20 Most Recent
Nikon Coolpix S9100 S-9100 26248 Black Hd Digital Camera 16gb Kit Questions & Answers
I have a S9100 Coolpix camera and all pictures have been erased. Is there any way I can retrieve them?
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
- Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
- Simple to use interface - just click 'Scan' and choose the files you want to recover
- Easy to use filter for results based on file name/type
- Simple Windows like interface with List and Tree view
- Can be run from a USB thumb drive
- Restores all types of files, office documents, images, video, music, email, anything.
- Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
- Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
- Restores files from external ZIP drives, Firewire and USB Hard drives
- It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva
http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
How to transfer internal memory pictures to computor
You have two options:1) Remove your memory card from the camera, if you have one. Then connect the camera to your computer using the supplied USB cable.2) Use the "Copy" command in the Playback menu to copy the pictures from the internal memory and then download the pictures from the memory card. Once the card is plugged into a card reader attached to your computer, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer.If you need a manual, you may download a copy
from here.
from here.
Night Photography NIKON digital cam.
Wait until the sun goes down.
In many ways night photography is just like day photography, except there's less light. With less light, you need a slower shutter speed, a wider aperture, a faster ISO, or a combination of all three. Or else you need to add light.
Just like day photography, the best camera settings (and other things) depend on what you want the photograph to say to the viewer.
You can add light by using the flash, car headlights, etc. The flash doesn't have much range; if you're sitting in the stands at a night sporting event your flash isn't going to affect any pictures you take of the action on the field. Another effect of the short range is that if you take a flash picture of a person at night, you're likely to have an almost completely black background. If you want something of the background to show, use the Night Portrait mode (and a tripod).
If you want to take a picture of a night landscape (or the night sky, with star trails) then turn off the flash. Put the camera on a tripod or other steady support and use a slow shutter speed.
If you're taking a picture of the full moon, then it's not night photography at all. The full moon is just a big rock under a midday sun, so treat it as such.
Just bought Nikon p600 and cant connect to WiFi help
U need to download nikon wmu software from google playstore or appstore. Then start wifi of ur camera and then start wifi connection in ur mobile.select "nikon p600" in wifi setup.when connected, start application named "wmu" in ur mobile.wait for the connection.after few seconds wifi connection will be established.hope this would help u!
My Nikon b500 Coolpix won't turn on just flashes green
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
