20 Most Recent Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001) Questions & Answers
Speedstream SS2510 Ethernet Router
Try Speedstream.com and specifically:
http://kb.efficient.com/display/1n/index.asp?c=&cpc=&cid=&cat=&catURL=&r=0.9983179
6/19/2008 7:58:46 PM • Efficient... • Answered on Jun 19, 2008
Factory defaults on ss2510 powerline router
Look for a small reset button. It would typically be concealed in a small hole where it can be pressed with a paper clip. Try pressing the reset button for about 15 seconds, then release it. If this fails to reset to defaults, turn off the power...press the reset button....turn on the power while holding the reset button in...continue to hold the reset button for about 15 seconds.
Good luck...and I hope this is helpful!
1/23/2008 11:47:40 PM • Efficient... • Answered on Jan 23, 2008
Which appliances can hinder Powerline networks?
Devices which can affect Powerline throughput inclued blow dryers, electric drills/saws, vacuum cleaners, and window-mounted air conditioners.
2/19/2006 2:53:56 PM • Efficient... • Answered on Feb 19, 2006
Can my neighbors or power company intercept my data over my powerline network?
Our Powerline devices have security that will prevent anyone from seeing your Powerline network. Using the utility provided with the device, you can encrypt all data transfers over powerline to 56 bit DES. In addition, the range of the powerline signal is limited, in order to help prevent others from accessing the data stream.
2/19/2006 2:53:12 PM • Efficient... • Answered on Feb 19, 2006
What is the default password for Powerline devices?
The default password is SpeedStream. Note that this password is case sensitive.
2/19/2006 2:52:16 PM • Efficient... • Answered on Feb 19, 2006
Can I use a Powerline product on a European 220 volt electrical system?
No. Currently we are only offering Powerline products for the North American market, with support for standard 120 Volt AC, 60 Hz electrical outlets. Simply plugging a 120 > 220 volt adapter will not work, as the transformer will block the broadband signal, not to mention that the increased voltage that is likely to leak through a standard adapter could destroy the product.
2/19/2006 2:47:47 PM • Efficient... • Answered on Feb 19, 2006
I have a large house (e.g. 4,000 sq ft). Will the Powerline network work throughout my house?
While the homeplug 1.0 standard was optimized for homes of around 2000 square feet, our Powerline devices have been tested with excellent results in homes of up to 7,000 square feet.
2/19/2006 2:47:02 PM • Efficient... • Answered on Feb 19, 2006
Does the 2501 work through a USB hub?
Yes, in most cases this USB device will work properly through a USB hub; however, we recommend that you plug the device directly into the USB port on your computer for best performance.
2/19/2006 2:46:09 PM • Efficient... • Answered on Feb 19, 2006
How many PCs can I connect to a Powerline network?
We recommend that there be no more than 10 computers active on a Powerline network at one time. It is possible to have more than this, but throughput will be greatly diminished.
2/19/2006 2:45:22 PM • Efficient... • Answered on Feb 19, 2006
Do I need to plug my Powerline product into a powerstrip/UPS to protect it?
No; the Powerline products have a built-in surge protector. Plug the unit directly into the wall socket.
2/19/2006 2:44:24 PM • Efficient... • Answered on Feb 19, 2006
0answers
Google red tube
tripp-lite 40kva ups rectifier on,but invertor not on ,alarm coming auxiliary supply abnormal
4/4/2014 3:41:18 AM • Efficient... • Answered on Apr 04, 2014
0answers
Mtu in cctv
Be the first to answer 1/28/2014 5:15:12 AM • Efficient... • Posted on Jan 28, 2014Be the first to answer
I am trying to set
How far have you got and what exactly are you having trouble with - ?
10/30/2010 11:55:31 PM • Efficient... • Answered on Oct 30, 2010
0answers
Where do i get a
Be the first to answer 10/8/2010 12:15:08 PM • Efficient... • Posted on Oct 08, 2010Be the first to answer
I can't set up wireless
Its asking for the username because in ur router, wi-fi protected set up(WPS) is enabled. Acsess the router's set up page using its default IP, and disable the WPS option, it wont ask for username and password anumore.
8/12/2010 9:33:18 PM • Efficient... • Answered on Aug 12, 2010
Please is there any WEP or WAP key that I can
Any encryption key will be specific to a network so no there is not a free universal key. If you find a non encrypted network like at Panera Bread Co. then you don't need a key.
11/18/2009 5:32:13 PM • Efficient... • Answered on Nov 18, 2009
3answers
Upgrading the OS Windows XP
Upgrading from OS Windows XP:
you can upgrade from Windows XP to Windows Vista(ultimate, premium, home, business.......),
you have to buy a Windows Vista CD and install a fresh copy or format.
Some Minimum Requirements:
i) Min 2GB RAM or atleast 1GB RAM(if you have>1GB RAM installation of Windows Vista will not continue)
II) External Graphic Card. for some versions of Windows Vista(to run Aero Interface, special feature only   in some versions of Windows Vista)
NOTE:
"Windows Vista Upgrade Advisor" is a software from Microsoft which you can download from internet, this  can help you determine which features and edition of Windows Vista will run on your computer.
 i.e., when u load this software on windows xp it will suggest which upgrade version of windows vista          will suit your system(based on you system configuration. or hardware components.) and then            you can install the upgraded version of windows xp(mostly windows vista home,.........)
Thanking You
M. Sridhar
5/28/2024 6:08:02 AM • Computers &... • Answered 4 hours ago
Efficient Networks Siemens SpeedStream Powerline 2510 DSL/Cable Router (936-2510-001) Logo
12 questions posted
Top Efficient Networks Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Efficient Networks Computers & Internet
Most Popular Question
factory defaults ss2510 powerline router
  • Computers & Internet
