20 Most Recent LG SuperMulti Network Attached Storage N1A1DD1 Network Storage Server Questions & Answers
tip
How to remove hard drive
There is a single screw under the sticker on the bottom that says the warranty will be voided if you remove it. Remove that sticker and unscrew that black screw. Then one of the white panels (the one closest to the actual hard drive) will slide towards the front of the enclosure when you push outward on the two black panels enough to clear the white tabs from the big white panel. write_tip-m4of3zriqzvgamqfw4yjpfsg-2-0.jpg
2answers
LG 55UM7300PUA not powering on
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
2/21/2023 10:34:59 PM • LG Computers &... • Answered on Feb 21, 2023
2answers
My lg dm 7630 hifi keeps going to sleep mode without me doing anything.......what should i do to fix the problem
Hi, Please record the amount of time that it takes until your device goes into sleep mode and set a timer for 5 minutes less than that time everytime you begin to use the lg device. At the points the timer/alarm goes off, you can simply lower/increase the volume and the lg's internal sleep timer should be reset. Thank you.
12/6/2022 5:25:07 PM • LG Computers &... • Answered on Dec 06, 2022
LG23MP55 IPS Monitor - HDMI Mode - All Buttons Non-functional except Power On
Hi, Please try using an alternative connection to the hdmit and test the monitor buttons again. And using analog mode prior to testing the monitor buttons again sounds like a good test as well. Thank you.
11/16/2022 10:51:37 PM • LG Computers &... • Answered on Nov 16, 2022
The nozzles orange behind the water dispenser assembly. What are they for in the LG washing machine?
'the nozzles orange'? Do you means 'orange nozzles', or is 'orange' a typo? There should be no oranges back there :>) It you have removed the dispenser drawer, the nozzles cause the water to flow into the correct compartments. You can check parts diagrams to identify any part. Please always include FULL make and MODEL in all questions. https://www.google.com/search?q=lg+washing+machine+parts+diagram ..
11/13/2022 6:01:20 PM • LG Computers &... • Answered on Nov 13, 2022
2answers
Where is the off button on my LG laptop
Hi, the typical power button looks like an open circle with a line through the top where the opening of the circle. Usually it's located at the top -right portion of your keyboard. If not there, then please check the sides of your keyboard as well. Thank you.
10/31/2022 10:33:58 PM • LG Computers &... • Answered on Oct 31, 2022
2answers
FLATRON LG L1515S MONITOR ISSUES HOW SOLVE
We don't call anyone. Take it into a computer or television shop for repair. Ordinary people can't fix television monitors.
10/29/2022 10:08:37 AM • LG Computers &... • Answered on Oct 29, 2022
2answers
Lg flatron tv model 21fc2ab tv after power on power indicator blining with beep
Yeah, that's not good. The manual provides no information on this at all. It's not user serviceable, in any case. If it's still under warranty, contact LG and see about having it serviced. If it's not, it will need to go to a repair shop to be fixed. A recent discussion I had with a sales person at Best Buy regarding the cost of repairing Digital TV's these days, is that it's usually more cost effective to just get a new TV, as unless it's an in-line fuse that has blown, any repair work is going to generally involve replaicement of the main board, and will end up being a few hundred dollars, pretty close to the cost of a new TV anyway. Sounds like it's time for a new TV.
10/17/2022 8:32:48 PM • LG Computers &... • Answered on Oct 17, 2022
My LCD monitor's buttons not working. How to do factory reset of my LCD 1643c?
Hi please visit main menu > then setup > factory reset to attempt to factory reset your device. Please double check your device's manual if this does not work initially. Thank you.
10/13/2022 2:51:59 AM • LG Computers &... • Answered on Oct 13, 2022
LG W1934S turn on, power led shows blue light, but no display
so working on super old 2007 PC monitors. and no PC connected."? it is NOT ANY LED BACK LAMP monitor here. came new with XP PC's. the monitos all good to sleep mode if no PC vidoeo connected. in the usa, even by law, (energy star) how ever lacking a PC, the screen will show "no signal entering sleep mode" VGA monitor. LED = blue on, amber sleep, LED out, oFF. NO 1080P mode allowed, (so common now) <<<< big clue here. set the PC to 1024 x 768 (to test ) 60Hz. using a flash light (torch) tool,. turn on Monitor, see blue LED point flash light to screen, see data, now, on sceen in the beam now you now CCFL backlamps are dead. as most are this old. Display Modes (Resolution) 640 x 350 720 x 400 640 x 480 800 x 600 832 x 624 1024 x 768 1152 x 870 1152 x 900 1280 x 1024 1440 x 900 proof BELOW. A FREE MANUAL TOO. page 47, see 4, CCFL jacks and HV supplies here 600VDC free service manual with full schematics and BOM https://elektrotanya.com/lg_w1934s_flatron.pdf/download.html in my shop I have VGA signal generator to maKE WORK EASY.
9/20/2022 8:09:55 PM • LG Computers &... • Answered on Sep 20, 2022
4answers
My LG model LW1516ERY7 Air conditioner is beeping and I don't know what it means. Can you help?
https://www.youtube.com/watch?v=IHL1wxni7tY
9/8/2022 10:29:51 PM • LG Computers &... • Answered on Sep 08, 2022
Touch buttons not working on LG 47lm4600 n I have no remote
Hello, hope to find you well. You can try the LG ThinQ app for smartphone, that will allow you to control your TV. Hope it helps.
7/5/2022 9:34:03 PM • LG Computers &... • Answered on Jul 05, 2022
How to fix LG monitor that doesnt turn on?
If you get a notice on the screen that the feed is not detected you may want to replace the feed cable to your device. If that doesn't work try the monitor on another device and see if the problem follows.
6/20/2022 2:58:19 AM • LG Computers &... • Answered on Jun 20, 2022
My lg lcd monitor shows STROMSPARMODUS on mid of screen...can any one tell 2 fix it.??
Hello! If you see that problem it's Automatically It's ok. It's maybe because your 1280x1024 lcd is little bit bigger than the original size! Have a nice day!
4/21/2022 10:56:19 AM • LG Computers &... • Answered on Apr 21, 2022
My LG laptop's power button light is on when I plug it to the charger I can see the lights but it's not restarting
So the light usually is there to tell you the psu is receiving power...Does pressing any buttons do anything? Can you remove the battery and reseat it?
4/18/2022 1:22:19 AM • LG Computers &... • Answered on Apr 18, 2022
LG SuperMulti Network Attached Storage N1A1DD1 Network Storage Server Logo
2 questions posted
Top LG Computers & Internet Experts
Marvin
Marvin
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • LG Computers & Internet
Most Popular Question
lg laptops power button light when plug
  • Computers & Internet
