20 Most Recent Canon imageRUNNER 2545 AllInOne Laser Printer Questions & Answers
How to solve Cannon ir 2545 e000840
There Is a failure in the shutter of the fixing unit . Remove the fixing unit and check the shutter mechanism
1/20/2020 8:58:30 AM • Canon... • Answered on Jan 20, 2020
5answers
Canon ir 2420l restart the machine.If problem persists.Call service rep. **E000007-0000
Hi, that error indicates there is a problem in the fixing unit . The inner fixing film is damaged and needs to be replaced to solve that error
12/6/2021 6:39:37 PM • Canon Office... • Answered 17 hours ago
CANON IR 3225 ERROR 280 003 COMING
Ir3225 are 280
12/4/2021 6:32:04 PM • Canon Office... • Answered 2 days ago
My Canon MP140 printer won't turn on.
Question edited for clarity, changed 'want' to 'won't'. You want an answer because the printer won't turn on. Here is some information and videos to help you. https://www.google.com/search?q=Canon+MP140+printer+won%27t+turn+on ..
12/2/2021 8:21:00 PM • Canon Office... • Answered on Dec 02, 2021
E000-0001 05 on a canon 6255i
hi find link for E000-0001 https://printcopy.info/?l=en&mod=erc&brand=canon&model=iR%20Advance%206255i&code=E000-0001
12/2/2021 5:12:29 PM • Canon Office... • Answered on Dec 02, 2021
Canon MP520 printing only Magenta color on Windows 10
hi find link for printer drivers for win10 64bit https://www.canon-europe.com/support/consumer_products/products/fax__multifunctionals/inkjet/pixma_mp_series/pixma_mp520.html?type=drivers&language=en&os=windows%2010%20(64-bit)
12/2/2021 5:10:26 PM • Canon Office... • Answered on Dec 02, 2021
Printer is flashing in orange and green alternately
Flashing orange light after paper jam
12/1/2021 6:03:29 PM • Canon Office... • Answered on Dec 01, 2021
How to change bottom glass for canon dr5010c
How many commercial scanners do you have? https://www.google.com/search?q=canon+dr5010c+remove+bottom+glass ..
12/1/2021 4:14:34 PM • Canon Office... • Answered on Dec 01, 2021
4answers
Canon mp250 paper will not feed snags on something
I had a paper feed problem with a Canon MP 250 and solved it this way. (not my own)
After many attempts t clean the feed rollers etc. I tried the following.
I cut a piece of card stock about two inches wide. I fed this sock from the front to rear and carefully worked the card stock in and out and from side to side (flossed it) and dislodged a drywall screw !!
I realize that having a drywall screw lodged in the paper feed is not common, however this "flossing trick may help to clear the paper feed path in other situations.
12/1/2021 12:21:13 PM • Canon Office... • Answered on Dec 01, 2021
Paper feed on my canon fc-224s doesn't feed!
Hello.
clean the roller "which take the paper" by any clean Cloth weten with water.
12/1/2021 12:20:52 PM • Canon Office... • Answered on Dec 01, 2021
2answers
Canon MG2500 error code B200.What to do?
In canon printers the most common error code is B200. You'll learn in this article how to resolve canon printer error b200 by self. The Canon Printer Error Code B200 on the canon printers means that the voltage of the print head or the heat of the printhead is not usual. In certain situations, the b200 error can also result in damage to the print head and being unable to use it, or a problem with the cartridges. The Canon printers come in two or 4 + cartridges. If you have Four or more cartridges on your printer, you need to follow the instructions below. If you have a two-cartridge printer, skip to the section below. Step 1: Extract all cartridges. Step 2: Extract the printhead. Step 3: The print head is reinstalled. Step 4: Bring the cartridges back in. Step 5: Continue Blog - Canon Printer Error B200 0_rwlma5mq2bbnwyse-undefined-undefined-0_29.jpg
12/1/2021 11:55:41 AM • Canon Office... • Answered on Dec 01, 2021
My Canon mg2522 is having problems with feeding the paper into the printer!
Disconnect the printer and turn it upside down. And shake it a few times Maybe there is a foreign object in the paper path
12/1/2021 11:55:27 AM • Canon Office... • Answered on Dec 01, 2021
Mp 287 printer not responding
If your printer fails to respond to a job, check that all printer cables are connected properly and be sure that the printer is turned on. If everything is connected properly and powered up, go to the computer's "control panel" from the "start" menu. Choose "printers" and be sure that your printer is selected as the default. If everything checks out in the control panel, right click on your printer icon and select "properties." Click on the "details" or "port" tab and make sure that the correct port is checked off. Next, double click on the printer icon, which will bring up a list of current jobs in the print queue. Cancel all documents and try printing again. If your printer is attached by USB port, you may try connecting to other USB ports.```````````
11/30/2021 5:18:52 PM • Canon Office... • Answered on Nov 30, 2021
No ink on print out from canon mg6150, please help
how much ink is in the ink Cartridges? have you changed the ink cartridge recently ? You may need to clean the print head. see http://www.cityinkexpress.co.uk/cheap-printer-cartridges/canon/pixma-mg6150/mg-series/cleaner/printhead-cleaning-cartridge/yellow http://www.ebay.com.au/itm/Printhead-Ink-CLEANING-KIT-Fix-Canon-PIXMA-MP990-MG6150-MG6250-QY6-0078-000-New-/250992770857 seems to look like it may be a manual procedure with the mg6150 rather than a computer setting in the printer properties. Look under properties to see if there is a computer generated head clean .
11/30/2021 5:14:08 AM • Canon Office... • Answered on Nov 30, 2021
My printer is showing red lines!
Question edited to fix errors in printer name format. Plus it is either a CP-200 or a CP-1200. There isn't a CP-2000. This is the likely reason. https://www.dpreview.com/forums/thread/4008872 Also remove the cartridges, remove the printhead, and look for scraps of paper or lint in the area. It is a known issue on these. https://www.google.com/search?q=Canon+Selphy+CP-200+printing+red+lines ..
11/25/2021 3:28:17 PM • Canon Office... • Answered on Nov 25, 2021
My Canon 2420 developer blade gets wrinkled.
Yes, it is a known issue on that model. Maybe the developer roller is damaged, so that is damaging the blade. It can also be caused by the paper stock. https://www.google.com/search?q=Canon+2420+developer+blade+gets+wrinkled ..
11/23/2021 4:15:10 AM • Canon Office... • Answered on Nov 23, 2021
Canon imageRUNNER 2545 AllInOne Laser Printer Logo
4 questions posted
old marine
old marine
Ekse
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
solve cannon ir 2545 e000840
  • Office Equipment & Supplies
