20 Most Recent
Soyo SY-P4I865PE Plus DRAGON 2 v1.0 Motherboard Questions & Answers
I added more RAM while
to check the type of ram you could remove it to check the brand/type before you do this
try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f this should schedule to happen on reboot which will scan for and attempt to recover bad sectors and automatically fix any corrupt files on your hard drive or
click startcontrol panel administrive tools,computer management ,disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now,start should schedule this task when restart
do not do anything while the chkdsk utility is in progress any input will damage your computer
then you should test or replace all leads make sure they are securely seated and are not bad/faulty that are attached to your (((motherboard to your hard drive))
defragment your hard drive will speed up your computer
scroll to the bottom toolbar (bottom of screen) right click you can select task manager applications also processes you will see whats running on your computer you might have virus slowing your computer also select users you will see who is using your computer
don
My motherboard close in 5
more detail please... did you make sure everything was pluged in, heatsink installed correctly, memory installed?
