20 Most Recent
ZTE Warp Questions & Answers
If you're not able to download apps from the android market then it might be due to criteria of the app not matching with the phones criteria. Let me know the error message?
ZTE Warp
Answered
on Jun 21, 2019
That is the boot up screen for the android. You can change the back ground in the settings menu under personalize I believe it is.
ZTE Warp
Answered
on Oct 26, 2017
Have the unit replaced since it is not working properly.
ZTE Warp
Answered
on Sep 05, 2017
How are you hooking it up? If you are using a USB cord from the phone to the car, most cars cant see the phone as a music device you have to set the phone as a usb storage device and even doing that wont guarantee that the stereo can find the music.
ZTE Warp
Answered
on Oct 14, 2016
Reboot. Remove battery and wait for 5 seconds. Put it back on. Enter 'Recovery Mode'. There will be some hardware button combination to enter Recovery Mode like Power+Volume Up+Volume Down. After entering, depending on your phone, you might have to navigate through physical buttons.
You will find 'Clear Cache' and 'Clear Dalvik Cache'. Do both.
And then Reboot normally. Now see if you can get the launcher working on your phone.
If that doesn't work, press home key, see if you can open some browser application or Play Store and download and install a new Launcher.
If that doesn't work, but you can somehow access settings, go to settings->Apps and clear data of your Launcher App.
If that isn't possible then, go to Recover Mode again and do 'Reset Factory Defaults'. This should make your phone feel just like when you brought it.
ZTE Warp
Answered
on May 19, 2016
Hi I think you should take your phone to a cell phone store, I'm sure they can advise you at no cost...Good luck...
ZTE Warp
Answered
on Mar 17, 2016
If your phone is pattern locked then either it will ask for Gmail account details if you have registered one or you can just enter *983*987# in the Emergency Dial which unlock your phone and also your phone will be resetted and all the datas will be erased. If your phone is locked with some PUK code then contact your service provider to unlock the phone.
ZTE Warp
Answered
on Aug 18, 2015
phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
ZTE Warp
Answered
on Aug 05, 2015
It sounds like the charging port is warn out. If you have a warranty on take to the store. If not, well to my knowledge there is no way of replacing it. Best. there a warranty. Worst. You need a New phone.
ZTE Warp
Answered
on Jun 10, 2015
Get rid off it.
ZTE Warp
Answered
on Jun 10, 2015
I have the same problem, just the phone 2 days ago
ZTE Warp
Answered
on May 06, 2015
