20 Most Recent
Precor EFX 5.25 Elliptical Fitness Crosstrainer Questions & Answers
EFX 5.25. Erro code 30. I had mice chew up the wiring between the two circuit boards. I have replaced the lower board and the wiring harness. Still shows error code 30
Precor Error 30, 31, 32 and 33, Communications Error
Probable Cause
1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
- Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
- Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
- Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
- If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
- Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
- Test unit with a known good lower PCA. Replace the lower PCA if necessary.
- Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
My precor 100I AMT elliptical keeps resetting when you slow down. Anybody know what's causing this?
Check RPM Feedback:
The most common cause for the timer to stop after 7 seconds on a Precor elliptical is NO RPM feedback.
Start by checking the connection of the speed sensor to the lower board. If necessary, reset the connection.
Also, inspect the magnet located on the user's right crank arm (versions 1 and 2) or the user's left crank arm (version 3). The magnet passes the speed sensor with each revolution of the crank arm.
Ensure that the magnet is installed correctly, with its south pole facing the speed sensor. You can verify the magnet polarity using another magnet or a compass.
Speed Sensor Spacing:
Confirm that the spacing between the speed sensor and the magnet is within the range of 1/8" to 1/4". Adjust if necessary.
Battery and Power:
If your elliptical has a battery, check its status. A low battery could cause issues.
Consider using the optional power adapter kit to ensure consistent power supply.
Error Codes and Clearing Logs:
Check for any error codes displayed on the console.
Clear the error codes and power down the unit.
Inspect cable connections to ensure they are fully seated.
Power on the unit and monitor the error code log for any reoccurrence.
Professional Assistance:
If the issue persists, consider reaching out to professional repair services or contacting Precor support for further assistance.
Precor EFX 556 cross trainer slow startup
Il existe deux raisons pour lesquelles votre v?lo elliptique Precor EFX 556 d?marre lentement. Tout d'abord, un probl?me ?lectrique, tel qu'un cordon d'alimentation mal branch? ou endommag?, ou m?me une prise d?fectueuse, pourrait survivre. Un condensateur d?fectueux ? l'int?rieur de l'appareil, qui peut causer des retards au moment de la mise sous tension, est une autre explication. Pour r?soudre ces probl?mes, commencez par v?rifier les connexions ?lectriques. Envisagez d'appeler un technicien qualifi? pour diagnostiquer et r?soudre un probl?me ?lectrique ou ?lectronique si le probl?me persiste.
My precor efx556 does not detect pedaling, how can i fix it?
hello there, check if the lift control system is detected the lift is moving in the opposite direction of the issued lift command. This error would happen when the lift was already in motion (typically downward) when a lift command in the opposite direction (lift upward) was issued.
What causes a slow boot up on a Precor EFX 546?
A slow boot up on a Precor EFX 546 elliptical machine can be caused by several factors, including:
- Low battery voltage: If the battery voltage is low, the machine may take longer to boot up. This can be due to a weak or old battery, or a problem with the battery charger.
- Dirty or corroded contacts: Dirt, dust, or corrosion on the battery contacts or other electrical contacts can interfere with the machine's ability to start up quickly.
- Faulty console or display board: If the console or display board is malfunctioning, it may take longer for the machine to boot up or may not boot up at all.
- Loose or damaged cables or connections: Loose or damaged cables or connections can prevent the machine from starting up properly and may cause a slow boot up.
- Outdated software: If the software on the machine is outdated, it may take longer for the machine to boot up or it may not start up at all.
To troubleshoot a slow boot up on a Precor EFX 546, you can try the following steps:
- Check the battery voltage and replace the battery if necessary.
- Clean the contacts on the battery and other electrical components.
- Inspect the cables and connections for damage or looseness.
- Check for any error codes or messages on the console or display board and consult the user manual for troubleshooting steps.
- Check for any available software updates and install them if necessary.
If none of these steps resolve the issue, you may need to contact a professional technician for further assistance.
Precor 556i / AXGE....Problema with the resistance. Can anybody help me?
Hey Fabian, it's possible that the resistance motor or sensors on your wife's Precor 556i/AXGE may need to be recalibrated. Try powering off the machine, unplugging it for a minute, and then plugging it back in to see if that resets the calibration. If the problem persists, you can try recalibrating the machine manually. There should be instructions in the user manual or online. If that doesn't work, then contacting customer service or a certified technician may be necessary. I hope this helps!
Precor 9.45 reset safety switch message wont go away
If you have checked the safety switch on your Precor 9.45 treadmill and everything seems to be intact, and the "reset safety switch" message still won't go away, it's possible that the switch itself is faulty or the console is not receiving the signal from the switch.
You can try cleaning the switch and the area around it, and also check the wires that connect the switch to the console to make sure they are not damaged. If the switch or wires appear to be damaged, they may need to be replaced.
If cleaning and checking the switch and wires doesn't resolve the issue, it's recommended that you contact the manufacturer or a qualified repair technician to further diagnose and fix the problem. They may be able to provide additional troubleshooting steps or suggest other possible solutions.
Precor treadmill making squeaking noise when running fast
Two likely candidates: Belt or tread. Lubricating the tread would be the easiest starting point; but if you're running at 7 or more you've probably already thought of that.
If the cover isn't too difficult to remove, you can expose the drive belt and the squeaking volume change would be an indicator that the drive belt is the problem.
