20 Most Recent HP Officejet 100 Mobile Inkjet Printer, Bluetooth-Enabled Questions & Answers
How do I make my hp officejet 100 discoverable
Extracted From the USER GUIDE (download here) http://h10032.www1.hp.com/ctg/Manual/c02648771.pdf Set up the printer for Bluetooth communication The printer allows you to print documents from Bluetooth devices without a cable connection. Simply print from a Bluetooth device such as a PDA or camera phone. You can also use Bluetooth technology to print from a computer to the printer. Set up a Bluetooth wireless connection This section describes how to set up and configure the device for a Bluetooth wireless connection. You can configure Bluetooth wireless settings during software installation, or you can configure settings later using Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools. To connect the printer using Bluetooth communication (Windows) NOTE: If you are using an external Bluetooth adapter for your computer, specific instructions for adding the printer might be different. For more information, see the documentation or utility provided with the Bluetooth adapter. 1. If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer. If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on. 2. On the Windows taskbar, click Start , click Control Panel , click Hardware and Sound , and then click Add a printer . - Or - Click Start , click Printer or Printers and Faxes, and then double-click the Add Printer icon or click Add a printer . 3. Follow the onscreen instructions to finish the installation. To connect the printer using Bluetooth communication (Mac OS X) 1. If you are using an external Bluetooth adapter for your computer, make sure your computer is started and then attach the Bluetooth adapter to a USB port on the computer. If your computer has Bluetooth built in, just make sure the computer is started and that Bluetooth is turned on. 2. Click System Preferences in the Dock, and then click Print & Fax . 3. Click + (Add). 4. Select the entry for the printer in the list with Bluetooth beside its name, and then click Add . 5. Follow the onscreen instructions to finish the installation. Set Bluetooth security for the printer You can enable the following printer security settings: • Require passkey authentication prior to someone printing to the printer from a Bluetooth device. • Make the printer visible or invisible to Bluetooth printers that are within range. • To enable these settings, you can use Toolbox (Windows), HP Utility (Mac OS X), or the Toolbox software for PDAs (Windows Mobile). For more information, see Printer management tools. Set up the printer for Bluetooth communication 93 Use a passkey to authenticate Bluetooth devices You can set the security level of the printer to either High or Low . • Low : The printer does not require a passkey. Any Bluetooth device within range can print to it. NOTE: The default security setting is Low . Low level security does not require authentication. • High: The printer requires a passkey from the Bluetooth device before allowing the printer to send a print job to it. NOTE: The printer ships with a predefined passkey that is set to six zeroes "000000". Set the printer to be visible or not visible to Bluetooth devices You can set the printer to be either visible to Bluetooth devices (public) or not visible to any (private). •Visible : Any Bluetooth device within range can print to the printer. • Not visible : Only Bluetooth devices that have stor ed the device address of the printer can print to it. NOTE: The printer ships with a default accessibility level of Visible . To reset to factory default settings NOTE: Using the following instructions will reset only the device's Bluetooth settings. 1. Press and hold down (Power button). 2. While holding down (Power button), press (Cancel button) 4 times, then press (Resume button) 6 times. 3.Release (Power button).
9/11/2014 8:16:25 PM • HP Officejet 100... • Answered on Sep 11, 2014
0answers
I have an orange light blinking
Unplug it, leave with no power for 15 mins, power up and update drivers from the net. Also check and replace cartridges if needed.
7/21/2014 2:51:59 PM • HP Officejet 100... • Answered on Jul 21, 2014
I have a HP Officejet 100 Mobile Printer. Only one
please check the paper path could be something block the paper or broken Hope help you
11/11/2013 6:15:51 AM • HP Officejet 100... • Answered on Nov 11, 2013
My HP Laserjet 1012 is not printing
Lo siento por o?r que tu impresora est? teniendo problemas. Es posible que la ca?da haya causado alg?n da?o a la impresora oa sus componentes internos. Aqu? hay algunos pasos que puedes seguir para intentar solucionar el problema:
  1. Verifica la conexi?n: Aseg?rese de que la impresora est? conectada correctamente al ordenador y que ambos est?n encendidos. Si est? utilizando un cable USB, intente cambiarlo a otro puerto USB.
  2. Verifica los cartuchos de t?ner: Verifica si los cartuchos de t?ner est?n correctamente instalados y si est?n bajos o vac?os. Intenta reemplazarlos si es necesario.
