20 Most Recent Sunterra 300207 Pond UV BioFilter 2000 Gallons Black Questions & Answers
obtain proper replacement bulb
shut down entire filter for a moment before unscrewing the top locking ring off Uv filter (left turn) lift top off set asside
using a soft clean rag retract uv tube from its cylinder holder inside , remove power connector from tube end (you should have already removed all power from converter box) with extremely clean rag handle new tube ( allow no forign material to touch outside of tube ) reinsert power connector onto new tube (same way it came off old one) then reinsert tube into holder sleeve , route power cord to proper places away from lid , replace lid and install lock ring back with enough force to ensure a leak proof seal , re start pump ck for leaks if none found then restart power converter for Uv filter
Sunterra 300207... | Answered on Oct 01, 2015
Take the filter to your local hardware and get the connections that way.
Sunterra Garden | Answered on May 19, 2019
There is a fairly easy way to vary the flow on nearly any pump. You can use a valve after the pump to restrict the flow up to 20% or so without putting to much strain on the pump. As to a specific pump I would need to know the G.P.H. range you are looking for and I would be happy to help find you the right pump for your needs.
Sunterra Garden | Answered on Mar 29, 2011
if its not making the nose with the blades off it is probably bad bearings in the deck
Garden | Answered Yesterday
Security lock --- if standard code loss dealer with vin and proof of owner ship for code --- if security lockout same to dealer for hookup to reset
Garden | Answered 2 days ago
I had this with mine , found the wire into fan had disconnected from brush inside of motor easy fix.
http://parts.powersmartusa.com/index.php?cPath=9_40_42&osCsid=uoi2thtlk30m2u2lb325vbcjg3
Yes take it to napa auto parts and they can cut and attach a new end which are for hydraulics. They are crimped on and meant to hold very very high pressure. I used to use a pressure washer everyday for a living and it was a tractor rental/repair shop and we used the hydraulic fitting machine on the power washer hose all the time so rest assured.
Garden | Answered on Feb 21, 2021
Specifications - John Deere Manuals
manuals.deere.com > Output > OMGX22067_C513
Exhaust Valve Clearance 0.10-0.20 mm (0.004-0.008 in.) Operating Range 3100 - 3300 rpm. Spark Plug John Deere M78543, Champion RC12YC. Spark Plug ...
Better to go with Make Model Valve clearance
Videos
https://www.google.com/search?q=valve+clearance+on+a+John+Deere+8.75hp
Garden | Answered on Feb 20, 2021
have on used but good &10.00 Plus shipping e mail me at [email protected] if you want it
Garden | Answered on Feb 18, 2021
Sunterra 300207 Pond UV BioFilter 2000 Gallons Black Logo
3 questions posted
Top Sunterra Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
Are you a Sunterra Garden Expert? Answer questions, earn points and help others
View Most Popular
Sunterra Garden
  • Sunterra Garden
Most Popular Question
go about replacing uv light
  • Garden
