20 Most Recent Brother SE400 Computerized Sewing Machine Questions & Answers
My top thread was running out, and when it did,
Its the bobbin below the needle it nees to be taken out and put back in
2/19/2018 4:56:00 PM • Brother SE400... • Answered on Feb 19, 2018
Why do my needles break only when doing reinforcing stitches?
This may be obvious but are you changing your needles frequently? A blunt or bent needle can cause this.
1/20/2018 3:26:56 PM • Brother SE400... • Answered on Jan 20, 2018
2answers
Problem with brother SE400
Looks like this girl does not have any issues with Brother se400 machine.
4/8/2017 4:31:02 PM • Brother SE400... • Answered on Apr 08, 2017
When transmitting a design from Amazing Designs Letter It, the LCD on my machine says transmitting design. However, the design never shows up. What am I doing wrong?
Check to make sure the design is not going into a folder. You may need to drill down a level or two to find it. That happens a lot with Bernina machines. ...
10/7/2016 9:11:52 PM • Brother SE400... • Answered on Oct 07, 2016
How do I switch from cm to inches
check in the instruction manual, and if you don't have one, check with brother sewing machine customer service to see if they can get you one and also their technical support may be able to help you with the problem. here are some link to try http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/NetworkUsersManual/NUM_SE_400_ENES_2330.PDF http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/QuickSetupGuide/QSG_SE_400_ENES_2329.PDF http://www.brother-usa.com/VirData/Content/en-US/HAD/Consumer/UsersManual/UM_SE_400_EN_2327.PDF Contact Brother
2/18/2016 4:17:39 PM • Brother SE400... • Answered on Feb 18, 2016
Thread is stuck in feed dog area
Yes it can. Lift the presser foot and take out the bobbin ,unscrew the needle plate (the silver plate under the presser foot) take out the bobbin case and all those threads should be easy to tease out from the area. Putting it all back the same way (You may need your instruction book if you are unfamiliar with these internal bits and pieces. While you have everything apart put a few drops of oil on all the moving parts and the machine will love you cheers Dot
9/25/2015 10:18:42 AM • Brother SE400... • Answered on Sep 25, 2015
2answers
I need to take apart my Brother SE 400 so I can replace the spool pin.
This is general information for all sewing machines. There are often hidden screws inside and clips that can not be seen. You can gently pry the machine apart and see where it is hanging up. Often the screws are reached from the side with a long Phillips screwdriver. You will need a flashlight to see them. Some models have access to the cover screws after removing a knob or the bottom plate.
5/22/2015 11:36:39 PM • Brother SE400... • Answered on May 22, 2015
Feeder dog will not stay up
take the plate off that covers the feeder dogs, sometimes those screws come loose
1/2/2015 8:35:44 PM • Brother SE400... • Answered on Jan 02, 2015
Why Is my bobbin thread showing on material instead of my color thread ?
It's a tension problem. The upper tension is too tight and it's pulling the bobbin thread up through the fabric instead of giving the proper balanced stitch. This is also why it's bunching up the thread. One thing to check on any machine when upper thread problems appear is the thread guides and the needle. Needles can get dull, or have a burr in the eye, which can chafe the thread and cause a lot of problems. So put in a brand new needle and check every thread guide to see if there are any nicks or rough spots. If there are, replace the guide or use emery cloth or fine sandpaper to smooth a rough spot. Also be sure the bobbin case area is very clean, no lint build up under there. That can cause problems too. I don't know enough about how computer machines adjust the upper tension, but if you can change the tension setting, using the controls, then loosen it and see if that helps. One other thing that can sometimes help is to change the thread spool for a new one and rethread the machine. Simple to try, at least. You may need a repair visit if you can't adjust the upper tension and it's possible that whatever mechanism is used to control tension may need to be repaired or replaced.
11/26/2014 11:17:18 PM • Brother SE400... • Answered on Nov 26, 2014
My 1 year old Brother SE-400 bobbin is spinning and making lots of noise. I have cleaned all I can gain access to, and I have put in new needle and made sure it is tight. I have confirmed that the b
You have done well so far. Check the thread to make sure it is not too thick or thin. Also, that the bobbin is not over full. Also make sure it is threaded correctly. Check the manual as you do this. Otherwise, find your warranty and return to shop.
10/16/2014 2:03:29 AM • Brother SE400... • Answered on Oct 16, 2014
Needle bar frozen
Rather suspect the bar has bent, remove it and check for true
2/19/2014 9:20:44 PM • Brother SE400... • Answered on Feb 19, 2014
Screwdriver given with the machine is not useful to unscrew the screws on the needle plate
the screwdriver with a handle is for something else. the one the is a circle metal with a small jutted out notch is the one for the plate:)
2/17/2014 1:34:48 AM • Brother SE400... • Answered on Feb 17, 2014
Brother SE400 Computerized Sewing Machine Logo
54 questions posted
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Brother Sewing Machines
Most Popular Question
brother se 400 metal ring
  • Sewing Machines
