20 Most Recent Apple iPad HD Questions & Answers
Try opening the "APP" store and typing in "Dictionary" under "Search" and downloading it directly from there?
Apple iPad HD | Answered on Oct 25, 2017
Your iPad HD is getting hot for a multitude of reasons, primarily because you are using it without taking a break. Things that are most likely to cause your iPad to overheat are the following:
  • Playing games continuously for more than 1 hour
  • Not taking a break from using the iPad for more than 1 hour
  • Using 4G LTE for more than 1 hour
  • Charging the iPad while using it
All of these things are part of the core experience of owning the new iPad and unfortunately Apple kind of dropped the ball here.
Having said that, I have had many devices over the years and this probably isn't the big issue everyone is making it out to be. Just be certain to use your iPad in moderation and everything will be fine.
Apple iPad HD | Answered on Nov 09, 2016
Make sure you are using an authentic charger if that doesn't help update your ipsw to the latest firmware
Apple iPad HD | Answered on Mar 10, 2015
Hello Linda
I had this over the weekend with Scrabble. There is something wrong with the Scrabble site or connection.
Today it seems to work fine.
But you can go to your Scrabble game
click on Options way at the bottom
click on About button
And click the category you can send them an email or question.
Apple iPad HD | Answered on Feb 09, 2015
Factory reset! Connect to PC and log into iTunes, you can reset from there!
Apple iPad HD | Answered on Jan 15, 2015
You will have to test it on a computer, and maybe change it because the password seems to not transfer over
Apple iPad HD | Answered on Sep 03, 2014
follow these instructions from apple
http://support.apple.com/kb/HT5787
Apple iPad HD | Answered on Jul 30, 2014
Try connecting to PC and start iTunes.
Apple iPad HD | Answered on Apr 14, 2014
I recently bought an iPad Air, and I'd like to use Kinkoo portable charger which I bought from: http://www.ikinkoo.com/shop/portable-charger/kinkoo-infinite-one-8000mah.html to charge it. I found Kinkoo can charge my iPad rapidly, only cost a few hours to charge it from 5% to 100%. Works perfectly than I expected.
Apple iPad HD | Answered on Dec 31, 2013
There are many things you might be doing wrong but slow battery charge is a problem with the new iPad. The battery is actually a lot bigger than the iPad 2 which means it is going to take you much longer to charge.
Use the provided charger and don't charge from your computer. It is almost twice as slow to do it plugged into a computer. Charge it at night to give it the most time to charge as possible. I usually turn it off so programs don't run and slow down the charging speed. Every little bit helps.
I can help you with other things too if you ask.
Safari is junkola, get Chrome or another browser. Safari always has issues with mine.
Apple iPad HD | Answered on Dec 16, 2013
Try to update it (if possible)
Apple iPad HD | Answered on Nov 27, 2013
https://play.google.com/store/apps/details?id=com.netflix.mediaclient
HERE IS THE LINK I USED TO INSTALL A SOMEWHAT WORKING FIX
Apple iPad HD | Answered on Oct 14, 2013
go to Creigs list. if there is a seller near the area you live in, you two may even be able to meet up and you can look over the IPad before you buy it.
Apple iPad HD | Answered on Apr 10, 2013
I answered this before. Please look at all answered problems before asking questions. Others have probably already given you the information.
Here is my answer:
There is no way to edit the screen ratio on the new iPad or any iPad for that matter. They went with 4:3 because the majority of users use the device to browse the internet and read e-magazines or e-books on it. As you know the screen gets cut off when you go to fullscreen or it has those annoying black bars above and below.
If you're looking to watch video do it on a computer or your TV. The new iPad isn't made for heavy video watching IMO.
Apple iPad HD | Answered on Oct 17, 2012
Hi datsyukiandeke,
Here are a few pointers I have for you when gaming on the new iPad:
  • Turn down your screen brightness. This is the best way for you to avoid heating issues. Your new iPad probably came out of the box with brightness turned all the way up. If you turn that down you will notice a decrease in heat immediately.
  • Use Wi-Fi instead of 4G LTE whenever possible. Now obviously you can't do this everywhere, but whenever possible you should access the internet via Wi-Fi and avoid riding your 4G LTE chip. That baby is power hungry and will heat up quick.
  • Give your A5X chip a break. In less technical terms, try not to play graphics heavy games (like Infinity Blade) for an extended period of time. Like you said in your question, that's when you experience the most heat discomfort. If it is at all possible for you to take even a short break (like 10 minutes every hour) from gaming, it should do a lot to keep the heat down.
I hope that helps you out!
Apple iPad HD | Answered on May 05, 2012
This has been debated many times. Many feel that the new iPad's heat is a problem, while many others think it is the media blowing it out of proportion. The majority of FixYa Experts feel the answer is somewhere in the middle as it definitely does run hotter than the iPad 2 but does not run as hot as some laptops.
So I would say it is a problem but not one that should keep you from buying for yourself to use.
But, I would be careful giving it to your kids. Make sure to monitor them when they are using it. Children's skin is much more sensitive than adults. Be a good parent and like everything be close to your kids when they are using the device.
If you do that, playing with the new iPad should not be a problem for your kids.
Apple iPad HD | Answered on Apr 19, 2012
Apple iPad HD Logo
39 questions posted
Top Apple Tablets & eReaders Experts
John mullen
Shaukat Bhutto
Shaukat Bhutto
Nicola Conroy
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
iPad Apple
  • iPad Apple
Most Popular Question
when playing scrabble cannot finish word
  • Tablets & eReaders
