20 Most Recent Sharp FX Plus Questions & Answers
Cant recieve picture messages
Make sure your APN settings match. Name: Straight Talk APN: tfdata Port: 80 MMSC: http://mms-tf.net MMS proxy: mms3.tracfone.com MMS port: 80
3/19/2014 4:54:46 AM • Sharp FX Plus • Answered on Mar 19, 2014
Too many pattern attempts, i to unlock my phone
I please want to unlock my phone. I was asked to sign in with google account in order to unlock my phone. I have tried this to no avail
2/20/2014 3:58:28 AM • Sharp FX Plus • Answered on Feb 20, 2014
Messages being rejected, says that its full but it not
How can i unlock my soft bank 003sh phone. I want to use it in philippines?
1/23/2014 3:45:24 AM • Sharp FX Plus • Answered on Jan 23, 2014
Sharp fx plus screen unresponsive
Sounds like the touch screen is dead, the crack most likely broke the touch screen sensor
1/20/2014 5:27:17 AM • Sharp FX Plus • Answered on Jan 20, 2014
0answers
Unlock
Be the first to answer 11/11/2013 10:30:58 AM • Sharp FX Plus • Posted on Nov 11, 2013Be the first to answer
No sound
that means you ear piece is dead or its disconnected,you just need to open your phone and fix your ear peace or speaker
11/8/2013 9:08:31 PM • Sharp FX Plus • Answered on Nov 08, 2013
3answers
Why won't my phone charge?
I had the same problem. I bought two new batteries before I figured it out. The three brass connections on the phone that normally touch the battery tend to curl up after several battery pulls like a finger curls up into a fist. After you remove the battery, gently scrape the brass leads on the phone with your fingernail until they extend out onto the chrome area beneath. If it doesn't work then try again. The charging leads are not making the connection to the battery because they are bent or curled up into the phone.If it still doesn't work then there's something else wrong.
5/27/2013 8:11:07 PM • Sharp FX Plus • Answered on May 27, 2013
Why can't i connect to wi fi, or my service network
Has it found your network?
4/28/2013 4:57:25 PM • Sharp FX Plus • Answered on Apr 28, 2013
Powers off by itself
Cell Phone Keeps Shutting Off Vibrations on dirty battery contacts could be the cause of this problem. Remove the battery and clean the battery contacts with methylated spirits and the battery contacts in the cell phone.
1/29/2013 2:48:02 AM • Sharp FX Plus • Answered on Jan 29, 2013
I can make calls and receive call and ppl can hear me but i cant hear them on my sharp fx plus
Sometimes network problems make this,
other wise phones speakr problam.
1/25/2013 5:33:34 PM • Sharp FX Plus • Answered on Jan 25, 2013
Free unlock code for sharp fx plus
i am receiving calls but i cant get into my phone it says draw pattern to unlock
1/12/2013 1:42:46 AM • Sharp FX Plus • Answered on Jan 12, 2013
Phone says text messages are full but there is none.
do factory reset.
6/29/2012 10:27:36 PM • Sharp FX Plus • Answered on Jun 29, 2012
How do you unlock a phone made by Sharp STTM21VAPP from Verizon.
Using an unlock screen is easy. Enter the code. but, there are two types of code, A Subscriber set pass code or A PUK Code, aka a SIM Lock Which do you have? Click Comment. ..
12/20/2023 10:02:15 PM • Sharp Cell... • Answered on Dec 20, 2023
2answers
Unlocking sharp dvd dv-slv8 for indian region
DVD drives region settings can be changed to view DVDs from different region, but on the 4th change the DVD player will lock on the 4th region change.
The DVD player can be made region free by upgrading the firmware, if it is available, but if you make a mistake the the DVD player will be a piece of junk.
The best way to make a DVD player region free is to install a piece of software on the computer to make the DVD player region free.
Please click on this link and follow my instructions to make the DVD player region free :-
http://www.fixya.com/support/r3559135-playing_dvds_from_other_regions
11/7/2019 2:18:28 AM • Sharp Cell... • Answered on Nov 07, 2019
Sharp dab fv db1e not displaying text on screen
if this is the machine your talking about check out this link to the user manual it may have the answer. if not then you may have broken wire/s in that display. this user manual may have contact info in it so you might ask the mfg. about the issue. good luck. https://www.manualslib.com/manual/571166/Sharp-Fv-Db1e.html
9/6/2019 4:06:55 PM • Sharp Cell... • Answered on Sep 06, 2019
Sharp crt TV ka red light chalu rahta h on karne par on ho k 5 second bad phir standby me chali jati h
You should take it to an authorized technical center. It look's like an protective mode. Maybe some electr?nico component inside it's broken...
7/14/2019 8:47:01 AM • Sharp Cell... • Answered on Jul 14, 2019
How to factory reset a sharp iso3 android phone
It is very easy to do. You just follow these steps and that's it. * Go to settings * Go to the Privacy * Now you will see an option "Factory Data Reset" (Click on it) * Then Click on "Erase Everything" after that, your device will reboot itself and it will perform an operation which will reset your data from the factory.
4/11/2019 9:33:06 AM • Sharp Cell... • Answered on Apr 11, 2019
Sharp FX Plus Logo
54 questions posted
Top Sharp Cell Phones Experts
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Sharp Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
Sharp Cell Phones
  • Sharp Cell Phones
Most Popular Question
many pattern attempts unlock phone
  • Cell Phones
