20 Most Recent Life Fitness Crosstrainer, 9100, 9500 Rear Drive Gk61-00002-0045 Questions & Answers
tip
95Xi Crosstrainer Crank Arm Cover Replacement
About This Video
Crank Arm Cover Removal and Replacement Video for the 95Xi LifeFitness Crosstrainer
  • This video demonstrates how to remove and replace a Crank Arm Cover on a Life Fitness 95Xi Crosstrainer elliptical
Necessary Tools:
  • Philips Screwdriver
  • 5/32" Allen Wrench
  • 2MM Allen Wrench
  • T25 Driver
  • T50 Driver
  1. Remove the main shrouds as seen in the shroud replacement video
  2. Remove the outer link cover as seen in the outer link cover removal video
  3. Remove the pedal lever assembly (as seen in Sportsmith's Pedal Lever Replacement video) on the side where the crank arm cover replacement is needed
  4. Remove the two bolts holding the crank arm cover in place, and remove the crank arm cover
  5. Replace the parts in reverse order
LifeFitness 95Xi Crank Arm Cover Video Removal and Replacement
tip
95Xi Crosstrainer Shroud Replacement
Video Presentation of Replacing the Main Shroud on a LifeFitness 95Xi Crosstrainer
  • The video shows the steps involved in replacement of the main shroud on a LifeFitness 95Xi
  • Tools:
    • Phillips Screwdriver
  • Remove the (4) screws securing the main shroud to the drive frame assembly
    • There are two screws on each side
  • Lift straight up on the shroud to remove it
  • Install the main shroud in reverse order
    • Making sure the main shroud fits into the grooves of the lower shroud panels
Repair Video for LifeFitness 95Xi Crosstrainer Shroud Replacement
tip
95Xi Crosstrainer Drive Belt Replacement
Drive Belt Replacement Video for LifeFitness 95Xi Crosstrainer EllipticalTools needed:
  • T25 Driver
  • T50 Driver
  • 2MM Allen Wrench
  1. Remove the main shrouds as seen in the main shroud removal video
  2. Remove the left outer link cover as seen in the Outer Link Cover removal video
  3. Remove the left pedal lever assembly as seen in Sportsmith's Pedal Lever replacement video
  5. Walk the drive belt off the pulley and remove it from the unit
  6. Install the new belt around the crossover shaft first and then walk it onto the pulley
  7. Replace the remaining parts in reverse order
LifeFitness 95Xi Drive Belt Video How To Replace
Life fitness crosstrainer 9500 HR just shut down few second after start
see the video and fix it. This happen because the lack of maintenance schedule.God bless you
4/4/2013 3:21:29 PM • Life Fitness... • Answered on Apr 04, 2013
My treadmill LIFE FITNESS T3 blocked and the console display the following message : ERR 6 / ERR KEY BLOCKED. Turn ON /OFF. Does not fix the problem. What does it mean and how to proceed? Thank you.
How do I fix error 6 on my treadmill? E6 Error: Controller malfunction. Resolution: Ensure that the cables connecting the console and the controller are secure. If any of the cables/connectors appear loose, completely power off and unplug the treadmill before unplugging and reattaching the cables.Sep 23, 2021
E6 Error Code: Control Board Malfunction - Spirit Fitness Support
https://www.google.com/search?q=LIFE+FITNESS+T3+ERROR ..
1/28/2024 11:47:14 PM • Life Fitness... • Answered on Jan 28, 2024
Incline Error Life Fitness TR9100HR
1/4/2024 2:03:40 PM • Life Fitness... • Answered on Jan 04, 2024
Life fitness t7-o shows "communication timeout" error when adding resistance to the belt.
Try to lubricate the belt and then use it. It seems the control temperature is getting above normal due to load
10/13/2023 5:26:13 PM • Life Fitness... • Answered on Oct 13, 2023
2answers
Motor disabled error on life fitness treadmill after 1min On 95ti model
check wiring and sensor
7/28/2023 8:56:41 AM • Life Fitness... • Answered on Jul 28, 2023
Life Fitness Club Series+ treadmill, miles to kilometers?
Hi Yuri, Hope so you're doing well, the distance unit from miles to kilometers on the Life Fitness Club Series+ treadmill, there are a few steps you can try before contacting Life Fitness support:
  1. Warm reset: Press the CLEAR key twice, and then hold down the ENTER key. The treadmill should perform a "warm" reset and beep three times, indicating that the USER MENU has been activated. After the reset, check if you can access the distance unit setting.
  2. Manual access: Alternatively, you can try holding down the ENTER key while turning on the treadmill. The message "USER MENU" should appear, and after a second, the MESSAGE CENTER will display the first menu item. Navigate through the menu options using the appropriate keys until you find the distance unit setting.
