20 Most Recent Canon PIXMA MG5220 Wireless Photo All-in-One Inkjet Printer Questions & Answers
Cannon pixma mg5220 printer, b200 error msg. how do you remove the printhead ?
Error B200: A service error has occurred.
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, the device needs to be send to service for repair. It can be that only the print head has malfunctions, but mostly it is another defect in the printer which causes also a defective print head. Changing the print head can solve the issue for a couple of weeks, but then the error will occur again.
11/24/2021 6:31:31 PM • Canon PIXMA... • Answered on Nov 24, 2021
Canon Pixma printer new magenta ink cartridge does not print
The nozzle in the printer is clogged - clean it with a cotton bud and distilled water
5/2/2017 8:18:10 AM • Canon PIXMA... • Answered on May 02, 2017
I can't print from my Mac to my canon mg 5220
hi, looks like software in compatible issue, you may require a patch , or re-install software , with printer on and connected to the mac re-start the computer , also check the firm of the printer , if it has one , hope this help,
9/18/2016 4:09:58 PM • Canon PIXMA... • Answered on Sep 18, 2016
0answers
Blurry text
Be the first to answer 2/2/2014 4:30:08 AM • Canon PIXMA... • Posted on Feb 02, 2014Be the first to answer
Printer head for my cannon MG5220 wihich was purchased through amazon in December is not working
Inkjet printers need to be used frequently to prevent blocked print head nozzles. You may have blocked print head nozzles. Try the printer maintenance to clear the printer nozzles. After several deep cleaning attempts and there is no improvements in the print then a new print head is required. A new print head maybe expensive and it maybe more cost effective to purchase a new printer.
8/22/2012 7:02:21 AM • Canon PIXMA... • Answered on Aug 22, 2012
My Canon PowerShot SX100IS will not keep the date/time. Every time it is turned off, it asks for the date/time to be set. What is causing this?
There is an internal battery that you cannot replace. IT has to be sent into service.
11/24/2021 6:31:13 PM • Canon Cameras • Answered on Nov 24, 2021
How do i fix e31 on may canon
11/24/2021 6:30:51 PM • Canon Cameras • Answered on Nov 24, 2021
Flash/Auto setting not working on Canon Rebel EOS 2000 35mm camera
remove the film and have it repaired and serviced by Canon. It is worth getting it fixed if you like using film. A number of companies are now making digital backs for cameras.
10/13/2021 10:08:06 PM • Canon Cameras • Answered on Oct 13, 2021
When insert any sd card canon 70d says cannot creat folder
The part where the SD cards are inserted could be dirty and should be cleaned out with qutips and rubbing alcohol or it could also needs replaced as well.
6/1/2021 4:12:45 AM • Canon Cameras • Answered on Jun 01, 2021
Cannon powershot A530 digital camera Camera
Try Formatting the card.
Someone could have locked it accidently.
2/25/2021 9:49:07 AM • Canon Cameras • Answered on Feb 25, 2021
A590. Why does it indicate 'replace batteries' even after new ones installed?
Corroded contacts caused by "moistening"
1/9/2021 3:58:13 PM • Canon Cameras • Answered on Jan 09, 2021
Manual for Canon A3100 IS PowerShot
In order to avoid any problems with any technique, I prefer to study the user manual in order to understand the different Canon models. You can read the user manual from this site http://canon.manymanuals.com
12/14/2020 3:23:19 PM • Canon Cameras • Answered on Dec 14, 2020
Fix stuck flash on Canon 60d
HOW TO BUILD FLASH ON../Kids Saying Yay [Sound Effect] - https://www.youtube.com/watch?v=xUMUE... From EpicSoundFX - https://www.youtube.com/channel/UChRh...
11/25/2020 2:39:02 PM • Canon Cameras • Answered on Nov 25, 2020
Manual PDF for Canon Camera pc1263
This answer is 8 years too late, but whatever. The PC1263 is actually the PowerShot A590 IS. To delete all photos, press the "MENU" button, select the "Playback" tab (the one that looks like a little triangle) and scroll down until you see the option "Erase All." Press the Select button and confirm. All photos will be erased.
7/31/2020 3:28:55 PM • Canon Cameras • Answered on Jul 31, 2020
Focus repair on a Canon D10 Camera.
9 years old model, probably not worth repair. You can get used one on ebay for little money
7/18/2020 5:30:17 PM • Canon Cameras • Answered on Jul 18, 2020
Canon ixus 330 zoom lens 3x 5.4-16.2mm1:2.7-4.7 download drivers
Feel free - we won't prevent you.
2/13/2020 8:24:54 AM • Canon Cameras • Answered on Feb 13, 2020
I have a Canon G11. When I push the zoom lever to zoom the lennse, it immediately goes back to the initial position when I release it instead of staying at the selected position. Any ideas.
there may be dust inside the lens (motor ,gears and sensor) pleas open and use an air blower to oust it.
1/8/2020 7:05:57 PM • Canon Cameras • Answered on Jan 08, 2020
Canon PIXMA MG5220 Wireless Photo All-in-One Inkjet Printer Logo
8 questions posted
Top Canon Cameras Experts
old marine
old marine
Ekse
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
Canon Cameras
  • Canon Cameras
Most Popular Question
canon pixma printer new magenta ink
  • Cameras
