20 Most Recent Proform Freespirit 814 Treadmill Drive Motor Questions & Answers
TREADMILL ERROR MESSAGE
A proximity sensor is telling you the belt is incorrectly aligned. Probably too loose. Bolts on end of shafts control belt tension. Turn in if loose, out if too tight.
9/5/2014 5:12:26 PM • Proform... • Answered on Sep 05, 2014
Proform crosswalk caliber elite cuts off after 10 minutes of use
Here are some possible causes and solutions: Overheating: If the motor or electronics of the treadmill get too hot, the machine may shut down to prevent damage. Make sure that the treadmill is placed in a well-ventilated area and that the air filters are clean. You can also try lubricating the walking belt to reduce friction. Faulty speed sensor: If the speed sensor is malfunctioning, it may cause the treadmill to shut down. You can try cleaning the speed sensor with a soft cloth and see if that helps . Worn walking belt: If the walking belt is worn or damaged, it may cause the treadmill to shut down. You can try replacing the walking belt and see if that helps. Electrical issues: If there are any electrical issues with the treadmill, it may cause the machine to shut down. You can try resetting the circuit breaker or unplugging the treadmill for a few minutes and then plugging it back in. If none of these solutions work, it may be best to contact Proform customer service.
1/20/2024 8:51:12 AM • Proform Exercise... • Answered on Jan 20, 2024
Proform 400R Exercise Bike. How to install seat handle please? Having trouble with seat adjustment handle.
Question edited for clarity. Here is the manual with assembly instructions starting on page 5.
ProForm XP400 R User Manual
ManualsLib https://www.manualslib.com > ... > XP400 R View and Download ProForm XP400 R user manual online. 831.217520. XP400 R exercise bike pdf manual download. Also for: 831.217520. ..
12/31/2023 11:40:25 PM • Proform Exercise... • Answered on Dec 31, 2023
Proform Crosswalk Treadmill. Where can we buy a motor controller, part number 101757?
Question edited for clarity. Try contacting Treadmill doctor direct.. They have the best spares collection. https://www.google.com/search?q=Proform+Crosswalk+Treadmill.+motor+controller%2C+part+number+101757 ..
9/30/2023 4:11:42 AM • Proform Exercise... • Answered on Sep 30, 2023
Incline won't work on Proform 400s Treadmill
If you've already replaced the lift motor on your Proform 400s Treadmill and the incline still won't work properly, there may be other underlying issues that need to be addressed. Here are a few troubleshooting steps you can try: Check the wiring: Ensure that all the wiring connections related to the incline mechanism are secure and properly connected. Loose or damaged wiring can cause issues with the incline functionality. Inspect the incline motor and gears: Examine the incline motor and gears for any signs of damage, misalignment, or obstruction. Ensure that the gears are engaging properly and that there are no obstructions preventing the incline from moving up and down smoothly. Reset the treadmill: Perform a full system reset on your treadmill. This can often resolve minor software glitches or issues that may be affecting the incline function. Consult your treadmill's user manual for instructions on how to perform a reset. Contact customer support: If you have followed the above steps and the issue persists, it is recommended to reach out to the customer support of Proform or the retailer from whom you purchased the treadmill. They should be able to provide further troubleshooting guidance or arrange for professional repair assistance if needed. Remember to exercise caution when working with electrical components or performing any repairs on your treadmill. If you are unsure or uncomfortable with the process, it is advisable to seek assistance from a qualified technician or the manufacturer's customer support to ensure proper diagnosis and resolution of the issue.
6/18/2023 4:47:04 PM • Proform Exercise... • Answered on Jun 18, 2023
2answers
Proform CrossWalk 545 Treadmill. The interface on my Proform 545 lights up, but do not respond to touch?
First try a full power reset and also look for the motor trip reset button.
3/18/2023 7:07:44 PM • Proform Exercise... • Answered on Mar 18, 2023
2answers
Proform CrossWalk 397 Treadmill. Some of the soft buttons on console are not working?
If you can get in behind the buttons, clean them with electrical Contact Cleaner spray. Also clean the connectors with it as well.
3/18/2023 7:06:29 PM • Proform Exercise... • Answered on Mar 18, 2023
How much did my Proform XP 800 VP cost when it was brand new and what year was it made please?
Question edited for clarity, it is a Proform not a preform. Question moved from Video Cameras category. $800 as a ballpark figure. https://www.google.com/search?q=proform+xp+800+vp+review 2005 is the manufacture date according to the Copyright notice on the last page of the manual. https://www.sportsmith.net/images/product_support%5CProForm%5C295550%20-%20PROFORM%20XP%2080%20VF%20TREADMILL%5C29555.0-222007.pdf ..
