20 Most Recent
Soyo P4X400 Dragon Lite (P4X400DRAGNLITE) Motherboard Questions & Answers
I bought this board with
you need to reset the cmos to recognize the ram, this is done by removing the cmos battery and joining conductive wire to the pos and neg term where the battery sits, earth out for at least 6 seconds, this takes place after inserting new ram, hope this helps
Wires for USB go to which MoBo pins?
there is two sets of 4 pin on each with an xtra ground you may not use.
Here is the link for your motherboard manual which shows the connections.
i.e you can connect your two sets of 4 wires to usb 1 or split them i.e 1 set of 4 on usb 1 and 1 set of 4 on usb 2.
http://zhornyak.com/soyo/Soyo_P4X400_Manual.pdf
Sound driver
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Drivers for motherboard
Click on the link I paste here below, there is a list of a available driver support for you motherboard.
SOYO P4X400 SupportKindly let me know if you need more assistance.
Thank you for using fixya.
micro-
Soyo sreen is black cannot sinc with my pc
this can be your computer issue not monitor try connect to other monitor and make sure your computer is working fine ,you can check all the lights on the computer are on and getting no beeps sounds usually you will hear a single beep when PC is booting well
Soyo monitor: Out of Range
Out of range indicates that you have attempted to use a resolution the the monitor is incapable of handling.
Lower your resolution and try again until you can get it to do what you wish then try to do each monitors resolution individually.
