20 Most Recent
Creative Labs I-Trigue 3600 Computer Speakers Questions & Answers
I have my old amp
You may attach any speakers you wish. If your amp is weak ,then avoid really huge ones. Otherwise, go nuts.:)
Farmerbear at FixYa.com
Sub doesn't work
try to check audio cable.. or the speaker wire.. if dosnt get ok.. anyway wer u from?
Crackling noise
if you so a test on your speakers you will find the one speaker is doing the same you must take the unit back because the speaker is faltie
Sound increases and decreases
If you are downloading illegal music this will happen. The music companies do this.
I
can't fix this for you, but if I helped you get it fixed, please rate it as a
fixya not a helpful rating. These ratings let me be allowed to help you
and others in the future.
Crackling
you may have played the speakers too loud and made them have effects or you have spilled something or! you have messed with the settings hope this helps!
No sound no nothing !
make sure :
1- the the speakers are connected to the sub woofer correctly
2- the sound driver is installed on your computer ( you can check that from Device Manager )
3- that you connected the sub woofer jack to the correct jack of your computer
4- the volume parameter is set to highest in your computer
if nothing works out then i suggest connecting the speakers to another device ( like ipod or mp3 player )
if either this won't work then the speakers are obviously corrupted :)
Hi, Is there a plug that will allow bulk printing
You can use this ONLINE tool from eBAY. ITS COMPLETELY FREESelling Manager is an online tool designed for medium-volume sellers to help
manage and track listings on eBay. Selling Manager is conveniently located in My
eBay. Use with Turbo Lister for a complete solution.
• Monitor active listings
• Generate bulk feedback and print invoices
• Print invoices and labels in bulk
Bulk Printing (Selling Manager Pro)
Selling Manager Pro subscribers can print as many as 200 invoices or shipping
labels at one time from the Sold View.
To print multiple invoices and shipping labels:
In the Sold View, check the box next to the listings that you want to print
invoices or shipping labels for and click the Print button.
To select all of your Sold items, check the box in the heading bar above
the list of sold items
From the Print page, select the printout you want, and click the Continue button.
In the pop-up window that appears, use the scroll bar to preview each of the
pages that will be printed.
Once you are satisfied with how the pages will look, click the Print button in the browser window.
If you need to edit information for a specific page, go the corresponding
sales record. When you are finished updating the sales record, save your
changes. Your changes will be reflected the next time you print.
This pro version is available for approx $5 per month
My IC BT9843 is burnt I need an equivalent to replace it.any help please?
Try searching again using Google, using BT 9843, but when you look down the results ignore the two letters and see if you can find an IC which is the same numbers, even if it has different letters on the front. Those letters could be just the makers letters, with the device made by different makers.
Barely see screen
If the brightness is all the way down, simply turn it up.
If not this indicates an issue with the device and you should take it to your local tech repair shop
My speakers stopped working after they were unplugged etc
Try the BLUE jack, then the GREEN jack. You won't hurt anything if you guess wrong. BTW, are the sub and speakers powered up? Pilot light showing they're on? Some speakers are powered by a USB port - any loose USB cables laying around?
