20 Most Recent
Creative Labs Inspire 2500 Computer Speakers Questions & Answers
M2600 no sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Sound only comes out of one speaker. If I switch
check the balance settings for one, and yes there is, What kind of plug do you have on your speakers that go into the sub, if its just a normal headphone jack, Go to radio shack and buy a splitter usually costs about 4 bucks and you can plug both speakers into it and then it into the empty sub jack.
I request you to please send me a link to the
There are NO drivers for any desktop speakers, you only need drivers for your sound card. Your support page states this .....
Creative speakers do not need to be installed at all as they can be plugged in to a device and ready to be used straight away.
Desktop speakers are designed to function with most sound cards without the use of any drivers. As such, there are no drivers necessary for the speakers to function as they were designed. The sound card or audio device which the speakers are plugged into may require drivers and/or software to work. Ensure that your speaker is connected to your sound card's audio out and that your sound card is configured properly to output sound. Please contact the sound card manufacturer for driver availability.
I have given additional ac supply to it something
Rohit,
With additional AC supply you have most likely burnt the amplifier. But there may still be hope if only the power supply unit of the device has been burnt. Open up the rear panel of the unit that has the power cord coming into and look for burnt and burst components. The whole modules would have to be replaced with exactly the same specs.Do it. if you feel that you cant handle it then go to the service center of the brand that you have.
Input jack problem
if its just jour input jack get a soder and get a jack from some old head phones and soder them together that will work
Help needed for speakers
lo-ve stated: but i cant still get to it in my windows
system and sound options. But there's nothing there.
If there's nothing there your computer can't find a sound card!
blue
Hi, Is there a plug that will allow bulk printing
You can use this ONLINE tool from eBAY. ITS COMPLETELY FREESelling Manager is an online tool designed for medium-volume sellers to help
manage and track listings on eBay. Selling Manager is conveniently located in My
eBay. Use with Turbo Lister for a complete solution.
• Monitor active listings
• Generate bulk feedback and print invoices
• Print invoices and labels in bulk
Bulk Printing (Selling Manager Pro)
Selling Manager Pro subscribers can print as many as 200 invoices or shipping
labels at one time from the Sold View.
To print multiple invoices and shipping labels:
In the Sold View, check the box next to the listings that you want to print
invoices or shipping labels for and click the Print button.
To select all of your Sold items, check the box in the heading bar above
the list of sold items
From the Print page, select the printout you want, and click the Continue button.
In the pop-up window that appears, use the scroll bar to preview each of the
pages that will be printed.
Once you are satisfied with how the pages will look, click the Print button in the browser window.
If you need to edit information for a specific page, go the corresponding
sales record. When you are finished updating the sales record, save your
changes. Your changes will be reflected the next time you print.
This pro version is available for approx $5 per month
My IC BT9843 is burnt I need an equivalent to replace it.any help please?
Try searching again using Google, using BT 9843, but when you look down the results ignore the two letters and see if you can find an IC which is the same numbers, even if it has different letters on the front. Those letters could be just the makers letters, with the device made by different makers.
Barely see screen
If the brightness is all the way down, simply turn it up.
If not this indicates an issue with the device and you should take it to your local tech repair shop
My speakers stopped working after they were unplugged etc
Try the BLUE jack, then the GREEN jack. You won't hurt anything if you guess wrong. BTW, are the sub and speakers powered up? Pilot light showing they're on? Some speakers are powered by a USB port - any loose USB cables laying around?
