20 Most Recent HP ProBook 4530s Notebook Questions & Answers
Powerbutton issue
its broken buy a used or new switch assy, on ebay.
1/14/2022 9:27:16 PM • HP ProBook 4530s... • Answered on Jan 14, 2022
2answers
My computer hp probook 4530s cooling fan not
You'll probably have to replace it. There are videos on youtube that can give you instructions on how to replace it, or you can bring it into a qualified computer repair shop and they can replace it for you.
8/29/2019 1:12:34 PM • HP ProBook 4530s... • Answered on Aug 29, 2019
I have the HDMI cord plugged in to both laptop and TV. Computer will not detect
Try connecting the tv first... Or getting a new wire.
If those don't work you might want to try the monitor button. Most laptops have them as one of the function keys. Often looks like a projector or a square with some extra lines. Try it with the fn key depressed and also without as fn lock might be on.
But try those first two things first.
12/13/2015 8:15:55 AM • HP ProBook 4530s... • Answered on Dec 13, 2015
2answers
How do I fix "HP_DATA partition not found. Cannot capture data."
Is the HP Tools Partition still on the drive? Right click Computer Left click on Manage Let Computer Management load On the left is Disc Management Click on it and on the right information about your local drives that are installed will load. Your C drive should show up and it will list all partitions. Does one of them says HP Tools? Did this problem start after installing the Office software? Does the HP Quicklook pop up come up every time you open Outlook? If so have you gone in to see if its a program that you can uninstall from Add/Remove programs? If you can uninstall it do so. I found this information when searching for hp quicklook HP QuickLook is a Personal Information Manager (PIM) viewer for Microsoft Outlook 2003 and 2007. HP QuickLook caches Email, Calendar, Tasks, and Contact Information from Microsoft Outlook 2003 and 2007 and enables users to view and edit this data quickly from a notebook that is Off or in Hibernation mode (without having to open Microsoft Outlook first). So if you don't need it, uninstall it. It could be causing the issue that you are having.
5/6/2015 5:03:16 AM • HP ProBook 4530s... • Answered on May 06, 2015
USB Ports are not working HP ProBook 4530s
check you have the drivers
4/14/2015 8:28:37 PM • HP ProBook 4530s... • Answered on Apr 14, 2015
How if, user profile service failed to log0n
Use the F8 key on power-up, it uses a different administrator login. You can then proceed to user accounts on control panel and delete and create a new user which should solve the problem.
3/19/2015 9:50:02 PM • HP ProBook 4530s... • Answered on Mar 19, 2015
Hi dear Fixya Technical support team I need help! I replace new battery to Hp ProBook 4530s but unfortunately doesn't charge. Thanks With Regards
Any chance you have a friend with the same Probook or a volt meter to see if your AC adapter is woring?
2/27/2015 3:12:20 PM • HP ProBook 4530s... • Answered on Feb 27, 2015
Unlock the mouse pad on my hp laptop?
Try double tapping the upper left hand corner of the screen.
2/21/2015 10:53:15 PM • HP ProBook 4530s... • Answered on Feb 21, 2015
How to change user ID & domain ID in HP Probook 4530s?which appears when you switch on your laptop..
Start > Control Panel > Search for "System" and click on it > On the left, click on Advanced System Settings > Click the Computer Name tab > Click the Change button > Click the Domain radio button > Add the domain name. You will need to be a memeber of the domain admin group, on your server, to perform this operation. When you go to log back in, it should have the domain you entered, selected.
10/17/2014 3:18:08 PM • HP ProBook 4530s... • Answered on Oct 17, 2014
Right Click on My Computer, go to properties, and in the general tab, click on Network. This is where you would change the domain you're in and the COMPUTER NAME. User IDs get changed in Control Panel under User Accounts
9/30/2014 9:29:30 PM • HP ProBook 4530s... • Answered on Sep 30, 2014
My laptop fn keys not working...?
hi ali That key does not work as an "Apple Fn" key -- it is handled internal to the keyboard, so it is not really a "key." (rather, it modifies other keys) to make them generate different codes. But you can make your function keys swap. See SysPrefs -> Keyboard -> "Use all F1, F2..."
9/25/2014 2:10:06 AM • HP ProBook 4530s... • Answered on Sep 25, 2014
How do i factory reset a hp probook 4530s
You would need the HP Recovery Media in order to do a system restore.
9/11/2014 3:42:25 PM • HP ProBook 4530s... • Answered on Sep 11, 2014
I have laptop hp probook 4530s . i off my laptop then after sometime i have tried to turn on when i press the button power on light is glowing and caps lock led flashing but not showing screen
Pls, Try changing the RAM memory and also apply heat to the display chip. Ideally, it is often the memory problem. so replace that.
7/18/2014 8:05:48 PM • HP ProBook 4530s... • Answered on Jul 18, 2014
Screen has hp logo and says press the ESC key for startup menu, but is not responding
Try a hard reset. Disconnect the power adapter (charger). Remove the battery. Now press few times the power button. Yes, with no power the laptop will not start but the idea is to drain any residual power left inside your laptop. Put the battery back and try again.
7/7/2014 11:28:30 AM • HP ProBook 4530s... • Answered on Jul 07, 2014
Black screen
check your ram
5/23/2014 1:00:31 PM • HP ProBook 4530s... • Answered on May 23, 2014
My teredo tunelling driver is not working
Reload the software.
4/8/2014 8:31:55 PM • HP ProBook 4530s... • Answered on Apr 08, 2014
My fingerprint is not work
Please check the finger print device in the Control Panel. Also, the finger print software.
2/18/2014 2:50:04 AM • HP ProBook 4530s... • Answered on Feb 18, 2014
Usb not recognise
unfortunately this happens from general wear and tear. USB are flash memory - in flash memory cells have a habit of dying this applies to anything with flash memory so phones tablets and solid state drives. you can attempt to recover it by reformatting the USB from disk management (make sure its the USB you format) if this doesn't work there is guides on how to do a Low level format and then a high level format but this is a last resort scenario
12/23/2013 9:46:54 AM • HP ProBook 4530s... • Answered on Dec 23, 2013
HP ProBook 4530s Notebook Logo
Popular Tags
86 questions posted
Top HP Computers & Internet Experts
Ekse
Mehandi Husain ...
Mandeep  Singh
Mandeep Singh
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ProBook HP
  • ProBook HP
Most Popular Question
1530
  • Computers & Internet
