20 Most Recent D-Link DP-G321 Print Server Questions & Answers
I can not print through my wirelss laptop on D-Link G321 print s
Call Printer support phone number 1-888-687-4491 USA Toll-free and find instant support.
2/21/2018 10:40:12 AM • D-Link DP-G321... • Answered on Feb 21, 2018
Why my D-Link DP-G321 Print Server don't work with a laserjet 1020
Laserjet 1020 is a host-based (WIN) printer. Won't work on DP-G321. Connect using USB to a PC and share it.
8/5/2014 5:43:00 AM • D-Link DP-G321... • Answered on Aug 05, 2014
Cannot connect wirelessly. Direct connect ok.
You should set Preamble to Short (default is Long) in the WiFi configuration page.
4/4/2012 4:01:50 PM • D-Link DP-G321... • Answered on Apr 04, 2012
It doesn't see local printer
- change the cable
- assure your plug.
5/13/2011 4:53:17 PM • D-Link DP-G321... • Answered on May 13, 2011
0answers
ALL ICONS ARE NOT ON
It sounds like your windows went into a temporary profile, this is nothing to do with your router. This is a windows problem. i've attached a link that gives you step by step to fix for windows 7 machine.
http://www.winhelponline.com/blog/fix-windows-easy-transfer-error-using-temporary-profile-windows-7/
3/7/2011 11:32:50 PM • D-Link DP-G321... • Answered on Mar 07, 2011
Will not work unless I disable my current wireless
You need to use the SSID of the wireless router on the print server. Any wireless security applied to the router must also be applied to the print server. Otherwise you have two seperate wireless networks.
9/2/2010 8:52:01 PM • D-Link DP-G321... • Answered on Sep 02, 2010
Single print
check in page setup plz
6/25/2010 7:31:07 PM • D-Link DP-G321... • Answered on Jun 25, 2010
Will this unit work with Visa 64 bit OS ??????????
Yes, but it run like 64 bit, because of the other devices.
12/16/2009 3:34:29 AM • D-Link DP-G321... • Answered on Dec 16, 2009
2answers
HP1100
I am currently using this print server with the HP Laserjet 1100 on the parallel port and it works flawlessly.
4/1/2009 9:55:06 PM • D-Link DP-G321... • Answered on Apr 01, 2009
Dp-g321 does it work with vista
According to its Datasheet, it will only work with the following Operating Systems:
- Windows 98, ME, 2000, XP
- MacOS EtherTalk
- Unix
- NetWare 5.0 or above (Native NDS)
- lpd
You can go to this link to download its Datasheet.
ftp://files.dlink.com.au/products/DP-G321/Datasheet/DP-G321_datasheet_01.pdf
3/8/2009 7:47:51 AM • D-Link DP-G321... • Answered on Mar 08, 2009
2nd printer on print server
Hello Kawena66,
There may be an ip conflict as the error suggest.
what is the ip address on your XP system?
9/19/2008 4:56:35 PM • D-Link DP-G321... • Answered on Sep 19, 2008
Factory reset d link DI-604 ethernet router
There should be a pinhole that allows you to do it with a paper clip...
2/16/2014 7:56:27 PM • D-Link DP... • Answered on Feb 16, 2014
2answers
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
11/12/2022 5:02:31 AM • D-Link Computers... • Answered on Nov 12, 2022
My d-link dwm-156 3g after upgrading its firmware don't working!
I am sure it is now toast and you cannot downgrade if the wrong firmware has been installed. I would ask D-Link.
5/10/2022 11:44:35 AM • D-Link Computers... • Answered on May 10, 2022
D-Link DP-G321 Print Server Logo
20 questions posted
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
DP D-Link
  • DP D-Link
Most Popular Question
cannot connect wirelessly direct
  • Computers & Internet
