20 Most Recent
Canon EOS Rebel T3i 600D SLR Digital Camera Kit with EF-S 18-55 IS II Lens & 430EX II Speedlite TTL Shoe-Mount Flash. Including SSE Premium Kit: Replacement LP-E8 Battery, Travel Charger, Full Size Tripod, HDMI Cable, 8GB SDHC Memory Card, SD Card Reader, Questions & Answers
CANON REBEL XS
It can happen if you are in the Auto-No Flash mode. Or if the flash release button is stuck.
Contact customer service, and have a pro take a look at your camera.
Trying to download pics from computer and get error 31, but then camera automatically disconnects itself
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Liquid soap inside the screen
The soap is probably between the back light and the LCD itself, on one of the plastic Fresnel screens. You may be able to clean it off with Windex on a Q-tip. Remove back cover (can't give directions without knowing which model)
Focus lights are Dim on My 1100d
Remove black side cover (two screws) and rear cover and check the rear circuit board for a missing screw in the lower right corner. Find screw and replace. If it did not short out the circuit you should see the function return. Other, send to Canon for circuit replacement
No picture on card
What model Canon camera? What type and size memory card do you have in it?
My canon rebel XS will only recognize or even
Try formatting the cards on your PC. Alternatively I would suggest that you reset your Firmware or if it is not on the latest version upgrade while you are at it - this should reset anything that potentially could have been scewed.
