20 Most Recent Toshiba E-studio 167 B & W Copier. Print/fax/scan Questions & Answers
Hi
The error means that the thermistor or heater abnormality at power-ON.
i think you should contact the provider.
Error Codes Toshiba Studio 167 Code C41
Toshiba E-studio... | Answered on May 23, 2016
HS-75 file system recovery mode -recovery F/S -imagedata, and then restart the equipment.
Toshiba Office... | Answered on Jan 11, 2021
You can't. It is made that way. You can reprogram the chip if you can find the machine and the software to do it. Everything is done to make you use OEM original toner cartridges, which are better quality, more reliable and made especially for your machine.
Toshiba Office... | Answered on Jan 07, 2021
Contact Toshiba directly to inquire.
Toshiba Office... | Answered on Jan 05, 2021
Hi Tim, I know your post is a year old but I'm hoping my massage reaches you. Can you please email the firmware update for studio 282 as well? Thank you [email protected]
Toshiba Office... | Answered on Dec 12, 2020
Image quality control test pattern abnormality: The test pattern
is not formed normally.
1. Turn the power of the equipment OFF and check the
connection of the HDD.
- Connector and harness check
- Check if the connector pins of the HDD are bent.
- Check if HDD for other equipment is not installed.
- Check if SRAM for other equipment is not installed.
2. If the error still occurs after step 1, perform the following.
- HS-75 File System Recovery mode ? Recovery F/S ? /
- Perform FS-FAX ? 11 FAX CLEAR MODE ? [CUSTOM
INITIALZE] ? [CLEAR DATA], and then restart the
equipment.
3. If the error persists after step 2, perform the following.
- Perform HS-73 Firmware Assist mode ? Format HDD, and
then install "System Software (HD data)" with HS-49
Firmware Update mode.
Notes:
The following items will be deleted by performing HS-73
Firmware Assist mode ? Format HDD.
• Message Log
• Job Log
• Spool Data (Print, Email reception)
• Template
4. If the error persists even after step 3, perform the following and
then reattempt step 3.
- HS-74 HDD Assist mode ? Revert Factory Initial Status
HDD.
5. If the error persists even after step 4, replace the HDD.
6. If the error persists even after step 5, replace the HDD
harness.
7. If the error persists even after step 6, replace the SYS board.
color copiers....yes.
you have to use glossy paper 200g or more.
High-voltage transformer abnormality:
Leakage of the main charger is detected.
Turn the power ON while pressing both the [0] and [8] keys.
• Press the [START] key after inputting [4541] with digital keys.
• Change the status counter "1", "2" or "3" to "0" and press the [OK] or [INTERRUPT] key ([CD4]
released
Toshiba Office... | Answered on Dec 05, 2020
check with toshiba
Toshiba Office... | Answered on Dec 03, 2020
[F110] Communication error between system CPU and scanner CPU
[F111] Scanner response abnormality
(1) Check if the harness connecting the SYS board and SLG board is disconnected or open circuited.
(2) Check the version of the system ROM on the SYS board.
(3) Check the version of the scanner ROM version on the SLG board.
(4) Replace the SYS board.
(5) Replace the SLG board.
Toshiba Office... | Answered on Dec 02, 2020
Toshiba E-studio 167 B & W Copier. Print/fax/scan Logo
7 questions posted
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Office Equipment & Supplies
Most Popular Question
atoshiba e studio 167 machine wich shows
  • Office Equipment & Supplies
