20 Most Recent Nikon Coolpix L24 Silver Digital Camera 8gb Kit Questions & Answers
3answers
How do I put pictures on a dvd from nikon coolpix L24
First you need to copy the photos to your computer that has a DVD burner. Then you open the DVD burn program and select the photos to burn onto the DVD disc.
7/18/2019 3:31:36 AM • Nikon Coolpix... • Answered on Jul 18, 2019
Battery door replacement on L24
These battery doors need delicate handling. These can be ordered on ebay and replaceable by user.
4/28/2016 6:08:26 PM • Nikon Coolpix... • Answered on Apr 28, 2016
Nikon Coolpix L24 camera. It doesn't take
Check that your digital camera is not in playback or review mode. Make sure the memory card is in the camera and that the card is properly formatted. The Memory Card may be full. Download the images to the computer or delete some to make way for new photos. Check the charge on the batteries. Replace if necessary.Have you been using the flash? It may be recharging. When it is recharged, the camera will be ready to take photos again.
8/22/2013 7:17:19 AM • Nikon Coolpix... • Answered on Aug 22, 2013
Nikon CoolPix B500 when I turn the camera on it tells me to turn camera off and then on again.
contact NIKON perhaps they can repair it we can not
8/3/2021 7:27:05 AM • Nikon COOLPIX... • Answered on Aug 03, 2021
2answers
Just purchased NIKON COOLPIX B500. I put in brand new Sandisk SD memory card And as soon as I shut the battery case the monitor says “this card cannot be used!” What’s up with that?
At the Time the Camera was made , Nikon lists a number of compatible memory cards. Each year both cameras and cards can read and write data faster. Cheap cards today can be read much faster than written. If any camera can take many photos in a short time, a slow cad will not allow the camera to operate as intended.
2/1/2021 1:38:30 AM • Nikon COOLPIX... • Answered on Feb 01, 2021
Single-shot on coolpix P900
I cant understand your question,please explain your problem clearly
1/8/2020 6:47:35 PM • Nikon COOLPIX... • Answered on Jan 08, 2020
The flash on my coolpix 6500 is not working. I pressed ok on the image mode for flash, but it still shows a line through the flash icon.
Some Modes, Like FIREWORK will not allow Flash. Check your MODE
11/6/2019 5:10:11 PM • Nikon COOLPIX... • Answered on Nov 06, 2019
SanDisk 64 GB SD card is too big for my Nikon COOLPIX S62000
Go to Nikon.com and search for your camera and then look for Memory cards that are compatible
10/16/2019 8:18:30 PM • Nikon COOLPIX... • Answered on Oct 16, 2019
My Nikon b500 Coolpix won't turn on just flashes green
It flashes green when it is basically on but in a sub mode that I'll call CHARGE MODE. If it is flashing that means the battery is charging. I suggest to let it continue to charge until it stops flashing and then remove the charger connection. When the camera is sitting all by itself with nothing connected you can then turn it on.
9/24/2019 1:52:47 PM • Nikon COOLPIX... • Answered on Sep 24, 2019
The screen on my Coolpix 500 looks like a chemical was poured on it. It is not scratched, what can I do
Is it the screen, or the screen protector ? If the latter, just remove it and replace it. If it is the actual screen, first of all try a lint-free cloth barely dampened with distilled water, and test it on a corner, see if that works. On no account get the camera wet. If that is unsuccessful, try adding a very little diluted washing-up liquid, and try again. Should that not succeed, I would advise taking the camera to your local repair facility for their expert advice.
8/24/2019 1:27:47 PM • Nikon COOLPIX... • Answered on Aug 24, 2019
Changing view on playback on Nikon p610
Not sure exactly what the issue is here - could you be more specific please ? Thank you.
2/20/2019 10:19:43 AM • Nikon COOLPIX... • Answered on Feb 20, 2019
Firmware update coopix s5100
I would suggest you go to the Nikon support site and see if there is a version you can download from there.
2/20/2019 10:18:21 AM • Nikon COOLPIX... • Answered on Feb 20, 2019
MY NIKON COOLPIX S 3000 DIGITAL CAMERA WONT DO ANYTHING AT ALL
Hi Here are some suggestions to try and see where the problem may be: 1. Have you tried to charge the battery? We would suggest trying different USB sources (e.g. a USB port on a computer as well as the Nikon supplied AC adapter) 2. Could the battery be dead? If you have tried to charge the battery in the camera via USB then there is a chance the battery is dead and needs replacing. If the camera had not been used for a long time and the battery was stored with little or no charge, the battery may now be un-chargeable. 3. If the camera has been left unused for a long time the internal battery that keeps the time/date may have discharged. You need to be able to set the time/date before the battery can be charged. If you plug the camera into a USB power source and you can see the menu on the LCD then set the date/time. We hope these suggestions help to get the camera back up and running
1/24/2019 9:36:19 AM • Nikon COOLPIX... • Answered on Jan 24, 2019
My nikon Coolpix L340 says: Out of memory! The memory card has 32GB and I have taken some 9000 pictures. Do I have to buy another memory card?
You have two main choices. Yes, you could buy a new memory card. But I find the extra small cards can be easily lost or misplaced. A better method is to transfer the images from the camera to a computer or laptop. It is also possible to transfer the photos through the computer or laptop onto an external hard drive with a much larger memory as a back up. Then you can re-use the card you already have.
1/12/2019 8:10:15 PM • Nikon COOLPIX... • Answered on Jan 12, 2019
Why won't my nikon coolpix s8000 camera flash pop up or register that it is up?
Do you have "Flash off" selected in menu? Also, if in manual modes, will not come up automatically. Try auto.
6/15/2018 5:14:41 AM • Nikon COOLPIX... • Answered on Jun 15, 2018
Nikon Coolpix L24 Silver Digital Camera 8gb Kit Logo
4 questions posted
Top Nikon Cameras Experts
Ekse
Steven Wander
Steven Wander
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
COOLPIX Nikon
  • COOLPIX Nikon
Most Popular Question
put pictures dvd from nikon coolpix l24
  • Cameras
