20 Most Recent Toshiba Satellite L750 Notebook Questions & Answers
Toshiba satellite L750-iq6 won't shut down or sleep?!?
That is a software issue with the OS. Was it always like this? If not, try a system restore to some time in the past when you know the unit was working fine.
9/6/2017 3:21:52 PM • Toshiba... • Answered on Sep 06, 2017
How do i factory reset when i cant login?
you need to use a password recovery disk or re install your copy of windows.
1/8/2015 3:41:05 AM • Toshiba... • Answered on Jan 08, 2015
What wrong with my computer?
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced. Rechargeable batteries will fail if stored in a discharged state for long periods.
9/25/2013 4:30:34 PM • Toshiba... • Answered on Sep 25, 2013
Mtp device drivers
DOWNLOAD FROM CNET SIDE
9/14/2013 2:50:29 AM • Toshiba... • Answered on Sep 14, 2013
Help desk
You have too much storage ,you need to delete a whole lot of files,lap tops dont hold a lot of files,pictures and videos take up a lot of room,and then music will too,also run defrag and set it up to do so every day.See how much is trying to start up when booting up,if there is too many programs booting up with the os system it will cause this problem also.
5/12/2013 11:46:15 PM • Toshiba... • Answered on May 12, 2013
The ordinal 575 could not be located in the dynamic link lidrary iertutil.dll
You might have some viruses and malware.Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below...Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira...You should be in pretty good shape if you run and install all of these programs.
6/29/2012 3:41:43 AM • Toshiba... • Answered on Jun 29, 2012
L750 block of colour on bottom half
Your lcd screen is going bad. It's either the lcd screen or the video card inside the computer. To isolate the problem try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok then your video card is ok, but your original monitor is bad. If the Borrowed monitor displays the same as your original monitor then your video card is bad.Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
6/8/2012 9:33:09 PM • Toshiba... • Answered on Jun 08, 2012
Why does the dvd rom click once and a while when not in use?
That is a hard question, generally it wil go into test mode when computer starts up, it is possible there may be a small glitch in the software or hardware but nothing to worry about provided it functions properly.
5/19/2012 7:32:13 PM • Toshiba... • Answered on May 19, 2012
How do i get all three symbols on a key to work on my toshiba satellite L750 to work?
blue symbol use after fn key of specify key use shift key take one symboluse normal key take normal symboluse fn special key to take third symbol
5/19/2012 12:42:16 PM • Toshiba... • Answered on May 19, 2012
Computor not showing start buttons or icons when turning on
press ctrl+alt+del and when given the menu go to file>new task(run) and type explorer.exe and press enter. that should bring up your menus also you can try to go to the bottom of the screen and see if the menu is auto-hiding for some reason if it is once it pops up right click and go to properties and turn off the auto-hide feature. If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
5/9/2012 9:42:55 AM • Toshiba... • Answered on May 09, 2012
My toshiba satellelite computer's second indicator is always in orange colour.it is like that in the shut down mode also.why
The lights are indicators of power on or charging the battery or Internet connection activated. More than likely your battery is charging that is why when you shut it down the battery indicator lite may be on showing you that there is a charge going on. Check your manual for what each indicator light shows you. John
5/5/2012 4:03:50 PM • Toshiba... • Answered on May 05, 2012
My toshiba laptop keeps turning off
This issue could be caused by any of the below possibilities.::::: Heat related issue. >> Hardware issue or error. >> Computer virus. >> Issue with operating system. >> Other failing hardware.... >>Two important things that you should do to fix a laptop which keeps shutting down are::::1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop. 2- Repairing and cleaning Windows registry. Run a system utility tool like ReginOut to repair corrupt registry and windows files.
4/16/2012 10:16:10 AM • Toshiba... • Answered on Apr 16, 2012
How do i torn up volumn on toshiba L750
there are 2 easy ways first is by pressing the fn (function key) and number 4 at the same time or you can click the speaker icon in the bottom right corner of your screen and drag the slider up hope this helps
2/2/2012 3:10:54 PM • Toshiba... • Answered on Feb 02, 2012
3answers
Is the product key for Microsoft office 2013 the same as all product keys for 2013 Microsoft offices that operate under laptops using windows 8.1?
The product key is associated with the MS Office 2013 software, not the specific MS Windows version of Operating System - unless the MS Office lists a minimum version of OS ie: "Windows 8.0" In this case, it would not install on Windows 7. Otherwise, you should be able to install it on Windows 7, Windows 8, or later.
2/15/2024 4:30:57 PM • Toshiba... • Answered on Feb 15, 2024
Japanese Visa Application with COE denied. Why?
How to Get Employment Security With Correct Japan Work Visa Japan is no different from other developing nations whereby grass seems greener on its side of the pasture. It attracts its fair share of foreign businesses as well as nationals seeking to work within its lands. Albeit many adhere to immigration procedures, some choose to test their limits on the basis of ignorance or defiance. By understanding the different types of work visa in Japan, it assures its foreign workers a continual stream of income with no threat of arrest and deportation. Visa simply infers the status of residence. Citizens obviously have no need of it as they automatically satisfy qualifications to freely reside in their country of birth. As for those of alien status who wish to join the local workforce, there should be a category to match one's requirement. Since most countries strive to improve the overall quality of life, professionals are generally welcomed to contribute knowledge and skill. Unskilled labor is normally not granted a visa to avoid flooding and dilution of the workforce. The visa is awarded in accordance to one's area of expertise. Supported with proof of relevant experience, it is based on the field of involvement whilst working in the country. In the event one's work scope changes from one expertise to another, it is essential to apply for a visa under the new circumstances. Different types of work visa in Japan also apply to foreign companies seeking to conduct local business. Domestic companies based abroad wishing to set up a local point of presence need to provide supporting documents to justify internal transfer of foreign workers. Governmental staff for diplomatic duties is assigned a category for legal residence. Over and above the general groupings, designated activities also garner approval from the authorities. Domestic service for non-native residents and citizens of certain nations on working holidays fall into this category of working visa. This, by no means, is the end of the list as it is best to consult the authorities on which visa serves best.Click Here For More Details: http://japanjobandvisaservice.com/blog/change-your-luck-when-apply-work-visa
5/22/2023 2:52:35 PM • Toshiba... • Answered on May 22, 2023
HOW TO ENABLE TOUCHPAD ON TOSHIBA SATELLITE a665-S6080
In BIOS, I made Pointing Device Enable and It has been done.
11/28/2022 9:05:08 AM • Toshiba... • Answered on Nov 28, 2022
Toshiba Satellite L750 Notebook Logo
Popular Tags
22 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
  • Computers & Internet
