20 Most Recent Sylvania SMPK8099 MP3 Player Questions & Answers
If it won't turn on then CHARGE IT!!! That's one way.....???
Sylvania... • Answered on Jan 18, 2021
Try charging the player for four or more hours.
Sylvania... • Answered on Dec 25, 2012
MP3 players can only play music files in mp3 file format. You can download mp3 music files from the Internet to your computer and then copy them to your MP3 player using the USB cable. For your CD collection, you need to convert your CDs to mp3 music files onto your computer or download them from the Internet and then copy them to your MP3 player after you have connected the USB cable to the MP3 player and the computer. You can do this using Windows Media player and Rip the CDs - Media Player will create a MP3 music file for each music track. Click on this link for instruction on converting music files to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
Sylvania... • Answered on Oct 29, 2012
Check the fuse in the adapter cable .
Sylvania... • Answered on Oct 17, 2012
On Off switch is the slide button on the side The switch may be faulty. You don't normally need it switched on to use USB, as the computer is supplying the power. This says it needs to be on for charging, that is odd! Battery 3. Remarks (Additional information for Adaptor purchase) 2.1 Make sure the power switch is on to charge, or the player could not be charged properly. The LED light 2 and LED light 1 are on when the player is charging, the light 1 will be off when the battery is full 3.1 The adaptor must be conformed to following standard could not be charged properly. The LED light 2 and LED light 1 are on when the player is charging, the light 1 will be off when the battery is full 2.2 Disconnect the player and charger if you want to stop charging 3.1.2 Output: 5.2V 0.2V 3.1.3 Max.: 350mA 3.1.4 4 pins adaptor When connecting to the computer via USB, it WON'T be recognised as such, but it you open Windows File Explorer, you will see it as a Volume in the left hand side pane. Drag music to a folder and drop music in from there. http://portablemedia.manualsonline.com/manuals/mfg/osram_sylvania/smp2012.html ..
Sylvania Audio... • Answered on Dec 15, 2020
Hi crystal 1299...
Downloading Music to MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your data cord, besure Windows Media Player is on.
6...Windows Media Player should recognize the MP3 player and sync with it.
7...After it is synced with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Free Answer...Please take time to rate me
Sylvania Audio... • Answered on Apr 21, 2020
Well, what are you trying to use it on? Does your device have Bluetooth? If you have Bluetooth. All you have to do is go into settings on your device and turn on Bluetooth. Follow the instructions and it should work... Regards Geoff
Sylvania Audio... • Answered on Jan 06, 2020
Any that will fit into the socket, as it's more of personal choice and to some extant how much you want to spend on the quality of the headphones. Many stores let you listen to the headphones or ear buds. Human hearing is not the same for everyone. So you need to listen to some before finding out the best for you. It might also depend on how comfortable they are to use. There's nothing worse than headphones that make you ears sweat!
Sylvania Audio... • Answered on Oct 12, 2019
Hello Rita, I am sending you the link so you can download the user manual of your, Sylvania clock radio scr1206bpl I hope you find the information useful Greetings Franco Dosil Hola Rita, te envio el link para que puedas descargar el manual de usuario de tu ,Sylvania clock radio scr1206bpl Espero te sea util la informacion Saludos Franco Dosil https://data2.manualslib.com/pdf4/95/9449/944856-sylvania/scr1206bpl.pdf?19d9acb7260bfa8d2564b71d52fa0231&take=binary
Sylvania Audio... • Answered on May 04, 2019
Sounds normal. Most digital clocks have a rapid set in forward and a slow in backwards. Helps you to get through the hours quickly. As you speed past the correct setting, you then backup slowly to the correct time.
Sylvania Audio... • Answered on Apr 29, 2019
A lot of manuals can be accessed by googling them. Now hurry up before the alarm goes off!
Sylvania Audio... • Answered on Nov 08, 2018
Sylvania SMPK8099 MP3 Player Logo
17 questions posted
Top Sylvania Audio Players & Recorders Experts
Terry
Terry
Gregg Mahin
Gregg Mahin
Are you a Sylvania Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Sylvania Audio Players & Recorders
Most Popular Question
mp4 sylvania smpk8099 8gb will not turn
  • Audio Players & Recorders
