20 Most Recent Marantz NR1602 Questions & Answers
Can you please repost this download link? I have corrupt firmware on a marantz 1602.
Thanks!
Marantz NR1602 | Answered on Jan 25, 2019
First thing to do is replace the cable with a new high quality one. They can go faulty. If that doesn't work, check that you are outputting the correct signals from your devices, plus it is set to pick them up. If that doesn't work you might have a fault possibly on the TV.
Marantz NR1602 | Answered on Mar 20, 2017
Try to use different discs. Older unit may have problem writing high speed discs. Try to find 1x or 2x discs. OPC-optical power calibration. Another possibility that yourlaser is on the way out
Marantz Audio... | Answered on Aug 02, 2020
Check to make sure your speakers are in phase. This means that they are both wired the same way. Common problem, and can damage your amplifier if not changed. Positive and Negative must be the same on all speakers.
Marantz Audio... | Answered on Jun 25, 2020
You have a piece missing. I would guess a thin wavy washer on the base of the platter and spindle.
Marantz Audio... | Answered on Jun 24, 2020
Unless you have extensive knowledge of electronics and the equipment necessary to troubleshoot the issue, I would look for a reputable repair center. The unit has components inside that eventually fail.
Marantz Audio... | Answered on Apr 26, 2020
https://audiokarma.org/forums/index.php?threads/marantz-sr7000-increasing-bass-w-o-remote.504810/
Marantz Audio... | Answered on Apr 06, 2020
If the sound test revealed no response from the left front speaker, it is likely that there is no left channel output from your Marantz receiver. Connect a substitute speaker to left channel output to be sure.
Marantz Audio... | Answered on Dec 03, 2019
Try plugging in headphones, if they work, it sounds like outputs have blown,
Marantz Audio... | Answered on Oct 28, 2019
A high quality fast response Servo Stabilizer will solve the problem but mark my words highlighted
Marantz Audio... | Answered on Sep 23, 2019
Marantz NR1602 Logo
10 questions posted
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Marantz Audio Players & Recorders
Most Popular Question
marantz nr1602 not swtich after firmware
  • Audio Players & Recorders
