20 Most Recent
D-Link DI-804HV - 4-Port Broadband VPN Router DI-804HV - 4-Port Broadband VPN Router [ DI-804HV ] (109528) Questions & Answers
D-Link Vpn Router model DI-804HV
Can you tell me the setup with your router? It should be Internet->Modem->Router->Computer
If that's setup properly (the wires in the right spots) then go to the gateway IP of the router...it might be something like "192.168.0.100 "so you put that in your internet browser. The default user is "admin" with no password. Make sure to run the "Wizard" while on that page and after that go to the "Status" page and check to see if the WAN connection is connected properly.
Using DI-804hv, I can connected to vpn but not to LAN
First set up an static IP address on your computer with a range 192.168.3.x, once you connect to the DI go to >> LAN Settings and change there the DI IP to be in your range of 192.168.2.x.
If you use win XP here is a link how to set up a static IP with your computer:
http://www.hotcomm.com/FAQ/FAQ_staticIPXP.asp
Regards,
Adnan
Vpn client
This router has built is VPN software that allows VPN from anywhere in the world. There would be no need for a software based VPN
Factory settings
Step 1 Power the unit off by unplugging its power adapter.
Step 2 Insert a paper clip in to the reset pinhole. Press and hold the reset button with light pressure.
Step 3 Power the device back on by plugging it in. Continue to hold the reset button.
Step 4 Watch the lights on the front of the router. The M1 & M2 should come on solid. When the M1 & M2 begin to blink slowly, release the reset button.
The unit will reboot itself and should be at factory defaults. If the M1 light is not blinking about once per second, unplug the power on the router and plug it back in.
If the M1 & M2 continue to blink rapidly, you held the reset button for too long. Power the device off and repeat the reset procedure.
The default IP address is 192.168.0.1. The default username for our routers is admin. The password is blank. If your router asks only for a password, use admin (lower-case).
9815813107 tell me name and adrress
You can find the details of the operator and the state they belong to .the operators wont reveal the address and name of any mobile numbers only higher officials can only get those information.
In order to trace the operator name and state you can try this link
http://www.indiatrace.com/trace-mobile-number-location/trace-mobile-number.php
I hope this will help you if it does do rate the answer
Thank you
regards
lalith
I have a D-link DP-300U device that I can not access
Ethernet/USB Print Server it is for even windows 98 (OMG )
page 7 is setup.
NO OS stated by you, at all. why:?
page 3 is OS compat.
after reset the default address is
192.168.0.10
5volt power pack is NOT OPTIONAL.
1998
what did you read the free manual yet.
the last page shows printer compatibility list, does your match?
where would you find a printer that old working now.
crickets...???
my guess is 2003 year made. XP first release is that.
one manual for it stamped 2003 so is 17 years old
relic fodder for sure, recycle it is best.
first hit
https://eu.dlink.com/-/media/consumer_products/dp/dp-300u/datasheet/dp_300u_datasheet_en.pdf
RTM ! no 17 year old printer works today, not really.
How to change password D-Link router DIR-655
the manual is free , at dlink dot com
you push the reset button for long time per manual 15sec (iirc)
the release it and now all defaults are set.
per the manual, google dir-655 manual.
easy as pie if you just read the manual.
How can i reset a router
There's a reset button on the back of the router, it's a small button that you can press using a paper clip. Press it for 15 seconds to reset it.
Reset 1:
Press the reset button for 15 seconds at the back of the router while the router is on.
Reset 2:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and release the reset button. Then plug the power cord back in.
Reset 3:
Press the reset button for 15 seconds while the router is on after 15 seconds unplug the power cord while holding the reset button then count another 15 seconds and plug the power cord back in while the reset button is plugged in and count another 15 seconds release the reset button.
Hope this helps.
D-link Router Tech Support Phone Number 1^877SCAMMER 69}}.support
Warning to FixYa readers -DO NOT CALL THE FAKE TECH SUPPORT NUMBERS POSTED ALL OVER THIS SITE. These phony support numbers or web links send you to criminal call centers where they will install malware, steal ID and/or extort money from you . Please only ever use the support contacts from the official company website {edited by volunteer Expert}
