20 Most Recent
Sunbeam SCH8211UM Ceramic Compact Heater Questions & Answers
Sunbeam BL0750 electric blanket green light blinking
Sure, here are a few suggestions on where to find a replacement controller for your Sunbeam BL0750 electric blanket:
* **Sunbeam customer service:** You can contact Sunbeam customer service directly and they may be able to help you find a replacement controller. Their contact information is available on their website.
[Image of Sunbeam customer service website]
* **Online retailers:** There are a number of online retailers that sell replacement controllers for Sunbeam electric blankets. A quick search should turn up a few options.
* **Local hardware stores:** Some local hardware stores may also carry replacement controllers for Sunbeam electric blankets. It's worth checking with your local store to see if they have any in stock.
Once you've found a replacement controller, you can either install it yourself or have a professional do it for you. If you're not comfortable installing the controller yourself, you can take your blanket to a qualified electrician or repair shop.
Here are some additional tips for troubleshooting your Sunbeam BL0750 electric blanket:
* Check the power cord to make sure it's plugged in securely.
* Try using a different outlet.
* Check the fuse or circuit breaker to make sure it's not tripped.
* If you've tried all of these things and the blanket still doesn't work, you may need to replace the controller.
I hope this helps!
Sunbeam heater SQH310 keeps shutting off when it is on 2, what do I do?
If you have the same heater i do then in between the elements at the bottom there is a safety swith that bends when it heats up and breaks the connection Dont mess with it plugged in it will shock the hell out of you but if you bend it down it wont be able to lift off the circut and will stay running untill you turn it off
Just need to know if
Lower temperature will keep the room cooler. For efficiency sake, lower the temperature gradually to
68 degrees.
Hope this helped you. Thanks for choosing FixYa.
My sunbeam heating pad remote is flashing the letter f
My sunbeam XL heating pad started blinking and I couldn’t figure it out. I Unplugged a couple of times and still it kept flashing. After hours of reading post, I did what wpart suggested and now it works normal again..... I kept pushing th on off button while plugged in, I unplugged it while still hitting the on off button, I plugged it back in while still hitting the on off button annnddddd drum roll please!!!!!! It started working properly! Thanks wpart, your the MVP and award goes to you!
