20 Most Recent Bowflex TreadClimber TC5000 Questions & Answers
Keeps tripping breaker when put into start mode.
Hi, if you have burnt electrical smell and the breaker keeps tripping you have a short in the motor that's what causes the tripping in the breaker. You will have to get it repaired or claim if it's still under warranty.
3/20/2016 8:06:48 PM • Bowflex... • Answered on Mar 20, 2016
What does error code 1649uli indicate?
You have to call the Company representative who will guide you through the error code. Call :1-800-628-8458 In case you don't have the manual, here it is: http://www.searspartsdirect.com/partsdirect/user-manuals/TC5000-Bowflex-Parts-BOWFLEX+TREADCLIMBER-manual Good Luck!
2/2/2016 3:36:58 AM • Bowflex... • Answered on Feb 02, 2016
0answers
I need someone to come out and service my tread climber. Is there a number I can call for maintenance?
Google search your manufacturer make, model and customer service. They can assist you in finding a service technician.
6/5/2015 10:22:48 AM • Bowflex... • Answered on Jun 05, 2015
2answers
Machine makes a LOUD clack clack clack while running. Seems to be coming from rear belt roller area...
It is probably the join on the belt itself as it passes the over the roller. It could be a sign that the belt is breaking.
3/5/2015 10:14:49 AM • Bowflex... • Answered on Mar 05, 2015
0answers
0answers
0answers
Makes a loud rubbing noise on one side
To be honest with you, these could be symptoms of a few different problems. Here are the most common ones and what it possibly sounds like: 1) It could be that the front roller has dislodged itself from the roller pulley. In other words, the motor keeps turning, and when you step on the walk belt, the pulley (the one with the small rubber belt) keeps turning, but the roller stops. This can cause grinding noises, and the pulley to "skid" the black belt, which can account for the black dust. You can usually tell this is the problem when it runs fine with nobody on it, but when you step on it, it grinds 2) It could also be that the walk belt is rubbing on the sides of the deck and/or side rails. This happens when the belt shifts over from the center. It would definitely sound like a grinding noise, and the black dust could be from the walk belt particles wearing down due to the rubbing. 3) It could also be the drive motor brushes. Let me explain. The motor has two small blocks on either side of it (inside the metal casing). Those two blocks actually carry electricity into the spinning part of the motor (called an armature). They actually make contact with the armature at all times while it spins. Those "small blocks" are made of a graphite (what pencil lead is made of). Well, with so much spinning, and so much contact from the armature, those things grind down with time. They sometimes grind down until they are stubs only. Then they start grinding. The powder in this case would be the brush graphite piling up (this would often be shiny dust, and is a dark grayish). 4) The grinding could also be roller bearings going bad. **For #3, and 4 above, you have but to remove the small belt that attaches to the motor (rubber, black, and small attached to pulleys), and let the treadmill run for a few seconds by itself. You may get a "speed error code' after the treadmill does not detect speed, but at least you'll know if the grinding is coming from the motor. If it runs super quiet, even for a few seconds, then you know it may be #1, 2, or 4 above. These are the most common issues based on your symptoms.
3/16/2014 6:38:38 AM • Bowflex... • Answered on Mar 16, 2014
0answers
Treadles only go uo and down about 3 inches. Hard to move them
These are fairly complex machines...call foe service 877-805-1030
1/4/2014 4:22:53 AM • Bowflex... • Answered on Jan 04, 2014
Power switches off after 15 to 20 minutes use
test the power switch for defective use the vom2) test the c. breaker for defective use the vom3) test the power supplier see the diagram attached. God bless you
8/26/2013 2:50:53 AM • Bowflex... • Answered on Aug 26, 2013
Bowflex TreadClimber TC5000 Logo
42 questions posted
Top Bowflex Exercise & Fitness Experts
Ekse
Paul Carew
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
View Most Popular
  • Bowflex Exercise & Fitness
Most Popular Question
treadclimber tc5000 error code l5
  • Exercise & Fitness
