered on Mar 16, 2013
It might be the battery. A fully charged battery is required to move the ramp up and down. The battery is like a car battery, if you don't use it then it dies and might need to be replaced.
Precor Exercise... | Answered on May 15, 2020
To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
https://www.sportsrec.com/reset-error-code-precor-treadmill-5519820.html
https://www.youtube.com/watch?v=_yD5eoMNB64
Precor Exercise... | Answered on May 09, 2020
https://www.precor.com/en/efx®-546i-elliptical-fitness-crosstrainer™
use of:
https://www.youtube.com/watch?v=YRFJNFIHAHY
Precor Exercise... | Answered on Apr 25, 2020
https://www.youtube.com/watch?v=M3u-jvWGTs8
Precor Exercise... | Answered on Mar 24, 2020
FIXYA DOES NOT SELL ANY PRODUCTS OR PARTS FOR ANY
Precor Exercise... | Answered on Jan 19, 2020
Contact Precor directly to inquire.
Precor Exercise... | Answered on Oct 28, 2019
Precor Treadmill 9.21 9.21s 9.25 9.21si 9.25 Replacement Motor Hood Cover Logo
7 questions posted
Top Precor Exercise & Fitness Experts
NOEL
NOEL
daf62757
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Precor Exercise & Fitness
Most Popular Question
precor treadmill 9 21si error code 26
  • Exercise & Fitness