  3. Limpia la impresora: Si la impresora ha sufrido alg?n da?o f?sico, puede haber polvo o suciedad en su interior que est? obstruyendo los componentes. Abre la cubierta y utiliza un pa?o suave para limpiar el interior de la impresora.
  4. Verifica el estado de la bandeja de papel: Verifica si la bandeja de papel est? correctamente insertada en la impresora y si hay suficiente papel en ella. Tambi?n aseg?rese de que la gu?a de papel est? ajustada correctamente para el tama?o del papel que est? utilizando.
3/29/2023 11:58:53 PM • HP Office... • Answered 15 hours ago
2answers
How to set HP 3830 deskjet ink printer?
HP Printer users faced trouble when they setup HP Printer with the computer. Follow the steps to setup your HP 3830 desk jet printer. Step1: Unpack your printer and connect to power Step2: HP Easy Start Printer Setup Software Step3: After printer setup, add this printer to your HP Support Dashboard
3/26/2023 7:19:49 AM • HP Office... • Answered on Mar 26, 2023
Officejet hp 8720 scanner block?
3/22/2023 3:21:38 PM • HP Office... • Answered on Mar 22, 2023
How can I fix 60.03 error
Hi! Error 60.03 on the HP LaserJet Pro M402n indicates a tray 2 lift error. Here are the steps you can take to fix the issue:
  1. Turn off the printer and unplug it from the power source.
  2. Remove the paper tray 2 from the printer.
  3. Check the tray for any damaged or jammed paper. If you find any, remove it carefully.
  4. Check the tray for any broken parts or debris that may be blocking the tray's movement. Clean the tray and remove any debris if you find any.
  5. Reinsert the tray into the printer and make sure it is correctly aligned.
  6. Turn on the printer and check if the error has been resolved.
If the error persists, you may need to replace the paper pickup and feed rollers in tray 2. If you are not comfortable doing this yourself, it is recommended that you contact an authorized HP service technician to help you resolve the issue. Regards Viktor
3/17/2023 10:12:22 PM • HP Office... • Answered on Mar 17, 2023
HP DESKJET 890C Professional WILL NOT TEST PRINT. It just has flashing lights.
Question edited for clarity. 3 Questions made into one question, 2 duplicates deleted. Refresh page to see your question. Please don't type in all CAPS, it is considered SHOUTING and harder to read. There are three different colour of lights. All explained here.
blinking information red light - HP Support Community
hp.com https://h30434.www3.hp.com > td-p Jun 29, 2020 - 1) Take out the cartridges. 2) Unplug the power cord from the printer & wall. 3) Wait for 30 seconds. 4) Plug the power cord back into ... Missing: 890c ‎' Must include: 890c
3/15/2023 4:26:40 PM • HP Office... • Answered on Mar 15, 2023
HP OfficeJet Pro 8600 stuck in printhead animation
It sounds like you are experiencing a hardware issue with your HP OfficeJet Pro 8600 printer, specifically with the printhead. Here are some troubleshooting steps you can try:
  1. Power cycle the printer: Turn off the printer, unplug it from the power source, and wait for about 1 minute. Plug the printer back in and turn it on. This may help to reset the printer and clear any errors.
  2. Remove the printhead and cartridges: Turn off the printer, open the front cover, and remove the printhead and all the cartridges. Clean the printhead with a lint-free cloth and distilled water. Be sure to let the printhead dry completely before reinserting it. Reinstall the printhead and cartridges and turn the printer back on.
  3. Reset the printer: Follow the steps for a full reset from the service menu, but before turning the printer back on, disconnect the printer from any network or computer connections. Turn the printer back on and try to print a test page.
  4. Replace the printhead: If the issue persists, it may be necessary to replace the printhead. Contact HP support for further assistance and information on how to order a replacement printhead.
Note: Using refillable cartridges can sometimes cause issues with the printer and may void the warranty. It is recommended to use genuine HP cartridges to ensure the best performance and reliability of your printer.
3/3/2023 5:24:52 PM • HP Office... • Answered on Mar 03, 2023
As i was printing A0 plans the printer froze.then i shut it down then switched it back on but now its not booting up......please help. the screen comes on but nothing is happening??
