20 Most Recent
StarTech.com (USB1100S) Network Adapter Questions & Answers
USB1100S adaptor
The small CD will/should work in a normal CD/ DVD? Just place in center it in the tray. This can B a problem tho if'n ya CD DVD is set Vertical.. like some I have had..
I have also got around this issue by getting access to a PC that I can use and copy the small CD to a Normal one.. or a USB stick etc, and put that on the PC that ya weren't able to use the Mini-CD on.
There isn't much on the 'net these links may be OK..
www.driversforwindows.com/startech_usb1100s_driver_8748.htm
www.driversforwindows.com/o/
I have a Hp Laserjet p1505 printer. I installed
Using the Settings Feature on your operating system; you need to make certain the printer is listed and it the main printer to send data to. Check all settings and make certain, if using a wireless connection that the wireless settings are managed correctly. Generally, this is covered in the printer manual. For best results, get the FREE updates, and diagnostic programs from HP.COM.
My Saturn 2001 wagon start for 2-3 sec and turn off
Sounds like a fuel problem.... make sure the theft light is out.... happens when you get a new battery, key or keyfob and that is a dealer problem..... first check fuse for fuel pump, then fuel filter then last pump
No driver
just pull out your sound card and search for a number on it and then search on the net. you will find that.
If this does't help you, tell us the number, we will do this for you.
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired an
employment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut.
They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
