20 Most Recent
Express 910 Radar Detector Questions & Answers
How do I use my Bel express 910.
I don't have a users manual for mine either! I found this link that helps a little bit to describe some elements of the detector...
http://www.radartest.com/article.asp?articleID=2003
My E550 Beltronics detector has developed a problem
you can try out some guide from reliable-store
they also provide live chat feature for instant help and it's very useful
using that I fixed my own excavator 5-6 times without any other help
plus free so whats harm in not getting
Using wrong power cord
Sounds like a dirty receptacle. If you're a smoker, I guarantee that's the problem. Take the cigarette lighter fuse out of your vehicle and clean the receptacle with sandpaper wrapped around a small stick. Good luck!
Beltronics rx65 service required can I fix this
This detector - along with other high-end types that require a microprocessor to analyze signals - performs a self-test when powering up. This is done for the same reasons a Power On Self Test is done on your computer. There's a lot going on inside and if just one area is malfunctioning data may not be processed correctly and in the case of the detector - resulting in aggravating false alarms or worse - not indicating an alert when needed.You should arrange for the detector's return to Beltronics for thorough checking / realignment. Contact Beltronics via this
link.I hope this helps!