First, make sure the printer is connected to a power source and the power is turned on. If it is, try disconnecting the power cord from the printer and wait a few seconds before reconnecting it. Also make sure the power cord is connected to a working outlet. If these steps do not help, your printer may require additional maintenance or repairs. I recommend contacting HP Support for assistance.
3/1/2023 7:29:10 PM • HP Office... • Answered on Mar 01, 2023
2answers
HP officejet pro 7720 scanner problem?
f the scanner on your HP OfficeJet Pro 7720 is not returning to the home position when making a copy from the original glass, there may be an issue with the scanner mechanism or the position sensor. Here are a few things you can try to troubleshoot the problem:
  1. Perform a power reset: Turn off the printer, unplug the power cord, wait for a minute or two, then plug it back in and turn the printer back on. This may help reset the scanner mechanism.
  2. Clean the scanner glass: If the scanner glass is dirty or has smudges, it may cause the scanner to slip. Clean the glass with a soft, lint-free cloth and a non-abrasive glass cleaner.
  3. Check for obstructions: Make sure there are no obstructions, such as paper clips or debris, preventing the scanner from moving freely.
  4. Reset the printer to default settings: In the printer's settings menu, reset the printer to its default settings. This may help resolve any software issues that could be causing the problem.
  5. Update the printer's firmware: Make sure the printer's firmware is up to date by visiting the HP support website and downloading the latest firmware.
If none of the above steps resolve the issue, there may be a hardware problem with the scanner mechanism or position sensor. In this case, it is recommended to contact HP support or a professional printer technician for further assistance.
2/28/2023 11:08:38 PM • HP Office... • Answered on Feb 28, 2023
2answers
Installed new HP 74 and 75 cartridges.
First, try to clean the print head by following the steps below: 1. Remove the old ink cartridges and clean the print head nozzle with a damp cotton swab to remove any dried ink. 2. Reinstall the new ink cartridges and print a test page. 3. If the test page is still blurry, try running the printer's alignment utility. This is typically accessed through the printer's settings or system preferences. 4. If the alignment utility doesn't help, try manually doing an alignment page directly from your computer. Be sure to follow the instructions from the printer manual or from the printer manufacturer's website. 5. If the alignment page is still blurry, try reinstalling the cartridges to ensure the cartridges are securely in place. 6. If all else fails, you may need to replace the ink cartridges
2/27/2023 8:39:30 AM • HP Office... • Answered on Feb 27, 2023
Hp Laserjet 6L often shows no paper when in fact paper is loaded, and if it prints, I get a grey page where the text is difficult to read.
The issue you are describing with your HP Laserjet 6L printer could be caused by a few different things. Here are a few steps you can take to try to resolve the issue:
  1. Clean the printer: Over time, dust and debris can build up inside the printer and cause various issues, including problems with paper detection and print quality. Use a clean, dry cloth to gently wipe down the interior and exterior of the printer. You can also use compressed air to blow out any dust or debris.
  2. Check the paper tray: Make sure that the paper is loaded correctly in the paper tray and that the paper guide is adjusted to the correct size of paper. Also, check the paper pickup roller for any debris or wear. If the roller is dirty or worn, it may not be able to properly pick up the paper.
  3. Check the toner cartridge: If the toner cartridge is running low, it may not be able to produce a dark enough image, which could result in the grayish text you are seeing. Consider replacing the toner cartridge to see if this resolves the issue.
  4. Check the printer settings: Make sure that the print settings in the printer driver are set to the correct paper size and type, and that the print quality setting is set to a high enough level to produce clear text.
  5. Check the fuser: The fuser is a component inside the printer that heats up to fuse the toner onto the paper. If the fuser is damaged or worn, it may not be able to properly fuse the toner, which could result in poor print quality. Consider replacing the fuser to see if this resolves the issue.
If none of these steps resolve the issue, it may be necessary to take the printer to a qualified technician for diagnosis and repair.
