20 Most Recent Proform Walking Belt For The Crosstrainer Treadmill. Model Pftl50072 Questions & Answers
Dear Sir:
Adjust the speed sensor very weel see the diagram attached, tigh the connector wires very well, and clean the s. sensor very well.
2) Run the software calibration for easy diagnose , fix it, and trouble.according with your manual instructions.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua.
Proform Exercise... | Answered on Jul 13, 2020
INTERMITTENT FAILURE IS ALWAYS A PROBLEM TO YOU AND ANY ONE ASKED ABOUT IT . WAIT TILL IT WILL NOT RESTART SORRY
Proform Exercise... | Answered on Mar 07, 2020
It’s the lower control board or speed sensor.
Not familiar with the model, but sounds like a board if it does not produce any error codes or is resolved by powering down.
Typically a dirty speed sensor will shut a machine down, because the speed the board and the sensor are not reading the same. Although this will often produce an error code, to be investigated.
Proform Exercise... | Answered on Feb 04, 2020
Verify the safety key is present and functioning. Most machines use a magnet and any strong magnet will be enough to close the circuit.
Most treadmills meet there demise from a faulty lower control board under the hood. It can light and be mostly functional, but still have issues. Boards are not very cheap but are very easy to install.
Search for options on fitnessrepairparts.com.
Make sure to take an image of the original board to copy the wire location/connections.
Boards often go bad from an array of issues, but verify the condition of the underside of the walking belt is not black and the deck is not worn. Lack of lubricant and too much friction on the belt system usually overloads the board with heat and damages the board.
Proform Exercise... | Answered on Jan 13, 2020
Front page of the manual has a contact for the manufacturer.
Warranty is on the back page.
Elliptical consoles come as completes, no harder to install then the original assembly
Proform Exercise... | Answered on Jan 10, 2020
Most likely worn belt and deck, demise of almost every treadmill or the source of a blown lower control board.
Lube is usually every 150 mi or 6 months. Consumers rarely apply lube until its too late.
Putting lube on it does not resolve the damage to the deck. Look under the belt and see if the bottom of the belt is white. When a machine is run out/low on lube the bottom of the belt turns grey/black and the slippery board the lube is supposed help the belt run on gets rough.
Parts aren’t bad, couple hundred bucks. Shipping is brutal because the deck is a 40lbs 2’ x 4’ sheet of laminated wood. You would need to dismantle the machine down to the frame to install the deck or even the belt.
Could be way simpler, but start with the condition under the belt and the sliding deck.
Verify the wire harness to the console has continuity with a multimeter.
Very common for the harness to be damaged if disassembled and reassembled during a move.
Otherwise you would need to source a wiring diagram from mfg to see what the readings should be at the console connection.
If that all checks out then it most likely is the upper control board.
Just because the lower board is getting power doesn’t indicate it is functioning
It is either the resistance motor or the cable/activating arm is struggling.
The resistance is so high because the magnets that create the distance are very close to the steel flywheel.
You will want to open the machine up to view this area. The resistance motor and fly wheel are in very close proximity to each other.
To decrease the resistance the motor is activating a hinge to move the magnets further away from the flywheel. The magnets are typically behind a plastic cover inside the flywheel and will not be able to access them.
Open the machine up and investigate. The system is very basic and playing with it will give some insight.
Try YouTube channel: fitness repair help. Won’t be your exact machine in the video, but it will give great impression
Many times the console is not recognizing the safety key with this type of response.
Otherwise it is your upper control board or lower control board, most likely lower.
Double check the safety key
Most likely lower control board.
This is the circuit board under the plastic hood. Controls the elevation motor.
Unless the console has a stuck or faulty elevation button, then the console is not sending an incline signal.
When a board goes bad the machine will respond with erratic strategies, elevation on max is one example.
When the board is “bad”, it can also not tell it is out of control and won’t throw a code or signal to stop.
Boards are just plug and play, very easy to install. Take an image before removing the old board and you should be able to duplicate the harnesses.
Fitnessrepairparts.com is where I buy my parts when I don’t have an account with a specific company
Owners manual will outline the procedure in back of pamphlet.
Utilize the supplied hex key or source the correct hex for the rear roller. Access the tensioning bolts for the rear roller through the holes in the plastic covers at the rear of the machine.
Tensioning the bolt clockwise will add tension to the side accessed. This will push the belt away from this side. Half turn increments at a slow belt pace (less then 3mph) will begin to make the desired result of moving the belt.
Pro forms parent company has great YOUTUBE CHANNEL: FITNESS EQUIPMENT HELP. Searching for the topic you are in search of should produce a great reference.
Tradmill belt - the thing you walk on probably needs silicone lubricant underneath the belt.
https://worldfitness.com.au/products/bodyworx-silicone-spray-can?utm_medium=cpc&utm_source=google&utm_campaign=Google%20Shopping&gclid=EAIaIQobChMIl_ekw96Q5gIVFIWPCh0C-wOdEAQYASABEgLtnfD_BwE
probably get from a sports shop that is local to where you live.
I have to get some for my own treadmill
Just haven't got to my local sports shop
Proform Exercise... | Answered on Nov 30, 2019
Proform Walking Belt For The Crosstrainer Treadmill. Model Pftl50072 Logo
1 questions posted
Top Proform Exercise & Fitness Experts
Marvin
Marvin
john h
jay kaye
jay kaye
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
proform zt3 causes dsl wifi modem go
  • Exercise & Fitness
