20 Most Recent HP Officejet Pro 8600 Plus e-All-in-One Wireless Inkjet Printer Questions & Answers
The Black Line running vertically on the page can be a couple of things.
1) If you are using the ADF (Auto Document Feeder) then the most likely cause is a mark on the ADF Scanner Glass normally caused by something going through the ADF with wet ink on it usually a page that has been written on with a Ball Point pen and the ink had not dried fully before it was fed through. If you lift the top of the printer so you can see the full glass scanner plate on the left had side you will see a smaller strip of glass/plastic that is used for ADF scanning. Clean this using Window Cleaner or Rubbing Alcohol.
2) if you are not using the ADF, or if you are and the previous option did not fix the problem then it could be a scanner bulb issue which would require a service technician replacing the scanner bulb. If the printer is under warrantee then this should not cost anything. If it is not in warantee then replacing the printer would be cheaper.
HP Officejet Pro... | Answered on Oct 14, 2014
Most HP printers include the print head with the ink carts. Replace the ink cart, get a new print head.
HP Officejet Pro... | Answered on Sep 02, 2014
Get a technician to fix it.
HP Officejet Pro... | Answered on Aug 26, 2014
first you need to do go to devices and printers and see your printer icon and double click your printer, it open automatically one window in that window you can able to see what it printing.. select the documents and delete the all documents....
still it same issue you need to do reset the printer settings means NVRAM installation..
HP Officejet Pro... | Answered on Jun 25, 2014
You will find the scanner is not lighting. You will have to fit a new scanner/CIS assy.
HP Officejet Pro... | Answered on Jan 30, 2014
When scanning multiple documents, select a TIFF file as the file type. Unlike a JPG, a TIFF file can contain multiple pages.
HP Officejet Pro... | Answered on Dec 14, 2013
how would you like to connect the printer??? it is though usb or wireless???
HP Officejet Pro... | Answered on Oct 21, 2013
Usually printers are opened up from underneath. Often, the screws hide under the rubber feet.
HP Office... | Answered 17 hours ago
Strategy for How To Fix HP Printer Offline In Windows 10 and Mac?
First You Must Check Your Basic Connections:
A few times show hp printer offline circumstance when it isn't accurately associated with your framework, or there shows up some organization issue prompting the printing blunder. Audit for the equivalent to measure with the printing capacity.
For what motivation behind why does my hp printer-state offline?
There can be a few reasons for what reason does my hp printer props up offline. One of the principal purposes behind the HP printer demonstrating offline, It might be an issue with your Wifi link or association. You should attempt to get check your Wifi Connection, is it appropriately associated or not.
Purposes for that Why Does My HP Wireless Printer Goes Offline?
HP printers require a strong association and organization with the framework's If your association is lost the availability, It will demonstrate the HP printer to be offline "Use the printer in offline mode" A the client must guarantee this alternative isn't picked on his printer as it would not permit the customer to use the printer with a far off association. The course for remedying this setting is according to the accompanying Select the Start menu-click on settings-Click on gadgets printer and scanners-from the recorded line uncheck the container given before "Use HP Printer Offline." This would restore your hp printer in online mode.
For detailed information on these kinds of issues. You are suggested to visit the link shown below:-
Hp Error 49.4c02
HP Office... | Answered Yesterday
HP Officejet Pro 8600 Plus e-All-in-One Wireless Inkjet Printer Logo
60 questions posted
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
scan black line running vertically get
  • Office Equipment & Supplies