Hope so this will work for you! Regards, Bryce June
6/3/2023 7:54:26 PM • Life Fitness... • Answered on Jun 03, 2023
Lifefitness se3 hang up how can i fix it ?
Sure, here are some steps you can try to fix the issue with your Lifefitness SE3 console:
  1. Perform a system diagnosis: The Lifefitness SE3 console has a built-in diagnostic tool that can help you identify any hardware or software issues. To access this tool, press and hold the 'Home' and 'Volume Up' buttons for 5 seconds. Then select 'System Diagnostics' from the menu and follow the prompts to perform the diagnosis.
  2. Check the system logs: The Lifefitness SE3 console logs all system events, which can help you identify the cause of the hang-up. To access the logs, go to the settings menu and select 'System Logs'. Look for any errors or warnings that may indicate a problem.
  3. Update the BIOS: The Lifefitness SE3 console has a BIOS (basic input/output system) that controls the hardware and software interactions. Updating the BIOS can sometimes fix issues with the console. To update the BIOS, download the latest BIOS firmware from the Lifefitness website and follow the instructions provided.
  4. Check the storage device: The Lifefitness SE3 console uses an embedded storage device to store data and software. If this storage device is faulty, it can cause the console to hang-up. To check the storage device, go to the settings menu and select 'Storage'. Look for any errors or warnings that may indicate a problem.
  5. Reinstall the operating system: If none of the above steps work, you may need to reinstall the operating system on the console. To do this, download the latest operating system firmware from the Lifefitness website and follow the instructions provided.
3/22/2023 8:57:51 PM • Life Fitness... • Answered on Mar 22, 2023
How can I turn down beeping on Life Fitness 95xi elliptical? My wife pedals slowly on it and it's constantly restarting and beeping and beeping and beeping.
To turn down or turn off the beeping on your Life Fitness 95xi elliptical, follow these steps:
  1. Locate the control panel: The control panel is usually located near the handlebars or on the console of the elliptical.
  2. Find the sound or beep settings: Look for a sound or beep option in the settings menu.
  3. Adjust the volume or turn off the beeping: Use the up and down buttons to adjust the volume of the beep, or turn off the beep completely.
  4. Save the changes: Once you have made the necessary adjustments, be sure to save the changes by pressing the "Save" or "Enter" button.
If you are unable to find the sound or beep settings, consult the owner's manual or contact the manufacturer for assistance. Keep in mind that some beeps are important safety warnings, and disabling them could be dangerous.
2/6/2023 12:48:56 AM • Life Fitness... • Answered on Feb 06, 2023
Life FItness elliptical model X7 has too much resistance on startup. Prevents use for warming up.
It sounds like the resistance on your Life Fitness X7 elliptical is set too high for the machine to be used effectively as a warm-up tool. There are a few things you can try to adjust the resistance on the machine.
  • Check the user manual that came with the elliptical to see if there are any specific instructions for adjusting the resistance.
  • Check the resistance settings on the dashboard to ensure that they are set to the correct level.
  • Check the resistance adjustment knob or lever to ensure that it is not stuck or jammed in place.
  • Check the belt tension on the elliptical to ensure that it is not too tight.
  • Check to ensure that there is no debris or dust in the resistance mechanism.
  • If the issue still persists after trying the above steps, it may be best to contact Life Fitness technical support or consult a technician for further assistance.
It is also a good idea to inspect the machine overall for any damage or wear. If all else fails, the used elliptical may have a defect or may not be compatible with your needs. You may need to consider purchasing a new one or a different model for your clients warm-up needs.
1/14/2023 10:34:22 PM • Life Fitness... • Answered on Jan 14, 2023
I have a Life Fitness 95x elliptical and at low speed the resistance gets very hard briefly and then frees up
Hi, The resistance might be caused by internal gears are probably switching when you initially slow down. It's the same as when you're decelerating in a car prior to accelerating and the car has resistance when you're going at a speed just before the car gears shift. Thank you.
12/29/2022 12:43:29 AM • Life Fitness... • Answered on Dec 29, 2022
Help identifying transistor on wax lift board for LifeFitness 9500HR treadmill A080-92182-H000
The link for the photos is not working. You may be able to view the numbers on the device using a polarized light or filter. Some are laser etched and hard to see if normal light.
3/5/2022 11:25:44 PM • Life Fitness... • Answered on Mar 05, 2022
Life Fitness Crosstrainer, 9100, 9500 Rear Drive Gk61-00002-0045 Logo
7 questions posted
Top Life Fitness Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Mike Cairns
Mike Cairns
Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Life Fitness Exercise & Fitness
Most Popular Question
life fitness crosstrainer 9500 hr just
  • Exercise & Fitness