2/22/2023 8:52:10 AM • HP Office... • Answered on Feb 22, 2023
11answers
Ink reset HP J6410
Unfortunately, you cannot reset the HP 74-75 ink cartridge ink level monitoring feature once they are empty (either refilled, remanufactured or compatible ink cartridges)...however print operations are still permitted. Watch this 'Low Ink Warning video' for all printer models which use the HP 74-75 ink cartridges:
HP 74, 75, 74XL, 75XL Cartridge Refills - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
Diagnostic Tap 41 Test (verifies electrical health of ink cartridges): http://www.youtube.com/watch?v=8fE-IM4AVMc
NOTE: To access the diagnostics menu on the HP Officejet J5700 or J6400 series printers, select * and # keys simultaneously and enter 124 (or 123). From there you can access the Reports Menu, 'print-mech tap test and run the diagnostic code=41 test (see video above for reference) - this will tell you the exact health of your ink cartridges. To run it I think you'll need to access via '124' access code for the HP OJ J64xx printer series. For more information, please visit:www.inkjet411.com
2/22/2023 8:48:13 AM • HP Office... • Answered on Feb 22, 2023
Error impresora hp 0xb80003e8
This error usually indicates a problem with the USB connection between the HP printer and the computer. Some common solutions to try to solve this problem are: 1. Verify that the USB connection of the printer is well connected to the computer. 2. Try disconnecting and reconnecting the USB connection to make it recognized by the computer again. 3. Verify that the computer has the correct drivers for the printer. If not, download and install them. 4. Check the USB settings in the BIOS. 5. Try using other USB ports to connect the printer. If none of these solutions work, contact HP support for help.
2/17/2023 8:44:42 PM • HP Office... • Answered on Feb 17, 2023
Hp scanjet 200 is not working
If your HP Scanjet 200 is not working, here are some troubleshooting steps you can take:
  1. Check the power supply: Make sure the scanner is properly connected to the power source and that the power cord is securely plugged in. If it's connected to a power strip or surge protector, try plugging it directly into a wall outlet.
  2. Check the USB connection: Make sure the USB cable is properly connected between the scanner and your computer. Try using a different USB cable or a different USB port on your computer.
  3. Check the scanner driver: Make sure the scanner driver is properly installed on your computer. You can download the latest driver from the HP website and reinstall it.
  4. Restart the scanner and computer: Turn off the scanner and your computer, then turn them back on and try scanning again.
  5. Clean the scanner glass: If the scanner glass is dirty, it can affect the quality of the scanned images. Clean the scanner glass with a soft, lint-free cloth and a non-abrasive glass cleaner.
  6. Check for error messages: If there are any error messages displayed on the scanner or on your computer, check the HP support website for more information on how to resolve them.
If none of these steps resolve the issue, it may be necessary to contact HP support or a professional technician for further assistance. They can help diagnose and fix the problem safely and effectively.
2/17/2023 1:53:50 PM • HP Office... • Answered on Feb 17, 2023
My prenter hp 2420 have two one is error of 62.2 storage and secondly when i use keys its functions are much slowr on disply during sitings so plz sport me for these slutions
Error code 62.2 on an HP LaserJet 2420 printer usually indicates an issue with the printer's internal memory or storage. Here are some steps you can take to troubleshoot this issue:
  2. Remove any accessories or optional components that are installed in the printer, such as an optional paper tray or additional memory.
  3. Power on the printer and see if the error message has cleared. If it has, the issue was likely caused by an incompatible accessory or memory module.
  4. If the error message persists, try resetting the printer to its factory defaults. To do this, turn off the printer, press and hold the "Go" button, and turn the printer back on while continuing to hold the "Go" button. Release the button when the printer's attention light turns on and all other lights turn off.
  5. If the issue still persists after resetting the printer, it may be necessary to replace the printer's formatter board, which contains the printer's internal memory and storage.
As for the slow response when using the printer's keys, this may be caused by a separate issue. Here are some steps you can take to troubleshoot this issue:
  1. Check the printer's display for any error messages or other indications of a problem.
  2. Make sure that the printer's firmware is up to date. You can download the latest firmware from HP's website and install it using the printer's embedded web server or HP Web Jetadmin software.
  3. If the printer is connected to a network, try connecting it directly to a computer using a USB cable to see if the issue persists. If it does not, there may be a problem with the network connection.
  4. Try resetting the printer to its factory defaults, as described in the previous section. This may help to clear any configuration or settings issues that are causing the slow response.
2/15/2023 5:56:53 PM • HP Office... • Answered on Feb 15, 2023
HP Officejet 100 Mobile Inkjet Printer, Bluetooth-Enabled Logo
5 questions posted
Clive
Clive
Ben Johnson
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
make hp officejet 100 discoverable
  • Office Equipment & Supplies