2/25/2023 1:30:54 AM • Proform Exercise... • Answered on Feb 25, 2023
My proform 400i treadmill screen is on, it says if it. The incline works, the treadmill doesn't move.
  1. Check if the safety key is securely inserted and engaged.
  2. Ensure that the belt is centered and not too tight or too loose.
  3. Verify that the motor controller is not over-heating, if it is, allow it to cool down.
  4. Check the drive belt for wear and damage, if necessary, tighten or replace the belt.
  5. Ensure the motor is functioning properly by checking the wiring and connections.
  6. If these steps do not resolve the issue, the motor or the control board may need to be replaced and it is recommended to call a professional repair service.
1/29/2023 7:17:35 PM • Proform Exercise... • Answered on Jan 29, 2023
2answers
The motor on my proform 395e elliptical has begun humming and it is getting louder and louder. Is there a remedy?
There are a few potential remedies for a humming motor on a Proform 395e elliptical:
  1. Tighten any loose parts: If the humming noise is coming from the motor, it could be caused by loose parts that are vibrating against each other. Try tightening any screws or bolts that may be causing the noise.
  2. Check the belt: The belt that connects the motor to the elliptical's flywheel may be loose or damaged, which can cause a humming noise. Tighten the belt or replace it if it is damaged.
  3. Check the flywheel: If the flywheel is damaged or out of balance, it can cause the motor to vibrate and make a humming noise. Check the flywheel for damage and replace it if necessary.
  4. Check the motor bearings: If the motor bearings are worn or damaged, they can cause the motor to vibrate and make a humming noise. Check the motor bearings and replace them if necessary.
If you are unable to identify the source of the humming noise or fix it yourself, it is recommended that you contact Proform customer service or a qualified technician for assistance.
1/2/2023 1:17:09 PM • Proform Exercise... • Answered on Jan 02, 2023
Need wiring diagram for incline motor
see the wiring attached: God bless you7_23_2012_2_04_25_pm.jpg7_23_2012_2_04_41_pm.gif
1/1/2023 9:16:44 PM • Proform Exercise... • Answered on Jan 01, 2023
2answers
Proform 9000 trips power as soon as we turn it on. Anyone else had this issue?
Unplug the treadmill from the surge suppressor and plug in a typical house vacuum.
Turn on vacuum. If breaker does not trip from the vacuum then treadmill power supply is likely kaput.
If breaker trips then likely it's not the treadmill. Bypass surge suppressor by plugging vacuum directly into same wall outlet as the suppressor. If breaker again trips, it's not the suppressor and more likely there is some type of circuit overload or other fault in the house branch circuit.
12/21/2022 2:21:42 PM • Proform Exercise... • Answered on Dec 21, 2022
I need a new motor control bord for proform pf 3.6 treadmill
Im having problems with proform pf 3.6. Dash is on but only the speed button is beeping noise everything else is off. I checked the motor Nd it's OK.
10/25/2022 2:55:49 PM • Proform Exercise... • Answered on Oct 25, 2022
Proform 505 cst belt slipping left and has crease
It's alway a good idea to replace any belt that shows signs of damage as this is a weak point on the belt and you risk it snapping, then you'll have to replace it anyway. Check the alignment of the pulleys the belt drives. Check they line up with each other and they spin without any wobble. Belts for these machines are usually not expensive. I would recommend you buy an original one from the manufacturer as this will be the one designed specifically for that job.
5/17/2022 4:36:34 PM • Proform Exercise... • Answered on May 17, 2022
Why does my Proform 650 LT beep at me and not work?
A power reset is the only help given. One article suggests a factory reset for 3 or 4 beeps. Customer Support bottom of the page. https://www.proform.com/treadmills/650-lt https://www.google.com/search?q=Proform+650+LT+5+beeps ..
4/30/2022 1:47:27 AM • Proform Exercise... • Answered on Apr 30, 2022
Why does My Proform 510i treadmill starts then stops immediately?
Question edited for clarity, 'then; a moment in time, 'than', a comparison between one thing and another. It is a known issue on Proform. Help in the link. https://www.google.com/search?q=Proform+510i+treadmill+starts+then+stops ..
3/29/2022 4:00:10 AM • Proform Exercise... • Answered on Mar 29, 2022
Proform Freespirit 814 Treadmill Drive Motor Logo
1 questions posted
Top Proform Exercise & Fitness Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Proform Exercise & Fitness
Most Popular Question
treadmill error message
  • Exercise & Fitness
