20 Most Recent Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48 Questions & Answers
CHECK THE THERMOSTAT WHETHER IS IT TO THE LOWEST CAUSING VERY LITTLE FREEZING. TAKE THE KNOB TO THE MAXIMUM AND THEN SEE WHETHER IT STARTED. IN CASE NO THEN CHECK THE WIRING OF THE FAN MIGHT BE SOME CONNECTION NOT IN PLACE
Beverage-Air... | Answered on Sep 29, 2014
http://www.beverage-air.com/Main.aspx?pid=49&tab=50
go to this site and see if your manual is there. It's a start.
Beverage-Air... | Answered on Jun 07, 2014
Go to this site and see if the Manual is for you unit.
sounds like it may have no power or has stopped working. Model and serial numbers would help.
There are different models made for holding different products. Yours has a 1/3 hp compressor for above 20 degs. It may have 0 on the thermostat and may well pull down that far, but -20 would be out of it's reach. Where as it's sister model is made to freeze to below zero has a 3/4 hp compressor. Larger compressor for the lower temps.
Beverage-Air... | Answered on Mar 30, 2013
http://www.beverage-air.com/Main.aspx?pid=50&tab=51 you will find the pdf files for specs & manuals here.
Beverage-Air... | Answered on Aug 27, 2011
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Beverage-Air... | Answered on Aug 24, 2010
Beverage air used R134a almost exclusively on refrigerators. The process is similiar to ac systems. You should weigh the charge in as per the data plate. Be precise as over or under charge can dramitically affect the performance of the unit. Hope this helps
Beverage-Air... | Answered on May 09, 2010
Be sure you have the defrost timer set for 4 defrost cycles and no less than 30 minutes each time.
Make sure doors close and seal tight.
Verify that the defrost heaters work.
Sit and time a defrost cycle. It could be terminating early, prior to the coil being completely cleared.
If it is frost on the coil, could be an air leak or high humidity.
If it is icing, it is a defrost problem.
Start here and let me know.
Good Luck!
Beverage-Air... | Answered on Jul 08, 2009
Most likely a short in the compressor electrical components (relay, overload,capacitor) Supco makes a 3 in 1 that you could use. If this works fine, if not "bad compressor".
Beverage-Air... | Answered on May 28, 2009
Unplug the fridge overnight and defrost it completely. Ensure the thermostat is properly set.
If it does not restart normal function after you plug back, then there may be a fault concerning the digital control, in that case call the number listed on the owner manual.
Beverage-Air... | Answered on Jan 07, 2009
Having to manually defrost an automatic defrost system tells me there is a problem with your defrost timer. Most Beverage-air freezers have a Paragon timer. There are two dials on these timers. An inner and outer dial. On the inner dial is an arrow to indicate the direction of rotation as counter clock wise. On the inner dial is a copper pointer indicating duration of the defrost cycle.
Observe the copper pointer, no movement indicates that the timer is bad.
Beverage-Air... | Answered on Jul 09, 2008
What does ( da ) mean on a beverage two fan single door reach in frezzer disply
Beverage-Air... | Answered on Aug 08, 2015
Beverage-Air 44.9 cu. ft. / 1271 liter Commercial Freezer KF48 Logo
Popular Tags
22 questions posted
Top Beverage-Air Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Tom Chichester
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
View Most Popular
  • Beverage-Air Freezers
Most Popular Question
lpw temp freezer reach
  • Freezers
