20 Most Recent Fujifilm Finepix S3400 Digital Camera black 977218 16gb Kit Questions & Answers
Press the MENU/OK button to bring up the menu, press cursor-left, use cursor-up/down to select the wrench icon, press cursor-right, use cursor-up/down to select the talking-head icon (should be the third item from the top), press cursor-right, select the desired language, and press MENU/OK.
Fujifilm Finepix... | Answered on Mar 16, 2017
About the HS10 autofocus problem, I discovered the cause and solution. It is a problem of camera design, and is caused by three screws securing the CCD sensor. These screws are not properly secured and the vibration eventually dropping.
In two cameras with the same defect, the screws were loose. These screws adjust the sensor position relative to the lens and the sensor is loose when out of position not allowing proper focus.
The solution is to disassemble the camera and secure the screws.
These screws can not be too tight they need to be adjusted to position the CCD sensor correctly. The camera is difficult to dismantle because several wires are soldered.
Care must be taken to discharge the capacitor of the flash, this may cause an electric shock and burn the camera board.
Those who want to try the repair, follow the link to the service manual.
http://elektrotanya.com/fujifilm_finepix_hs10_hs11_sm.pdf/download.html
Milton Maenishi
Fuji FinePix... | Answered on Jan 05, 2019
Many occasions LCD on camera display never fails but back light fails unless physical damage to LCD screen. Hold a torch to display when camera is on you will see faint(black and white) image means LCD is ok but back light is failed, it's replaceable but needs little skill to replace. Or replace full Screen with backlight. This is easy. Just remove back cover, remove display by loosening flex lock, put back new display carefully lock it holding flex with one finger. Please do not touch display flex contacts.
Fuji FinePix... | Answered on Dec 21, 2018
Time for a new camera, these are not repaired just exchanged, so the price is high, just replace it.
Fuji FinePix... | Answered on Jan 23, 2017
Local friendly camera shop / manufacturer / Ebay
Fuji FinePix... | Answered on Oct 01, 2016
That should be possible - just Google the make and model, followed by the word software.
Fuji FinePix... | Answered on Sep 27, 2016
Why not remove the memory card and use a card reader attached to your computer ?
Fuji FinePix... | Answered on Aug 19, 2016
Which FujiFilm camera model do you have? Not every camera has a GPS function built in.
Fuji FinePix... | Answered on Apr 29, 2016
Pull and twist gently to see if that will dislodge whatever is keeping the lens from retracting. You may have gotten some dirt or sand in the mechanism. It doesn't take much to prevent retraction. If it is dirty, a little gentle action will sometimes free it.
Fuji FinePix... | Answered on Mar 25, 2016
There is cables that you can get it is like a HDMI cable or USB cable that fits your cameras charging zone and fits the computer. :)
Fuji FinePix... | Answered on Mar 21, 2016
Hi, it sounds like you will have to get it repaired if its under warranty or otherwise.
Fuji FinePix... | Answered on Jan 27, 2016
Fujifilm Finepix S3400 Digital Camera black 977218 16gb Kit Logo
1 questions posted
Top Fuji Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
change language s3400 camera
  • Cameras
