20 Most Recent Beverage-Air MT17 Refrigerator Commercial Questions & Answers
Low refrigerant would make it inefficient but if it chills to 28° it can't be that bad. I think you have a control issue. The compressor runs when you reset to off & on, then chills until it satisfies the thermostat, then shuts off. But then is not starting again when the temperature rises. You'll need to follow the control wiring to see what contacts are open and not passing power to the compressor. Control wiring is typically 24v ac or 115v ac. There's also the possibility that the compressor is tripping out on overload at 28°. You effect a reset when you turn it off, then on.
Beverage-Air... | Answered on Mar 26, 2017
only time it should go off is when in defrost mode thats ur condensor fan
Beverage-Air... | Answered on Jun 20, 2015
you have to ensure that there are sufficient clearance at the back refrigerator.
Beverage-Air... | Answered on Sep 11, 2012
The inside fan has to run all the time. It turns off it will not keep things cold. Not the fan outside in the air it shoulc cycle with the compressor.
Beverage-Air... | Answered on Jun 14, 2011
sounds like you either need to replace the door springs or at least look to see what might be wrong. let me know if i can help.
Beverage-Air... | Answered on Feb 21, 2011
Without refrigeration gauges, you can't check your freon level. You have to check the pressure of the freon, not the level. If you are careful and have a basic knowledge of electricity and moving parts, you can get an idea if you are out of freon. If you remove the lower slotted cover from the refrigerator you will see the condensor coils. This is a radiator that has aluminum fins on the front and will have a fan running behind it. If the compressor is running this condenser coil should be hot to the touch at the top part of the aluminum fins. If the fins are covered with dust and dirt it can cause your cooler to malfunction. Also if the fan is not running the compressor will overheat and quit. If you pull the cooler away from the wall, you can see the compressor in the bottom of the cooler. There are two copper lines leading to the compressor. The small line goes to the condensor coils (the radiator) and should be hot enough to burn your finger if you have enough freon. Also the larger of the two copper lines brings the freon back to the compressor from inside the cooler. It should be cold to the touch if you have proper freon pressure. If both of those two lines feel about the same temperature, either the compressor is not running or you have no freon. BE CAREFUL! There are electrical lines and moving fan blades near the compressor, and some of the tubing gets really hot.
Beverage-Air... | Answered on Sep 23, 2010
before you go replacing stuff, better check the freon level. It sounds that it may be low. Could be a leak in the system. I'd do that first. Symtoms point in that direction.
Beverage-Air... | Answered on Jul 04, 2010
Yes, the compressor should be bolted down tight enough to be pressing against the springs beneath it, but not so tight that it completely smashes the springs. If there are no springs beneath the compressor that could also be the cause of the noise problem.
Beverage-Air... | Answered on Mar 29, 2010
their web site says it is to maximize defogging.
http://www.beverage-air.com/images/glassDoorMerchandisers/manuals/809-005A.pdf
See if you can get to their web site. In the operations section, under initial start up, it talks about this. Can't find anything else on this.
Good Luck-Hope this helps.
Beverage-Air... | Answered on May 24, 2009
The refrigerant must be recoverd or drawn into the condensing unit and the service valves closed.
If you do not have service valves that will close, you must recover the refrigerant.
Beverage-Air... | Answered on Mar 04, 2009
refrigerant does not need to be replaced. only time needs gassing up is if there is a fault with the sealed system such as a leak etc. what is your actual problem that makes you ask the question. get back to me if you like
Beverage-Air... | Answered on Jun 08, 2007
There is no"filter" underneath. There is. however, a tray underneath your fridge, designed to catch any excess water. If you remove the bottom louvered piece in the front on the fridge, you will find, probably on the right hand side, a tray which is engineered and designed to catch any excess water (as if the fridge were defrosting), but there is no "filter" which I know about. Refrigerators are pretty simple machines. They don't typically require lots of maintenance, but they do require monitoring here and there.
Beverage-Air... | Answered on Jan 18, 2018
Beverage-Air MT17 Refrigerator Commercial Logo
Popular Tags
27 questions posted
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Beverage-Air Refrigerators
Most Popular Question
unit will not get cold vacummed fins
  • Refrigerators
